Småprat om/rundt WoW
Fikk en dags bann på elitistjerks.com for å poste dette:
"i did some basic totaly awfull math and figured out that the 4/31/6 specc mgith be better as the 30% disease dmg is a boost. while the Blood Tap comes down to HOW you use it. "
Elitist much?
Elendig språkforråd, forferdelig tegnsetning og sannsynligvis ingen matte lagt til i posten. Jeg tror jeg teller ti regelbrudd ifølge ElitistJerks-retningslinjer bare der, og det der er to setninger.
Jeg har postet noen innlegg på ElitistJerks selv oppgjennom årene, og har du ikke noe helt nødvendig å si som du i tillegg kan backe opp med theorycrafting så burde du unngå å poste.
Jeg telte to:
All posters are to make an effort to communicate clearly. In particular, all posts should be made in a reasonable approximation of proper English. We realize that a significant number of you are not native speakers, and we do not expect perfection: merely effort. Please obey basic rules of capitalization and punctuation, avoid chatroom abbreviations ("lol", "imo", "u", and the like), and pay at least minimal attention to sentence and paragraph structure. This includes not starting a new paragraph for each sentence.
Do not post unless you have something new and worthwhile to say. Do not bump, quote for truth, cross-post, or post only to say thanks. We don't want to hear your funny story about something that happened in your raid last night, your baseless speculation is unproductive, and your idea for a new ability really isn't that interesting. We don't care what gear you are hoping to get or just received. If you have an idea you'd like to share with the community, support it with analysis, testing, or both that indicates you've put some thought into it. (Note: Posting of a new untested spec falls under this rule, unless you have done the grunt work and have information to support your amazing new spec don't even bother posting it here.)
men det var nok til "ban", sidene der er for pro'z!
Synes du skal bare holde deg til "read", og ikke "write".
Jævlig marksman hunter skal critte a. Tar 24k+ i lvl 81. Lurer på hva jeg tar i 85 da :dribble:
Critter rundt 50k med Aimed shot og rundt 35k med Chimera med 350ilvl.
Det kan vel ikke stemme?
Med alt av procs og buffs på min arms warrior (ilvl 340), så critter jeg maks 30k.
med min fury warrior (ilvl 338) så critter jeg 44k+25k med Raging Blow, 36k med slam og 36k med bloodthirst. Dette rett etter hverandre.
Alt skal bevises med formler og statistikk. Lese hypoteser eller noe man tenker over tilfeldig hører ikke hjemme der..
Akkurat. Skal jeg gå på en messe for fysikk og holde tale der jeg sier " Jeg gjorde litt forferdelig matte på sorte hull teorien til Hawking, og jeg kom frem til at den ikke stemmer. " da?
Det hadde nok tatt seg ut. Problemet med posten som ble postet der er at det kan godt hende den stemmer, men uten noe som helst av bevis så blir det bare en tullepost som ikke bidrar til noe som helst.
Jeg skjønner dem godt. Om de ikke holder en høy standard for hva folk skal kunne poste der så ender forumet opp som arenajunkies hvor det nå er fullt av tull.
edit: Sånn forøvrig. Jeg fikk gjort BWD i går som Disc, og det var heeerlig å spille det speccet i PvE nå.
Endret av Detectable
Elitist Jerks er stedet for hundre prosent pålitelig theorycrafting, styrt av et samfunn der folk de ikke vil ha der ikke har noe de skulle ha sagt. "Awful math" er ikke en pålitelig kilde, og ingen får noe ut av det da de som bedriver theorycrafting vil ha det så optimalt som mulig. Unødvendighet gir ban, det er en grunn til at det er sykt få tråder på forumet.
Ja, jeg er kjempefornøyd med patchforandringene. DS treffer og healer mye mer, og det er kjempefett spesielt når blood shield stacker. Fire charges på Bone Shield sier jeg heller ikke nei til.
Hei! :)
Jeg har plukket opp huntern min igjen, og lurer på om noen med peiling kan ta en titt og se hva jeg bør endre på av utstyr osv. Jeg har ikke noen formening om hvor man bør ligge i stats på lvl 74, og setter pris på noen meninger. Jeg spiller BM og driver stort sett med PvE.
Armory: Livtrase
Agility. Siden du bare skal levle gjør det ikke noe om gearet ikke er knakendes bra. Bare få så mye agility som mulig, 1 agility er det samme som 2 attack power og litt crit.
Når det gjelder spec har jeg for lengst gitt opp i å overbevise folk om dette å bytte ut av BM og SV, men marksman er helt klart det beste valget etter lvl 65ish, dette grunnet Rapid Recouperation og Rapid killing.
Endret av Kraziebone
