Trenger hjelp med Xbox registreringsystem
Hei jeg driver å lager et registreringssytem for en xbox-side. Har noen ting jeg lurer litt på:
  • Hvis man skal skjekke om en radiobox er checked, eller unchecked å få det inn i mysql. Hvordan gjør man det da?
  • Hvordan ville dere lagt opp tabellstrukturen i mysql?
Dette er fila join.html
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<title>Registreringsskjema XAN</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<link href="cssstylesheets/xandesign.css" rel="stylesheet" type="text/css">
</head>
<body>
	<form name="registrering" id="registrering" method="post" action="registrer.php">
		<h2>Ønsket Brukernavn :</h2>
			<acronym title="(min3, max20)"><input name="brukernavn" type="text" id="brukernavn" size="25" maxlength="20"></acronym>
		<h2>Ønsket Passord :</h2>
			<acronym title="(min3, max20)"><input name="passord" type="password" id="passord" size="25" maxlength="20"></acronym>
		<h2>Bekreft passord :</h2>
			<input name="bekreftpass" type="password" id="bekreftpass" size="25" maxlength="20" />
		<h2>Gametag x-link kai :</h2>
			<input name="tagxlk" type="text" id="tagxlk" size="25">
		<h2>Gametag xbconnect :</h2>
			<input name="tagxbc" type="text" id="tagxbc" size="25">
		<h2>Har egen Xbox :</h2>
		<label><input type="radio" name="xbox" value="ja">Ja</label>
		<label><input type="radio" name="xbox" value="nei">Nei</label>
		<acronym title="(headsett til xbox)">Har Xbox Live Comunicator:</acronym>
		<label><input type="radio" name="xboxxlc" value="ja">Ja</label>
		<label><input type="radio" name="xboxxlc" value="nei">Nei</label>
		<h2><acronym title="kb/s ut ikke inn">Hvilken opplastningshastighet :</acronym></h2>
			<input name="opplast" type="text" id="opplast" size="10">
		<h2>Land :</h2>
			<select name="land" id="land">
				<option>Land</option>
				<option value="nor">Norge</option>
				<option value="sve">Svergie</option>
			</select>
		<h2>By / Tettsted :</h2>
			<input name="by" type="text" id="by" size="25">
		<h2>Alder :</h2>
			<select name="alder" id="alder">
				<option>Alder</option>
				<option value="16">16 - 18</option>
				<option value="18">18 - 20</option>
				<option value="20">20 - 25</option>
				<option value="25">25 - 30</option>
				<option value="30">30 +</option>
			</select>
		<h2>E-Post adresse :</h2>
			<input name="email" type="text" id="email" size="40">
		<h2>Ønsker E-Post adresse hos XAN :</h2>
		<label><input type="radio" name="epostxan" value="ja">Ja</label>
		<label><input type="radio" name="epostxan" value="nei">Nei</label>
		<h2>Hvilken Xan clan ønsker du :</h2>
		<h3>XAN FPS:</h3>
		<acronym title="halo 2 , ghost recon 2, rainbow six"><input name="xanfps" type="radio" value="xanfps"></acronym>
		<h3>XAN RT:<h3>
		<acronym title="forza, rallisport C 2, midnight C 3"><input name="xanrt" type="radio" value="xanrt">
		<input name="registrer" type="submit" id="registrer" value="Send Skjema">
		<input name="reset" type="reset" id="reset" value="Reset Skjema">
	</form>
</body>
</html>
Og Dette er registrer.php
<?php
include("config.php");
$brukernavn = $_POST['brukernavn'];
$brukernavn = htmlspecialchars($brukernavn);
$passord = $_POST['passord'];
$passord = htmlspecialchars($passord);
if($query = @mysql_query("INSERT INTO brukere (brukernavn, passord) VALUES ('$brukernavn', '$passord')")or die(mysql_error())) {
echo "Registreringen skjedde vellykket";
else {
echo 'Det skjedde en feil i registreringen. Vennligs gå tilbake og prøv på nytt.';
Sliter litt nå. Takker for all hjelp.
Endret av ett
Jeg har noen feil i registrer.php, men jeg finner dem ikke. Får denne feilmeldingen:
You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 'by, alder, email, epostxan, xanfps, xanrt) VALUES ('', '', '',
Dette er registrer.php:
<?php
$bekreftpass = $_post['bekreftpass'];
$bekreftpass= htmlspecialchars($bekreftpass);
$xbox = $_POST['xbox'];
$xbox = htmlspecialchars($xbox);
$tagxlk = $_POST['tagxlk'];
$tagxlk = htmlspecialchars($tagxlk);
$tagxbc = $_POST['tagxbc'];
$tagxbc = htmlspecialchars($tagxbc);
$xboxxlc = $_POST['xboxxlc'];
$xboxxlc = htmlspecialchars($xboxxlc);
$opplast = $_POST['opplast'];
$opplast = htmlspecialchars($opplast);
$land = $_POST['land'];
$land = htmlspecialchars($land);
$by = $_POST['by'];
$by = htmlspecialchars($by);
$alder = $_POST['alder'];
$alder = htmlspecialchars($alder);
$email = $_POST['email'];
$email = htmlspecialchars($email);
$epostxan = $_POST['epostxan'];
$epostxan = htmlspecialchars($epostxan);
$xanfps = $_POST['xanfps'];
$xanfps = htmlspecialchars($xanfps);
$xanrt = $_POST['xanrt'];
$xanrt = htmlspecialchars($xanrt);
if($query = @mysql_query("INSERT INTO xbox (brukernavn, passord, bekreftpass, xbox, tagxlk, tagxbc, xboxxlc, opplast, land, by, alder, email, epostxan, xanfps, xanrt) VALUES ('$brukernavn', '$passord', '$bekreftpass', '$xbox', '$tagxlk', '$tagxbc', '$xboxxlc', '$opplast', '$land', '$by', '$alder', '$email', '$epostxan', '$xanfps', '$xanrt')")or die(mysql_error())) {
else {
Takk for hjelpen hittil. :thumbup:
Endret av ett
Byttet ut 'by' med `by` men det funket dårlig. Får en ny feilmelding nå.
