Hvor mye er denne Skjermen Værdt? 21/22" CRT
Hei, lurer på hvor mye denne er verdt
tror den er noen år gammel ja, men vet ikke akkuratt hvor mange.
Her er litt spec:
0.24mm aperture grille uni pitch
This ultra-fine aperture grille uni pitch produces clear, crisp images with great picture definition, even at the highest resolutions.
2048 x 1536 maximum resolution
Displays a maximum resolution of 2048 x 1536 at 79Hz flicker-free refresh rate for easy viewing.
2048 x 1536 @ 79Hz
1920 x 1440 @ 84Hz
1600 x 1200 @ 99Hz
1280 x 1024 @ 115Hz
PerfectFlat® screen
Absolute flat screen provides realistically proportioned, precise images with reduction of ambient light reflection, image distortion and eye fatigue.
350MHz video input bandwidth
Delivers a sharp and realistic image at high resolutions.
E-Color's True Internet Color® and Colorific®
Colour management software included for reliable colours when users visit E-Color Corrected™ web sites. Colorific ensures precise colour matching from screen to other colour peripherals.
OnView® controls including ViewMatch®
All screen adjustments are made via an on-screen menu using simple controls. ViewMatch allows the user to adjust colour temperature and individual colour intensity for screen-to-print matching.
Screen Treatment
This specially formulated anti-reflection, anti-glare screen treatment uses a multi-layer process to refract unwanted light away from the user while maintaining the highest quality of the displayed area.
BNC Connector
Allows easy connection of two sources at the same time and switching between both with a single button.
TCO '03 and Energy 2000 certified
This monitor complies with the world's strictest standards for low emissions, safety, ergonomics, recycling and power management while saving costs through automatic power-saving modes.
Link her
http://www.viewsoniceurope.com/UK/Products/CRTProf/P225F.htm
takker for svar
Endret av m-momr
Siden den er brukt... 500 +/- noen hundrelapper.
Det som er bra på den er maks oppløsningen, grei nok Hz og at det er 21 tommer, men de som er intresert er noen som ikke bryr seg om plassen den tar, noe mange i dagens LCD 12/8ms tider gjør.
