Gjestebok problemer i PHP
Jeg har en gjestebok og den skal virke helt fint. Men jeg vet ikke hvorfor jeg ikke kan poste ting :S
Sånn er hele scriptet:
<script type="text/javascript" src="smileys.js"></script>
<title></title>
<table width="100%" border="1" cellspacing="0" bordercolor="#000000">
<tr>
<td width="432"><form name="guestbook" action="post.php" method="post">
<p>Navn:
<input name="name" type="text" id="name">
<br>
E -Mail:
<input name="email" type="text" id="email">
<br>
WebSide:
<input name="url" type="text" id="url">
<br>
<br>
<strong>Smileys: <span class="style2"><img src="smileys/smiling.gif" alt=":)" width="15" height="15" style="cursor:pointer;border:0" onClick="addsmiley(':)')" /></span>
| <img src="smileys/sad.gif" width="15" height="15" style="cursor:pointer;border:0" onClick="addsmiley(':(')">
| <img src="smileys/mad.gif" width="15" height="15" style="cursor:pointer;border:0" onClick="addsmiley(':mad:')">
</strong><br>
Melding:<br>
<textarea name="message" id="message"></textarea>
</p>
<p>
<input type="submit" name="Submit" value="Send">
<input type="reset" name="Reset" value="Tøm Melding">
</p>
</form></td>
</tr>
</table>
<br>
<tr>
<td class="style3"><em><strong>Inlegg</strong></em>:</td>
</tr>
<tr>
<td><?php
//where shout data is stored must be CHOMDED to 777
$dataf = "posts.txt";
//max length of input
$length = 500;
$comments = 1000;
if (!$name)
{ $name = "Anonymous"; }
else $name .= ":";
if (!$email)
{ $email = "Hidden"; }
else $email .= ":";
if (!$url)
{ $url = "None"; }
else $url .= ":";
$message = str_replace(":mad:","<img src='smileys/mad.gif'>",$message);
$message = str_replace(":)","<img src='smileys/smiling.gif'>",$message);
$message = str_replace(":(","<img src='smileys/sad.gif'>",$message);
$message = str_replace("fuck","****",$message);
$message = str_replace("bitch","****",$message);
$message = str_replace("asshole","****",$message);
$message = str_replace("cunt","****",$message);
$message = str_replace("bullshit","****",$message);
$message = str_replace("shit","****",$message);
$message = stripslashes($message);
$comfile = file($dataf);
if ($message != "") {$df = fopen ($dataf, "w");
$message = stripslashes($message);fwrite ($df, "<table width='100%' border='1' cellspacing='0' bordercolor='#000000'>
<tr>
<td width='51'><strong>name</strong></td>
<td width='928'>$name</td>
</tr>
<tr>
<td><strong>email</strong></td>
<td><i><a href='mailto:$email'>$email</a></i></td>
</tr>
<tr>
<td><strong>website</strong></td>
<td><a href='$url' target='_blank'>$url</a></td>
</tr>
<tr height='100%'>
<td><strong>message</strong></td>
<td>$message</td>
</tr>
</table>
<br>");
for ($i = 0; $i < $comments; $i++) {fwrite ($df, $comfile[$i]);}fclose($df);}
Header("Location: $HTTP_REFERER");
?></td>
</tr>
</table>
Se på denne her:
Der ser du at formen heter guestbook.
Her ser du at submit heter Submit. Derfor prøver input'en å sende til "Submit" i formen som ikke eksisterer. Det du må gjøre er å gjøre disse like. Da skal det funke.
<form name="Submit" action="post.php" method="post">
Der ser du at nå heter formen "Submit".
Dette skal være korrekt, men hvordan ser post.php ut? Du ber den tross alt sende dit og da bør det være en funskjon der, ellers så skjer det jo ingen ting. :hm:
Lykke til da. :)
Endret av ett
Post ser slik ut. Men tror det er feil :S
<?php
$length = 500;
$comments = 1000;
if (!$name)
else $name .= ":";
if (!$email)
else $email .= ":";
if (!$url)
{ $url = "None"; }
else $url .= ":";
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr height='100%'>
<td>$message</td>
</tr>
</table>
<br>");
Dette ser da helt greit ut i mine øyne. Hva tror du er feil? Alle variabler og lignende ser ut til å stemme. Har ikke tittet veldig nøye, men ser sånn ut ihvertfall.
Edit: Se på denne:
$dataf = "post.txt";
Her ser du at i post.txt så gjøres det noe. Finnes post.txt?
Edit2: Hva skal du egentlig med å sensurere engelske banneord hvis ikke guestbooken skal være på engelsk?
Da kunne du droppa det.
Endret av ett
Kan du godt egentlig.
<?php
$length = 500;
$comments = 1000;
if (!$name)
else $name .= ":";
if (!$email)
else $email .= ":";
if (!$url)
{ $url = "None"; }
else $url .= ":";
<div class="name"><p>Navn: $name</p>
<div class="email"><p>Email: <a href='mailto:$email'>$email</a></p>
<div class="website"><p>Webside: <a href='$url' target='_blank'>$url</a></p>
<div class="message"><p>$message</p>
Nå ser post.php mye bedre ut. Fulgte det med noen posts.txt? Er tydligvis kommentarene som er der, eller noe.
På post så har jeg gjort slik:
<?php
$length = 500;
$comments = 1000;
if (!$name)
else $name .= ":";
if (!$email)
else $email .= ":";
if (!$url)
{ $url = "None"; }
else $url .= ":";
$message = str_replace(":@","<img src='smileys/mad.gif'>",$message);
<tr>
<td width='51'><strong>Navn:</strong></td>
</tr>
<tr>
<td><strong>E-Mail:l</strong></td>
</tr>
<tr>
<td><strong>WebSide:</strong></td>
</tr>
<tr height='100%'>
<td>$message</td>
</tr>
</table>
<br>");
Så når jeg poster ting så kommer dette opp:
Parse error: parse error, unexpected $ in /home/freehost/t35.com/s/m/smorky/inc/post.php on line 371
Endret av Martin-_-
Jeg hadde gjort ferdig filen til deg jo:
<?php
$length = 500;
$comments = 1000;
if (!$name)
else $name .= ":";
if (!$email)
else $email .= ":";
if (!$url)
{ $url = "None"; }
else $url .= ":";
Da skal den funke. Hva STÅR det i posts.txt? :hm:
Edit: Dette er bare en ryddigere kode enn din, men inneholder det samme. Prøv denne du.
Endret av ett