Warning: shell_exec(): Cannot execute using backquotes in Safe Mode in /free1go/j/u/www.abc.def/prosjekt/registrer.php on line 25
EDIT: Fant feilen. Hadde byttet ut by, med sted i databasen for å unngå problemet, men glemte å endre det i registrer.php. :w00t:
Endret av ett
Hvor bruker du shell_exec?
Du får akkurat samme MySQL-feilmelding.
skal være
INSERT INTO xbox (brukernavn, passord, bekreftpass, xbox, tagxlk, tagxbc, xboxxlc, opplast, land, `by`, alder, ema
Trenger litt hjelp med å sikre admin-sidene. Det jeg ønsker å gjøre er å ha et bestemt brukernavn/passord som er det eneste som kommer inn. Forslag til å gjøre dette?
Admin logger inn fra admin.php til /admin/index.php.
Mitt forslag er å gjøre dette med sessions/cookies siden man logger inn rett før. Noen sikkerhetshull der? evt. andre metoder?
Endret av ett
Sikkerheten er ikke VELDIG viktig. Jeg har funnet et loginscript som virker veldig sikkert. Har modifisert koden og brukt den i systemet mitt. Det funker bra. Får en parse eror på registrer.php. Finner ikke feilen, men har antagligvis sett meg ganske blind på koden. :hm:
Parse error: parse error, unexpected $ in /free1go/j/u/www.juventusnorge.1go.dk/utvikling/system/registrer.php on line 109
Registrer.php
<?php
require('config.php');
if (isset($_POST['registrering'])) { // Hvis formen er sendt,
/* skjekk om de har fylt feltene de skulle,
at passordene stemmer og at brukernavnet
ikke allerede er tatt. */
if (!isset($_POST['brukernavn'], $_POST['passord'], $_POST['bekreftpass'], $_POST['email'])); {
// Skjekk om brukernavnet finnes i databasen.
if (!get_magic_quotes_gpc()) {
$_POST['brukernavn'] = addslashes($_POST['brukernavn']);
$name_check = $db_object->query("SELECT brukernavn FROM xbox WHERE username = '".$_POST['brukernavn']."'");
if (DB::isError($name_check)) {
die($name_check->getMessage());
$name_checkk = $name_check->numRows();
if ($name_checkk != 0) {
die('Brukernavnet '.$_POST['uname'].' er allerede i bruk.');
// skjekk om passord er like
if ($_POST['passord'] != $_POST['bekreftpass']) {
die('Passordene var ikke like.');
// skjekk email format
if (!preg_match("/.*@.*..*/", $_POST['email']) | preg_match("/(<|>)/", $_POST['email'])) {
die('Ugyldig epost-adresse.');
if (!preg_match("/.*@.*..*/", $_POST['msn']) | preg_match("/(<|>)/", $_POST['msn'])) {
die('Ugyldig msn-adresse.');
// skjekk ingen html
$_POST['brukernavn'] = strip_tags($_POST['brukernavn']);
$_POST['passord'] = strip_tags($_POST['passord']);
$_POST['webside'] = strip_tags($_POST['webside']);
$_POST['sted'] = strip_tags($_POST['sted']);
if ($_POST['webside'] != '' & !preg_match("/^(http|ftp):///", $_POST['webside'])) {
$_POST['webside'] = 'http://'.$_POST['webside'];
// passord krypteres
$_POST['passord'] = md5($_POST['passord']);
$_POST['bekreftpass'] = md5($_POST['bekreftpass']);
$_POST['passord'] = addslashes($_POST['passord']);
$_POST['email'] = addslashes($_POST['email']);
$_POST['webside'] = addslashes($_POST['webside']);
$_POST['sted'] = addslashes($_POST['sted']);
$insert = "INSERT INTO xbox (id, brukernavn, passord, bekreftpass, xbox, tagxlk, tagxbc, xboxxlc, opplast, land, sted, alder, email, epostxan, xanfps, xanrt, webside, msn
VALUES (
'".$_POST['id']."',
'".$_POST['brukernavn']."',
'".$_POST['passord']."',
'".$_POST['bekreftpass']."',
'".$_POST['xbox']."',
'".$_POST['tagxlk']."',
'".$_POST['tagxbc']."',
'".$_POST['xboxxlc']."',
'".$_POST['opplast']."',
'".$_POST['land']."',
'".$_POST['sted']."',
'".$_POST['alder']."',
'".$_POST['email']."',
'".$_POST['epostxan']."',
'".$_POST['xanfps']."',
'".$_POST['xanrt']."',
'".$_POST['webside']."',
'".$_POST['msn']."'";
$add_member = $db->query($insert);
if (DB::isError($add_member)) {
die($add_member->getMessage());
$db->disconnect();
<h2>Registrert</h2>
<p>Du er nå registrer og kan logge inn. <a href="login.php" title="Login">logg inn</a>.</p>
<?php
Sikkert bare en liten tullefeil. Tusen takk for all hjelp hittill. :thumbup:
Endret av ett
