ACC65 Skrevet 3. august 2005 Forfatter Del Skrevet 3. august 2005 asbjorn@IET:~/zc030x$ make Building ZC030X driver for 2.5/2.6 kernel. PLEASE IGNORE THE "Overriding SUBDIRS" WARNING Remember: you must have read/write access to your kernel source tree. make -C /lib/modules/`uname -r`/build SUBDIRS=/home/asbjorn/zc030x modules make[1]: Går til katalog '/lib/modules/2.6.10-5-386/build' make[1]: *** Ingen regel til at skabe mål 'modules'. Stop. make[1]: Forlader katalog '/lib/modules/2.6.10-5-386/build' make: *** [default] Fejl 2 ....har laget mappen.... Lenke til kommentar
ACC65 Skrevet 3. august 2005 Forfatter Del Skrevet 3. august 2005 asbjorn@IET:~/zc030x$ ls -l /usr/src totalt 30568 -rw-r--r-- 1 root root 283283 2005-04-05 00:44 fglrx-kernel-source.tar.gz -rw-r--r-- 1 root root 30967556 2005-04-06 19:47 kernel-source-2.4.27.tar.bz2 drwxr-xr-x 7 root root 4096 2005-07-15 01:25 rpm de to øverste er røde, mens rpm er blå Lenke til kommentar
objorkum Skrevet 3. august 2005 Del Skrevet 3. august 2005 asbjorn@IET:~/zc030x$ ls -l /usr/src totalt 30568 -rw-r--r-- 1 root root 283283 2005-04-05 00:44 fglrx-kernel-source.tar.gz -rw-r--r-- 1 root root 30967556 2005-04-06 19:47 kernel-source-2.4.27.tar.bz2 drwxr-xr-x 7 root root 4096 2005-07-15 01:25 rpm de to øverste er røde, mens rpm er blå Der har du problemet. Når du la inn kernel-source la du inn for kernel 2.4.27. Køyr denne kommandoen: sudo apt-cache search kernel-source Så skal eg fortelje kva for pakke du skal legge inn. Lenke til kommentar
ACC65 Skrevet 3. august 2005 Forfatter Del Skrevet 3. august 2005 asbjorn@IET:~$ sudo apt-cache search kernel-source avm-fritz-kernel-source - AVM Fritz! binary kernel module source fglrx-kernel-source - ATI binary kernel module source cpad-kernel-source - Source for the Synaptics cPad driver freeswan - IPSEC utilities for FreeSWan kernel-patch-2.4-lids - LIDS Kernel Patch kernel-patch-debian-2.4.27 - Debian patches to Linux 2.4.27 kernel-source-2.4.27 - Linux kernel source for version 2.4.27 with Debian patches kernel-tree-2.4.27 - Linux kernel source tree for building Debian kernel images lidstools-2.4 - LIDS Admintool nvidia-kernel-source - NVIDIA binary kernel module source oprofile - system-wide profiler for Linux systems wacom-kernel-source - Source for the wacom binary modules wacom-tools - Utilities for wacom tablets and other hid devices W: Couldn't stat source package list http://backports.ubuntuforums.org hoary-extras/main Packages (/var/lib/apt/lists/backports.ubuntuforums.org_backports_dists_hoary-extras_main_binary-i386_Packages) - stat (2 Ingen slik fil eller filkatalog) W: Couldn't stat source package list http://backports.ubuntuforums.org hoary-extras/universe Packages (/var/lib/apt/lists/backports.ubuntuforums.org_backports_dists_hoary-extras_universe_binary-i386_Packages) - stat (2 Ingen slik fil eller filkatalog) W: Couldn't stat source package list http://backports.ubuntuforums.org hoary-extras/multiverse Packages (/var/lib/apt/lists/backports.ubuntuforums.org_backports_dists_hoary-extras_multiverse_binary-i386_Packages) - stat (2 Ingen slik fil eller filkatalog) W: Couldn't stat source package list http://backports.ubuntuforums.org hoary-extras/restricted Packages (/var/lib/apt/lists/backports.ubuntuforums.org_backports_dists_hoary-extras_restricted_binary-i386_Packages) - stat (2 Ingen slik fil eller filkatalog) ....tror jeg må finne nye servere til apt-get Lenke til kommentar
objorkum Skrevet 3. august 2005 Del Skrevet 3. august 2005 Hm, der ligg ikkje den du skal ha. Tydeleg at du ikkje får lista opp alle. Kvifor ikkje bruke standard sources.list? Lenke til kommentar
ACC65 Skrevet 4. august 2005 Forfatter Del Skrevet 4. august 2005 (endret) asbjorn@IET:~$ sudo apt-cache search kernel-source avm-fritz-kernel-source - AVM Fritz! binary kernel module source fglrx-kernel-source - ATI binary kernel module source cpad-kernel-source - Source for the Synaptics cPad driver freeswan - IPSEC utilities for FreeSWan kernel-patch-2.4-lids - LIDS Kernel Patch kernel-patch-debian-2.4.27 - Debian patches to Linux 2.4.27 kernel-source-2.4.27 - Linux kernel source for version 2.4.27 with Debian patche kernel-tree-2.4.27 - Linux kernel source tree for building Debian kernel images lidstools-2.4 - LIDS Admintool nvidia-kernel-source - NVIDIA binary kernel