benjamin84 Skrevet 29. august 2005 Forfatter Del Skrevet 29. august 2005 root@ubuntu2:/home/benjamin # iwconfig wlan0 essid "Askeladden" key s:000000000000000000000000 root@ubuntu2:/home/benjamin # dhcpcd wlan0 bash: dhcpcd: command not found root@ubuntu2:/home/benjamin # dhclient wlan0 Internet Systems Consortium DHCP Client V3.0.1 Copyright 2004 Internet Systems Consortium. All rights reserved. For info, please visit http://www.isc.org/products/DHCP sit0: unknown hardware address type 776 sit0: unknown hardware address type 776 Listening on LPF/wlan0/00:c0:49:55:91:0e Sending on LPF/wlan0/00:c0:49:55:91:0e Sending on Socket/fallback DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 4 DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6 DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13 DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 9 DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 11 DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 15 DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3 No DHCPOFFERS received. No working leases in persistent database - sleeping. root@ubuntu2:/home/benjamin # iwconfig wlan0 wlan0 IEEE 802.11g/b+ ESSID:"Askeladden" Nickname:"acx100 v0.2.0pre8" Mode:Auto Frequency:2.447 GHz Access Point: 00:0D:54:A3:1E:3C Bit Rate:1 Mb/s Tx-Power:15 dBm Sensitivity=1/3 Retry min limit:7 RTS thr:off Encryption key:3030-3030-3030-3030-3030-3030-3030-3030-3030-3030-3030-3030-3030-0000-00 Security mode:open Power Management:off Link Quality=54/100 Signal level=36/100 Noise level=0/100 Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0 WEP key'n er byttet til 00-00-00-00-00 osv osv for copy pasten, den korrekte key'n er brukt i oppsettet. Hvor de 3-tallene kommer fra vet jeg ikke. Lenke til kommentar
objorkum Skrevet 29. august 2005 Del Skrevet 29. august 2005 Kutt ut den s-en i key, altså bruk: iwconfig wlan0 essid "Askeladden" key xxxxxxxxxxxxxxxxxxxxxxxxxx Brukar du 128-bit WEP skal det vere 26 teikn i nøkkelen. Lenke til kommentar
olear Skrevet 29. august 2005 Del Skrevet 29. august 2005 Kutt ut den s-en i key, altså bruk: iwconfig wlan0 essid "Askeladden" key xxxxxxxxxxxxxxxxxxxxxxxxxx Brukar du 128-bit WEP skal det vere 26 teikn i nøkkelen. s: brukes hvis man bruker ASCII. Trodde trådstarter brukte ASCII, ikke Hex Lenke til kommentar
benjamin84 Skrevet 29. august 2005 Forfatter Del Skrevet 29. august 2005 (endret) hehe, ja lurte på om ikke det var den s'en som var skyld i 3 tallene Right, prøvd uten nå, og får samme resultat. root@ubuntu2:/home/benjamin # iwconfig wlan0 wlan0 IEEE 802.11g/b+ ESSID:"Askeladden" Nickname:"acx100 v0.2.0pre8" Mode:Auto Frequency:2.447 GHz Access Point: 00:0D:54:A3:1E:3C Bit Rate:1 Mb/s Tx-Power:15 dBm Sensitivity=1/3 Retry min limit:7 RTS thr:off Encryption key:0000-0000-0000-0000-0000-0000-00 Security mode:open Power Management:off Link Quality=52/100 Signal level=34/100 Noise level=0/100 Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0 root@ubuntu2:/home/benjamin # dhclient wlan0 Internet Systems Consortium DHCP Client V3.0.1 Copyright 2004 Internet Systems Consortium. All rights reserved. For info, please visit http://www.isc.org/products/DHCP sit0: unknown hardware address type 776 sit0: unknown hardware address type 776 Listening on LPF/wlan0/00:c0:49:55:91:0e Sending on LPF/wlan0/00:c0:49:55:91:0e Sending on Socket/fallback DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 5 DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6 DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13 DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 20 DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 17 No DHCPOFFERS received. No working leases in persistent database - sleeping. EDIT: På tide med litt søvn tror jeg, tidlig på jobb imorgen! Takk for hjelpen sålangt Endret 29. august 2005 av benjamin84 Lenke til kommentar
objorkum Skrevet 30. august 2005 Del Skrevet 30. august 2005 Det er her snakk om å installere kildekoden til kjerna. Det skal kunne gjerast enkelt med apt-get / Synaptic Køyrer "dessverre" ikkje Ubuntu, så kan ikkje hjelpe deg med namn på pakke. Har lagt inn Ubuntu i VMware, og funne ut at pakken ein treng i Ubuntu for å få kildekoden til kjerna er: linux-headers-i386 Så om ein legg den inn med synaptic skal ein kunne kompilere modular utan problem. Lenke til kommentar
escariot Skrevet 30. august 2005 Del Skrevet 30. august 2005 (endret) Du kan vel kanskje prøve det jeg har gjort også.. skader vel ikke etter alt styret du allerede har hatt.. sudo gedit /etc/network/interfaces # så ut alle linjer som har med eth0/eth1 å gjøre, sett gateway (eller hva det nå står.. default?) til wlan0 og sett hotplug fra eth0 til wlan0. Dette funket for meg iallefall. Grunnen? tja.. jeg tror at maskinen min/ubuntu ikke klarte å håndtere (eller konflikt mellom noe) trådfast og trådløst nettverk på en gang. -Escariot ps. med forbehold om at jeg ikke husker instillingene og banen i/til interfaces korrekt. edit: tilleggsinfo.. Slik ser min interfaces ut, men denne er ubuntu breezy (hvor det trådløse kortet mitt ble eth1): # This file describes the network interfaces available on your system # and how to activate them. For more information, see interfaces(5). # The loopback network interface auto lo iface lo inet loopback # This is a list of hotpluggable network interfaces. # They will be activated automatically by the hotplug subsystem. mapping hotplug script grep map eth1 # The primary network interface #iface eth0 inet dhcp iface eth1 inet dhcp wireless-essid 3Com auto eth1 Endret 30. august 2005 av escariot Lenke til kommentar
benjamin84 Skrevet 30. august 2005 Forfatter Del Skrevet 30. august 2005 Det er her snakk om å installere kildekoden til kjerna. Det skal kunne gjerast enkelt med apt-get / Synaptic Køyrer "dessverre" ikkje Ubuntu, så kan ikkje hjelpe deg med namn på pakke. Har lagt inn Ubuntu i VMware, og funne ut at pakken ein treng i Ubuntu for å få kildekoden til kjerna er: linux-headers-i386 Så om ein legg den inn med synaptic skal ein kunne kompilere modular utan problem. Takker Den drivern der er nok siste utvei nå, men kjekt å vite uansett Escariot: Skal forsøke, skader som du sier ikke maskinen skal formateres uansett etter all rotingen i console som root Lenke til kommentar
