hero_ruler Skrevet 10. august 2005 Del Skrevet 10. august 2005 (endret) Hei, jeg prøver og installere amsn cvs men får denne feilen: jonas@Jonas:~/tcl$ cd ~/amsn-cvs jonas@Jonas:~/amsn-cvs$ cd msn jonas@Jonas:~/amsn-cvs/msn$ ./configure && make checking for gcc... gcc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ANSI C... none needed checking for g++... g++ checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking how to run the C preprocessor... gcc -E checking for prefix by checking for wish... /usr/bin/wish checking tcl build dir... configure: error: Unable to find Tcl directory or Tcl package is not tcl-dev jonas@Jonas:~/amsn-cvs/msn$ Kan noen hjelpe meg? Edit: Kjører Ubuntu 5.04 Endret 10. august 2005 av hero_ruler Lenke til kommentar
Gronz Skrevet 10. august 2005 Del Skrevet 10. august 2005 Installer pakken "tcl8.0-dev" med Synaptic. Lenke til kommentar
hero_ruler Skrevet 10. august 2005 Forfatter Del Skrevet 10. august 2005 (endret) Så når jeg prøver og starte amsn cvs: Picture.tcl: TkCximage not loaded Edit: jonas@Jonas:~/amsn-cvs/msn$ ./configure && make checking for gcc... gcc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ANSI C... none needed checking for g++... g++ checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking how to run the C preprocessor... gcc -E checking for prefix by checking for wish... /usr/bin/wish checking tcl build dir... using tcl library in /usr/lib checking tk build dir... using tk library in /usr/lib checking for main in -lstdc++... yes checking for X... libraries /usr/X11R6/lib, headers /usr/X11R6/include checking for gethostbyname... yes checking for connect... yes checking for remove... yes checking for shmat... yes checking for IceConnectionNumber in -lICE... yes checking for imlib-config... /usr/bin/imlib-config checking for IMLIB - version >= 1.8.2... no *** Could not run IMLIB test program, checking why... *** The test program failed to compile or link. See the file config.log for the *** exact error that occured. This usually means IMLIB was incorrectly installed *** or that you have moved IMLIB since it was installed. In the latter case, you *** may want to edit the imlib-config script: /usr/bin/imlib-config You need to install Imlib 1.x, e.g. http://freshmeat.net/redir/imlib/4385/url_...b-1.9.10.tar.gz if your distributor doesn't have a package Could not find Imlib, traydock will not be compiled checking for ftello... yes checking for fseeko... yes checking for getpt... yes checking for strcasestr... yes checking for memmem... yes checking for dlopen... no checking for pthread_create in -lpthread... yes checking if mmx should be used... yes configure: creating ./config.status config.status: creating Makefile config.status: creating utils/linux/capture/config.h compile time options summary ============================ X11 : yes IMLIB : no Using Libng : yes Tcl : 8.0 TK : 8.0 utils/TkCximage/src/Rules.mk:10: advarsel: tilsidesætter kommandoer for mål 'utils/TkCximage/src/TkCximage.so' utils/TkCximage/src/Rules.mk:10: advarsel: ignorerer gamle kommadoer for mål 'utils/TkCximage/src/TkCximage.so' CXX utils/TkCximage/src/TkCximage.o In file included from utils/TkCximage/src/TkCximage.cpp:11: utils/TkCximage/src/TkCximage.h:23:25: tkPlatDecls.h: Ingen slik fil eller filkatalog utils/TkCximage/src/TkCximage.cpp: In function `int Tkcximage_Init(Tcl_Interp*) ': utils/TkCximage/src/TkCximage.cpp:152: error: `Tcl_InitStubs' undeclared (first use this function) utils/TkCximage/src/TkCximage.cpp:152: error: (Each undeclared identifier is reported only once for each function it appears in.) utils/TkCximage/src/TkCximage.cpp:159: error: `Tk_InitStubs' undeclared (first use this function) make: *** [utils/TkCximage/src/TkCximage.o] Fejl 1 Endret 10. august 2005 av hero_ruler Lenke til kommentar
Gronz Skrevet 10. august 2005 Del Skrevet 10. august 2005 (endret) vekke Endret 10. august 2005 av Gimper Lenke til kommentar
Gronz Skrevet 10. august 2005 Del Skrevet 10. august 2005 Prøv å kjøre "make all" i kildekodemappen. Lenke til kommentar
hero_ruler Skrevet 10. august 2005 Forfatter Del Skrevet 10. august 2005 Samme feilen som med make jonas@Jonas:~/amsn-cvs/msn$ make all /home/jonas/amsn-cvs/msn/utils/TkCximage/src/Rules.mk:10: advarsel: tilsidesætter kommandoer for mål '/home/jonas/amsn-cvs/msn/utils/TkCximage/src/TkCximage.so' /home/jonas/amsn-cvs/msn/utils/TkCximage/src/Rules.mk:10: advarsel: ignorerer gamle kommadoer for mål '/home/jonas/amsn-cvs/msn/utils/TkCximage/src/TkCximage.so' CXX /home/jonas/amsn-cvs/msn/utils/TkCximage/src/TkCximage.o In file included from /home/jonas/amsn-cvs/msn/utils/TkCximage/src/TkCximage.cpp:11: /home/jonas/amsn-cvs/msn/utils/TkCximage/src/TkCximage.h:23:25: tkPlatDecls.h: Ingen slik fil eller filkatalog /home/jonas/amsn-cvs/msn/utils/TkCximage/src/TkCximage.cpp: In function `int Tkcximage_Init(Tcl_Interp*)': /home/jonas/amsn-cvs/msn/utils/TkCximage/src/TkCximage.cpp:152: error: ` Tcl_InitStubs' undeclared (first use this function) /home/jonas/amsn-cvs/msn/utils/TkCximage/src/TkCximage.cpp:152: error: (Each undeclared identifier is reported only once for each function it appears in.) /home/jonas/amsn-cvs/msn/utils/TkCximage/src/TkCximage.cpp:159: error: ` Tk_InitStubs' undeclared (first use this function) make: *** [/home/jonas/amsn-cvs/msn/utils/TkCximage/src/TkCximage.o] Fejl 1 Lenke til kommentar
Gronz Skrevet 10. august 2005 Del Skrevet 10. august 2005 Installer "tk8.4-dev" og rekjør "make all". Lenke til kommentar
hero_ruler Skrevet 10. august 2005 Forfatter Del Skrevet 10. august 2005 Måtte ta med ./config og make Og det funker Takk for hjelpen Lenke til kommentar
