Problem med skjermoppløsning i Ubuntu
Har nettopp installert Ubuntu og valgte 1280x1024 som oppløsning. Likevel kan jeg bare velge mellom 640x480, 800x600 og 1024x768. What's the problem?
Har også installert nvidia-driver via apt-get, og prøvde å gå inn i xorg.conf, og der fikk jeg med meg at det bare stod de overnevnte oppsløsningene. Jeg la til "1280x1024", men det hjalp ikke..
ble kanskje litt mye, men slengte dette opp likevel:
Section "Files"
FontPath "unix/:7100" # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
# paths to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID"
EndSection
Section "Module"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "no"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "Emulate3Buttons" "true"
Option "ZAxisMapping" "4 5"
EndSection
Section "Device"
Identifier "NVIDIA Corporation NV40 [GeForce 6800]"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
HorizSync 28-49
VertRefresh 43-72
EndSection
Section "Screen"
Identifier "Default Screen"
Device "NVIDIA Corporation NV40 [GeForce 6800]"
Monitor "Generic Monitor"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1024x768" "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
Endret av Ole-Magnus
xorg.conf er nødvendig ja. Dessuten, du la vel til "1280x1024" under riktig fargedybde og restartet X11?
er ikke sikker på at jeg la det på riktig sted osv. Jeg fjerna 1280x1024 nå, så kan dere se på xorg.conf å si hvor jeg skal sette det inn :p Har nettopp installert ubuntu så jeg er ikke helt proff ennå.
Jeg restarta forresten X (ikke X11 etter hva jeg vet, hvis ikke det er det samme da)
Skal være på den nederste linjen under "Section "Screen"" som begynner med "Modes". Altså:
Depth 24
Modes "1280x1024" "1024x768" "800x600" "640x480"
EndSubSection
EndSection
Husk at for å teste må du logge ut, og så restarte X (Ctrl+Alt+Backspace).
Dersom det Gimper sa ikkje fungerar, kan du prøve å endre Section "Monitor" til:
Section "Monitor"
Option "DPMS"
#HorizSync 28-49
#VertRefresh 43-72
EndSection
Dvs kommentere ut dei to linjene.
Jeg prøvde først bare med det Gimper sa, og da funka det ikke; men da jeg i tillegg kommenterte de to linjene som objorkum sa fungerte det.
Takker og bukker alle sammen. Litt deiligere det her enn den 1024x768-oppløsningen...
Flottings!
Når du kommenterar dei ut er det det same som om dei ikkje eksisterar. Grunnen til at det no fungerte er at dei verdiane som var satt er feil, men når du kommenterte dei ut, får du X til å spørje skjermen din om dei korrekte verdiane, noko som fungerte.
  • 1 år senere...
Hmm, jeg har samme problemet. Har vært i xorg config og prøvd å sette skjermoppløsningen til 1680:1050 men den står bom fast på 1024x768
oppfriskningsraten er på 75 hz. For meg virker det som det er denne som er problemet, men jeg får bare opp valget 1680:1050 75hz i xorg når jeg velger advanced elns, den i midten iallfall. Når jeg velger simple og velger 20" skjer det heller ikke no. Den skal vel egentlig være på 1680:1050 60hz.
Men hva er det trådstartet har gjort for å få det til? Jeg er ikke helt med på dette med redigeringen...
Lim inn innholdet i din /etc/X11/xorg.conf her, så kan vi lettere hjelpe deg :-) (tips: når du da limer inn lange ting er det lurt å bruke SKJUL-taggene som forumet tilbyr, men vi overlever nok uansett)
Endret av kommers
