Småprat om/rundt WoW
Er det bare meg eller er det litt lang cooldown på [ultra safe transporter - Gadzetzan] ? o.O
6720633[/snapback]
Bruker du en egen cooldown timer?
Lol du er vel en dårlig ingeniør da, regner med at det er du som har lagd den og da har man vel ikke andre å skylde på...
6720882[/snapback]
....du kan ikke være "dårlig" engineer på wow.
Bruker cooldown count til bongos.
Får du ikke brukt den på 50 d heller ?
4t er jo normalt.
6722269[/snapback]
På tooltippen står det 4 timer, så tror det bare er no feil med "tiden som vises" av cooldown counten.
EDIT: Nå er cooldownen ferdig, eller så går 50 dager i Blizzards verden velidg fort.
Endret av johnny Bravo
Skjer vel ikke så mye spennende der vel? :hmm:
Patch 1.11.2
Click here to view the features for patch 1.11: Shadow of the Necropolis
General
* Fixed an issue where players were still being disconnected in 1.11.0 when trying to log back in within 20 seconds of a client crash.
* Fixed an issue where it was possible to place special bags inside one another.
* Applied a fix where players reported that they are sometimes unable to resurrect at their corpse.
* Fixed a graphical error where when viewing a character from a second computer, a player who had his weapons sheathed did not appear to have any weapons on his side or back.
* Fixed an issue where a player received a fatigue bar after a disconnection occurred during a flight path over deep water.
* The Looking For Group channel is now defaulted off. Players will need to join the channel to access it. (/join LookingForGroup)
* Fixed an issue where temporary weapon enhancements such as poisons would not persist after zoning or logging.
Druids
* The tool tip for the talent Omen of Clarity now reflects its new duration of 10 minutes.
* Fixed an issue where players with the Heart of the Wild talent were losing health each time they shifted to Bear Form or Dire Bear Form.
* Fixed an issue where players with the Furor talent were not staying in combat mode when shifting to bear form and were losing the extra rage generated.
Hunters
* Players are no longer able to animate emotes while using Feign Death.
Paladins
* Seal of Righteousness will now benefit properly from wizard oil and other effects which give bonus damage against specific creature types.
* Fixed a bug where sometimes casting a spell immediately after a swing would prevent Seal of Command from triggering.
Priests
* Fixed an error where Priests in Spirit of Redemption form did not benefit from plus to healing items.
* Touch of Weakness will now work again when you have Power Word:Shield active on yourself.
Warriors
* Fixed an issue where the Improved Charge talent was incorrectly increasing the amount of rage generated by Charge.
Items
* Fixed an issue where the Undead female's ears clipped through the item "Polar Helmet."
* Fixed several graphical anomalies with a female Troll wearing Dreadnaught armor.
* Fixed an issue where the trinket "Spectral Essence" was not working inside of the castle in Caer Darrow. This was preventing players from seeing Magistrate Marduke and starting the quests he gives.
Professions
* Fixed an error that if you try to create a Soul Shard bag while you have one equipped the materials used for the creation of the bag are consumed and the bag is placed in the inventory queue.
Raids and Dungeons
* Fixed an error where Necro Knight Guardians in Naxxramas were sometimes causing players to crash when they cast their Blink ability.
Battlegrounds
* Fixed an area within Warsong Gulch where a person could get stuck and was no longer targetable.
* Fixed an issue where sometimes a queued player can't enter a new battleground.
User Interface
* Using /chatwho for the Looking for Group channel should no longer disconnect players from the server.
* Fixed an issue where the Guild Recruitment channel option could not be enabled.
* Fixed an issue where the use of "Show Target of Target" feature on a friendly target overlapped the fifth buff, making it difficult to see.
* Fixed an error where player colored debuff icons were not displaying their correct color.
* Fixed an error where negative effects were not causing party player portraits to pulse the effect color as indicated in the 1.11.0 patch notes.
Mac
* Fixed a bug in 3D sound positioning that would occur in various situations, such as leveling up or standing above a body of water.
Her, derimot:
Cross-Realm Battlegrounds
For the first time in the history of World of Warcraft, you will be able to face off against players from other realms in the Battlegrounds. PvP Battlegrounds link Alterac Valley, Warsong Gulch, and Arathi Basin so that players from several realms will be combined into one huge matchmaking pool. Replenish your mana, sharpen your blades, and get ready for some brand-new challengers!
