hero_ruler Skrevet 11. august 2005 Del Skrevet 11. august 2005 Når jeg skal brenne en cd med ubuntu 5.04 kommer feil meldingen: " Feil under skriving av cd Det oppstod en feil under skriving av cd'en: Systemet er for tregt til å skrive CDer med denne hastigheten. Prøv en lavere hastighet. " cdrecord: fifo was 0 times empty and 1 times full, min fill was 0%. cdrecord: fifo had 64 puts and 0 gets. cdrecord: Try to use 'driveropts=burnfree'. cdrecord: Max DMA data speed is 23. cdrecord: DMA speed too slow (OK for 23x). Cannot write at speed 24x. cdrecord: WARNING: This causes a high risk for buffer underruns. cdrecord: Permission denied. WARNING: Cannot set priority using setpriority(). cdrecord: Operation not permitted. WARNING: Cannot set RR-scheduler SCSI buffer size: 64512 cdrecord: Warning: using unofficial version of libscg (ubuntu-0.8ubuntu1 '@(#)scsitransp.c 1.91 04/06/17 Copyright 1988,1995,2000-2004 J. Schilling'). Linux sg driver version: 3.5.27 Warning: Open by 'devname' is unintentional and not supported. scsibus: -2 target: -2 lun: -2 devname: '/dev/hdc' scsidev: '/dev/hdc' cdrecord: WARNING: This causes a high risk for buffer underruns. cdrecord: Permission denied. WARNING: Cannot set priority using setpriority(). cdrecord: Operation not permitted. WARNING: Cannot set RR-scheduler cdrecord: If you have unexpected problems, please try Linux-2.4 or Solaris. cdrecord: There are unsettled issues with Linux-2.5 and newer. cdrecord: Warning: Running on Linux-2.6.10-5-386 cdrecord: Continuing in 5 seconds... cdrecord: Future versions of cdrecord may have different drive dependent defaults. cdrecord: Asuming -tao mode. cdrecord: No write mode specified. 2 ghz amd prosessor msn 52x32x52 brenner Aopen dvd brenner 1gb minne 128mb ati radeon 9200se Hva skyldes dette? Burde funke helt fint og brenne cder med det Lenke til kommentar
Mr.Elendig Skrevet 11. august 2005 Del Skrevet 11. august 2005 cdrecord: Max DMA data speed is 23. cdrecord: DMA speed too slow (OK for 23x). Cannot write at speed 24x. Prøvd å brenne med lavere hastighet? t.d. 16x Lenke til kommentar
hero_ruler Skrevet 11. august 2005 Forfatter Del Skrevet 11. august 2005 Det funka men det tar jo evigheter Lenke til kommentar
Jakob K Skrevet 11. august 2005 Del Skrevet 11. august 2005 Skjedde med meg istad også, og da måtte jeg brenne i 8x! Skulle heldigvis bare brenne ~300 MB, men det var jo rat for det - fungerer jo fint å brenne i full hastighet under Windows. Lenke til kommentar
hero_ruler Skrevet 11. august 2005 Forfatter Del Skrevet 11. august 2005 Funker fint i windows her og.. Litt små irriterende i lengden men,men Lenke til kommentar
Gronz Skrevet 11. august 2005 Del Skrevet 11. august 2005 Har du prøvd å brenne som root? Av en eller annen grunn fungerer det kun å brenne CD'er som vanlig bruker med lave hastigheter noen ganger. Lenke til kommentar
hero_ruler Skrevet 11. august 2005 Forfatter Del Skrevet 11. august 2005 Huske på neste gang Lenke til kommentar
Jakob K Skrevet 11. august 2005 Del Skrevet 11. august 2005 Har du prøvd å brenne som root? Av en eller annen grunn fungerer det kun å brenne CD'er som vanlig bruker med lave hastigheter noen ganger. Tenkte på det, da jeg så denne linja i feilmeldingen: cdrecord: Permission denied. WARNING: Cannot set priority using setpriority(). Men regnet med at alle brukerene skulle kunne brenne CD-er i samme hastighet. Lenke til kommentar