module source oprofile - system-wide profiler for Linux systems wacom-kernel-source - Source for the wacom binary modules wacom-tools - Utilities for wacom tablets and other hid devices W: Couldn't stat source package list http://backports.ubuntuforums.org hoary-extsts_hoary-extras_main_binary-i386_Packages) - stat (2 Ingen slik fil eller filka W: Couldn't stat source package list http://backports.ubuntuforums.org hoary-exts_dists_hoary-extras_universe_binary-i386_Packages) - stat (2 Ingen slik fil ell W: Couldn't stat source package list http://backports.ubuntuforums.org hoary-extrts_dists_hoary-extras_multiverse_binary-i386_Packages) - stat (2 Ingen slik fil W: Couldn't stat source package list http://backports.ubuntuforums.org hoary-extrts_dists_hoary-extras_restricted_binary-i386_Packages) - stat (2 Ingen slik fil asbjorn@IET:~$ sudo apt-cache search kernel-source avm-fritz-kernel-source - AVM Fritz! binary kernel module source fglrx-kernel-source - ATI binary kernel module source kernel-source-2.4.27 - Linux kernel source for version 2.4.27 with Debian patches asbjorn@IET:~$ Dette var med standard sources.list... ....jeg finner trolig den riktige kernel-source på www.apt-get.org ..hvilken er det vi leter etter? Endret 4. august 2005 av ACC65 Lenke til kommentar
objorkum Skrevet 4. august 2005 Del Skrevet 4. august 2005 Nei, du bør bruke ein offisiell pakke. Lenke til kommentar
objorkum Skrevet 4. august 2005 Del Skrevet 4. august 2005 Hmm, kva med: sudo apt-cache search linux-source ? Lenke til kommentar
ACC65 Skrevet 4. august 2005 Forfatter Del Skrevet 4. august 2005 asbjorn@IET:~$ sudo apt-cache search linux-source linux-patch-ubuntu-2.6.10 - Ubuntu patches to Linux 2.6.10 linux-source-2.6.10 - Linux kernel source for version 2.6.10 with Ubuntu patches Lenke til kommentar
objorkum Skrevet 4. august 2005 Del Skrevet 4. august 2005 asbjorn@IET:~$ sudo apt-cache search linux-source linux-patch-ubuntu-2.6.10 - Ubuntu patches to Linux 2.6.10 linux-source-2.6.10 - Linux kernel source for version 2.6.10 with Ubuntu patches sudo apt-get install linux-source-2.6.10 Så prøv make Lenke til kommentar
ACC65 Skrevet 4. august 2005 Forfatter Del Skrevet 4. august 2005 den samme feilmeldingen kom opp enda en gang.... .... jeg tror jeg vet hva som er problemet... Jeg tror jeg må oppdatere kernelen... ...hvordan gjør man det? ..har jeg allerede gjort det, da ma jeg vel starte på nytt.. Lenke til kommentar
objorkum Skrevet 4. august 2005 Del Skrevet 4. august 2005 Nei det må du ikkje. ls -l /usr/src Lenke til kommentar
ACC65 Skrevet 4. august 2005 Forfatter Del Skrevet 4. august 2005 asbjorn@IET:~/zc030x$ ls -l /usr/src totalt 67164 -rw-r--r-- 1 root root 283283 2005-04-05 00:44 fglrx-kernel-source.tar.gz -rw-r--r-- 1 root root 30967556 2005-04-06 19:47 kernel-source-2.4.27.tar.bz2 -rw-r--r-- 1 root root 37431650 2005-06-24 22:06 linux-source-2.6.10.tar.bz2 drwxr-xr-x 7 root root 4096 2005-07-15 01:25 rpm nå er de tre øverste røde, og rpm er blå Lenke til kommentar
LessThanJake Skrevet 4. august 2005 Del Skrevet 4. august 2005 instaler linux-kernel-headers og linux-headers Lenke til kommentar
objorkum Skrevet 4. august 2005 Del Skrevet 4. august 2005 (endret) Fargane er ikkje det nøye med. Kan du nett ta: ls -l /lib/modules/2.6.10-5-386/build EDIT: Og gjer som LessThanJake sa. Endret 4. august 2005 av objorkum Lenke til kommentar
ACC65 Skrevet 4. august 2005 Forfatter Del Skrevet 4. august 2005 (endret) asbjorn@IET:~/zc030x$ ls -l /lib/modules/2.6.10-5-386/build totalt 0 en annen ting.. innne på kontroll senter står det at min maskin er 686... skal jeg da velge linux-headers686? eller 383?, eller bare linux-headers?[/code] Endret 4. august 2005 av ACC65 Lenke til kommentar
objorkum Skrevet 4. august 2005 Del Skrevet 4. august 2005 asbjorn@IET:~/zc030x$ ls -l /lib/modules/2.6.10-5-386/build totalt 0 en annen ting.. innne på kontroll senter står det at min maskin er 686... skal jeg da velge linux-headers686? eller 383?, eller bare linux-headers?[/code] 386, sidan kernelen er det. Lenke til kommentar
LessThanJake Skrevet 4. august 2005 Del Skrevet 4. august 2005 samme som du har bak linux-image. Lenke til kommentar
ACC65 Skrevet 4. august 2005 Forfatter Del Skrevet 4. august 2005 okei;) ..skriver jeg make kommer fortsatt feilmeldingen opp.. Lenke til kommentar