World PvP
The stage is set for intense, objective-based land battles as Horde and Alliance vie for control over important strategic positions and resources around Azeroth. Head out for Silithus and Eastern Plaguelands to engage the enemy on the field!
General
* Threat Reduction Effects
o This system has been redesigned to eliminate inconsistency in how the effects work. Previously, some were additive (for example: 30% reduction + 20% reduction = 50% reduction) while others were multiplicative (30% reduction and 20% reduction made 44% reduction, from 0.7*0.8). They are now all multiplicative. This also prevents unpredictable behavior when the total reduction percentage was equal to or greater than 100%.
* Haste and Slow effects
o Previously Haste and Slow effects worked inconsistently, with spells working differently from weapons, and hastes and slows not acting as inverses of each other. We have revised the system so that all haste and slow effects work the same way, and haste and slow percentages of the same magnitude perfectly cancel each other out (30% haste and 30% slow combine to no change). As a result, we had to change the tooltip numbers on all spell haste effects, and on all melee and range slow effects. The numbers in the tooltips are different, but the game functionality is unchanged (other than slight rounding errors). Those tooltips that changed will now display larger numbers than they used to display. Conceptually, haste values indicate how much more of that activity you can perform in a given time. 30% melee haste means 30% more swings in a given time. Slow values indicate how much longer an activity takes to complete. 30% slow means an action takes 30% longer to finish.
* The deserter debuff will now continue to expire even while you are offline.
Druids
* Barkskin: The tooltip has been changed to 25% due to the haste effect change.
* Ferocious Bite: The Book of Ferocious Bite (Rank 5) now drops somewhere in the world.
* Furor: This talent now works correctly with Cat Form again.
* Improved Shred: The discounted cost for Shred will now be displayed correctly even when you are not in Cat Form.
* Rip: Lesser potency Rips will no longer overwrite greater potency ones.
Hunters
* Spirit Bond: This ability will now be correctly reapplied when you resurrect in a battleground and your pet is polymorphed or otherwise unable to act normally.
Mages
* Arcane Missiles: It is no longer possible to cast this spell on an evading mob. In addition, the animation will now stop when the target is dead.
* Arcane Power: It is no longer possible to gain the benefit of this spell and Power Infusion at the same time by careful timing.
* Frost Armor Chilled effect: The tooltip has been changed to 25% due to the haste effect change.
* Ice Armor Chilled effect: The tooltip has been changed to 25% due to the haste effect change.
* Polymorph: This spell will now be removed when a player leaves a battleground. This prevents some bugs involving polymorph from occurring.
* Evocation will no longer be usable while silenced.
Paladins
* Divine Shield: The tooltip has been changed to 100% due to the haste effect change.
Priests
* Mind Control: The tooltip has been changed to 25% due to the haste effect change.
* Psychic Scream: This spell now uses the same resistance checks as the Warlock spell Fear.
Rogues
* Due to significant talent changes, Rogues will have all talent points refunded and can be re-spent. Training costs for all talent spell replacements have been significantly reduced.
* Eviscerate: Manual of Eviscerate (Rank 9) now drops somewhere in the world.
* Garrote: The damage from this ability has been increased approximately 50%.
* Relentless Strikes: This ability will no longer trigger when your finishing move does not hit your target.
* Sap: Enemy rogues will now always lose stealth when you Sap them.
Shaman
* Grounding Totem: This totem will no longer absorb multiple effects from Entrapment in a 10 second period.
* Windfury Totem: The weapon enchantment from this totem will now only trigger off normal melee swings. This means abilities such as Sinister Strike, Mortal Strike, and Hamstring will no longer trigger the Windfury Totem.
* Reincarnation should now display the cooldown timer when used.
* Chain Heal - After the initial target is healed, the healing effect will jump to the most damaged target (by absolute health) within range. In addition, if a raid member is the initial target it will look for valid raid targets to jump to rather than non-raid targets as a priority, making it consistent with group targeted Chain Heals.
Warlocks
* Cripple (Doomguard): The tooltip has been changed to 45% due to the haste effect change.
* Enslave Demon: The tooltip has been changed to 40% due to the haste effect change.
* Health Funnel: This spell will now work correctly on low-level enslaved demons.
