tommy18 Skrevet 13. august 2005 Del Skrevet 13. august 2005 (endret) Har endelig fått til tv-out i ubuntu med mitt geforce fx5200 nvidia kort. Ser bildet klart på TV nå, men når jeg setter xorg.conf til å vise både lcd (via DVI) og TV, så blir oppløsningen på LCD og 1024x769 mens den egentlig skulle vært 1280x1024...setter jeg xorg.conf til å kun vise LCD, får jeg den oppløsninga jeg skal ha. Noen som ser noe galt? Her er xorg.conf # /etc/X11/xorg.conf (xorg X Window System server configuration file) # # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the /etc/X11/xorg.conf manual page. # (Type "man /etc/X11/xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package. # # If you have edited this file but would like it to be automatically updated # again, run the following commands: # # cp /etc/X11/xorg.conf /etc/X11/xorg.conf.custom # sudo sh -c 'md5sum /etc/X11/xorg.conf >/var/lib/xfree86/xorg.conf.md5sum' # sudo dpkg-reconfigure xserver-xorg Section "Files" FontPath "unix/:7100" # local font server # if the local font server has problems, we can fall back on these FontPath "/usr/lib/X11/fonts/misc" FontPath "/usr/lib/X11/fonts/cyrillic" FontPath "/usr/lib/X11/fonts/100dpi/:unscaled" FontPath "/usr/lib/X11/fonts/75dpi/:unscaled" FontPath "/usr/lib/X11/fonts/Type1" FontPath "/usr/lib/X11/fonts/CID" FontPath "/usr/lib/X11/fonts/100dpi" FontPath "/usr/lib/X11/fonts/75dpi" # paths to defoma fonts FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID" EndSection Section "Module" Load "bitmap" Load "dbe" Load "ddc" #Load "dri" Load "extmod" Load "freetype" Load "glx" Load "int10" Load "record" Load "type1" Load "vbe" EndSection Section "InputDevice" Identifier "Generic Keyboard" Driver "keyboard" Option "CoreKeyboard" Option "XkbRules" "xorg" Option "XkbModel" "pc105" Option "XkbLayout" "no" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/input/mice" Option "Protocol" "ImPS/2" Option "Emulate3Buttons" "true" Option "ZAxisMapping" "4 5" EndSection Section "Device" Identifier "NVIDIA Corporation NV34 [GeForce FX 5200]" Driver "nvidia" BusID "PCI:2:0:0" Option "ConnectedMonitor" "DFP" #Option "IgnoreDisplayDevices" "CRT" Option "TwinView" "true" Option "TwinViewOrientation" "Clone" Option "TVOutFormat" "COMPOSITE" Option "TVStandard" "PAL-B" Option "SecondMonitorHorizSync" "30-50" Option "SecondMonitorVertRefresh" "60" Option "MetaModes" "1280x1024,1280x1024;1024x768,1024x768;800x600,800x600;640x480,640x480" Option "DPMS" EndSection Section "Monitor" Identifier "LCD1770NX" HorizSync 31.5-69.0 VertRefresh 56.0-75.0 Option "DPMS" EndSection Section "Screen" Identifier "Default Screen" Device "NVIDIA Corporation NV34 [GeForce FX 5200]" Monitor "LCD1770NX" DefaultDepth 24 #SubSection "Display" # Depth 1 # Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480" #EndSubSection #SubSection "Display" # Depth 4 # Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480" #EndSubSection #SubSection "Display" # Depth 8 # Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480" #EndSubSection #SubSection "Display" # Depth 15 # Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480" #EndSubSection #SubSection "Display" # Depth 16 # Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480" #EndSubSection SubSection "Display" Depth 24 Modes "1280x1024" #"1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480" EndSubSection EndSection Section "ServerLayout" Identifier "Simple Layout" Screen "Default Screen" InputDevice "Generic Keyboard" InputDevice "Configured Mouse" EndSection Section "DRI" Mode 0666 EndSection Endret 13. august 2005 av tommy18 Lenke til kommentar
Mortal Skrevet 14. august 2005 Del Skrevet 14. august 2005 Jeg er usikker på hvordan du vil ha det. Men grunnen til at oppløsningen blir 1024x768 er at driveren velger den høyeste MetaModes som begge skjermene takler. TV-utgangen takler maksimalt 1024x768. Slik har jeg det: Option "MetaModes" "1280x1024,1024x768 @1280x1024; 1024x768, 1024x768; 800x600, 800x600; 640x480, 640x480;" Dette gjør at Oppløsningen på skrivebordet og LCD-en blir 1280x1024 mens TV-en blir 1024x768. Bildet på TV-en scroller da etter musen. Når jeg skal se film, trykker jeg "ctrl", "alt" og "+". Da forandrer oppløsningen seg til 1024x768 på begge skjermer og selv om skrivebordet er større så skjønner de fleste medieavspillere dette og gir riktig størrelse ved fullscreen. Lenke til kommentar
tommy18 Skrevet 16. august 2005 Forfatter Del Skrevet 16. august 2005 Dette så ikke helt ut til å virke. Oppløsningen ble ikke 1280x1024; Alt ble "gigantisk" på begge skjermer, så bildet på både LCD og TV fulgte musa. Her er min xorg.conf (den delen som er viktig i denne sammenheng): Section "Device" Identifier "NVIDIA Corporation NV34 [GeForce FX 5200]" Driver "nvidia" BusID "PCI:2:0:0" Option "ConnectedMonitor" "DFP" Option "TwinView" "true" Option "TwinViewOrientation" "Clone" Option "TVOutFormat" "COMPOSITE" Option "TVStandard" "PAL-B" Option "SecondMonitorHorizSync" "30-50" Option "SecondMonitorVertRefresh" "60" Option "MetaModes" "1280x1024,1024x768 @1280x1024; 1024x768, 1024x768; 800x600, 800x600; 640x480, 640x480;" Option "DPMS" EndSection Lenke til kommentar
Mortal Skrevet 16. august 2005 Del Skrevet 16. august 2005 Det er slik "gigantisk" når du starter X? Her er i hvertfall min xorg.conf: # /etc/X11/xorg.conf (xorg X Window System server configuration file) # # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the /etc/X11/xorg.conf manual page. # (Type "man /etc/X11/xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package. # # If you have edited this file but would like it to be automatically updated # again, run the following commands: # # cp /etc/X11/xorg.conf /etc/X11/xorg.conf.custom # sudo sh -c 'md5sum /etc/X11/xorg.conf >/var/lib/xfree86/xorg.conf.md5sum' # sudo dpkg-reconfigure xserver-xorg Section "Files" FontPath "unix/:7100" # local font server # if the local font server has problems, we can fall back on these FontPath "/usr/lib/X11/fonts/misc" FontPath "/usr/lib/X11/fonts/cyrillic" FontPath "/usr/lib/X11/fonts/100dpi/:unscaled" FontPath "/usr/lib/X11/fonts/75dpi/:unscaled" FontPath "/usr/lib/X11/fonts/Type1" FontPath "/usr/lib/X11/fonts/CID" FontPath "/usr/lib/X11/fonts/100dpi" FontPath "/usr/lib/X11/fonts/75dpi" # paths to defoma fonts FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID" EndSection Section "Module" Load "bitmap" Load "dbe" Load "ddc" Load "dri" Load "extmod" Load "freetype" Load "glx" Load "int10" Load "record" Load "type1" Load "vbe" EndSection Section "InputDevice" Identifier "Generic Keyboard" Driver "keyboard" Option "CoreKeyboard" Option "XkbRules" "xorg" Option "XkbModel" "pc105" Option "XkbLayout" "no" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/input/mice" Option "Protocol" "ImPS/2" Option "Emulate3Buttons" "true" Option "ZAxisMapping" "4 5" EndSection Section "Device" Identifier "NVIDIA Corporation NV28 [GeForce4 Ti 4800 SE]" Driver "nvidia" BusID "PCI:1:0:0" Option "TwinView" Option "MetaModes" "1280x1024,1024x768 @1280x1024; 1024x768, 1024x768; 800x600, 800x600; 640x480, 640x480;" Option "TVStandard" "PAL-B" Option "SecondMonitorHorizSync" "30-50" Option "SecondMonitorVertRefresh" "60" Option "TwinViewOrientation" "Clone" EndSection Section "Monitor" Identifier "Generic Monitor" Option "DPMS" HorizSync 30-65 VertRefresh 50-75 EndSection Section "Screen" Identifier "Default Screen" Device "NVIDIA Corporation NV28 [GeForce4 Ti 4800 SE]" Monitor "Generic Monitor" DefaultDepth 24 SubSection "Display" Depth 1 Modes "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 4 Modes "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 8 Modes "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 15 Modes "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 16 Modes "1280x1024" "1024x768" "800x600" "640x480" EndSubSection SubSection "Display" Depth 24 Modes "1280x1024" "1024x768" "800x600" "640x480" EndSubSection EndSection Section "ServerLayout" Identifier "Default Layout" Screen "Default Screen" InputDevice "Generic Keyboard" InputDevice "Configured Mouse" EndSection Section "DRI" Mode 0666 EndSection Lenke til kommentar