* Howl of Terror: This spell now uses the same resistance checks as the Warlock spell Fear.
* Siphon Life will now properly gain a benefit from Shadow Mastery.
Warriors
* Flurry: The text on the tooltip has been corrected to indicate it triggers on all types of attacks.
* Shield Slam: This ability will sometimes no longer remove more than one beneficial effect from the target.
* Sword Specialization: This ability can no longer trigger off of itself.
Items
* +30 Spell Damage Enchantment: Fixed a bug with this enchantment which was preventing it from benefiting healing spells.
* Blade of Eternal Darkness: The triggered effect from this weapon will no longer occur when the spell being cast has its effect broken by causing damage.
* Blazefury Medallion: The triggered effect from this item will no longer break Gouge.
* Bonescythe Armor: The Eviscerate bonus will no longer trigger when your Eviscerate does not hit your target.
* Darkmoon Card- Twisting Nether: The dialog for this resurrection will now always reappear after the Spirit of Redemption effect has completed.
* Eye of the Dead: Holy Shock now interacts properly with this item.
* Ranged Elemental Damage: Our ranged combat system does not allow a ranged weapon to do a mix of Elemental (Fire, Frost, Arcane, etc.) and Physical damage. Many ranged weapons existed which were listed as doing Elemental damage and did not function properly (the damage was dealt, but was treated as Physical). All of those weapons have been changed to deliver the Elemental damage as a chance on hit effect. Hurricane was previously changed this way in 1.11. The following ranged weapons are also fixed in 1.12: Bow of Searing Arrows, Dwarven Hand Cannon, Heartseeking Crossbow, Dark Iron Rifle, Galgann's Fireblaster, Quillshooter, Shell Launcher Shotgun, Venomstrike, and Verdant Keeper's Aim.
* Talisman of Ascendance: This item will no longer trigger from physical damage effects. In addition, if either of the buffs from the item are cancelled, they will both be cancelled.
* Zandalarian Hero Charm: Item tooltip corrected to match the effect tooltip.
* The Items that summon mounts have been changed in their color/quality. Items that summon normal mounts are now blue(superior)items and items that summon swift mounts are now purple(epic) items.
* Fixed a bug that allowed you to use items which restored health or mana while you were already full health or mana.
* Fixed a bug with the Jom Gabbar trinket which was causing it to trigger a category cooldown for a duration longer than intended.
* Fixed a bug that prevented Arcane Missiles from being able to trigger the effect of Wrath of Cenarius.
* Clarified the tooltips for the Stormshroud armor and Kalimdor's Revenge to explain that they deal Nature damage.
* Fixed a bug that caused the Blooddrenched Mask to hide a character's hair.
* Warbear leather now stacks to 20.
Professions
* Engineering: The damage from sapper charges can now be resisted. The overall DPS of the charges should not be significantly altered from what it currently is.
* Engineering: Explosive sheep do fire damage instead of physical damage.
Raids and Dungeons
* Uldaman
o Reduced the number of Shadowforge Ambushers that attack after looting the quest chest.
o Shadowforge Ambushers are no longer elite.
o The respawn of the Stone Stewards has been changed to 2 hours (from 30 minutes).
* Zul'Farrak
o The respawn of the 2 Troll/1 Basilisk patrollers should now be 2 hours.
o Reduced the damage dealt by the Sul'lithuz Abomination and Sul'lithuz Sandcrawler.
o Zul'Farrak Dead Heroes are no longer elites.
o Theka the Martyr will now only remain immune to physical damage for 30 seconds before reverting to normal.
o Antu'sul's Sul'lithuz Broodlings now only hatch 4 at a time and are significantly weaker.
o Witch Doctor Zum'rah will no longer call as many Zul'Farrak Zombies to his aid when aggroed.
o Weegli Blastfuse now has slightly more hit points.
o Antu'sul's Warden no longer attempts to knock adventurers into Antu'sul's lair.
o Sandfury Cretins who engage the party during the pyramid event are no longer able to cast shadow bolt.
* Maraudon
o Noxxious Scions will no longer spawn when you cleanse Celebrian Vines.
User Interface
* V key functionality has been improved in several ways.
o V key now shows summoned monsters (such as the gargoyles in Stratholme.)
o V key now shows both monsters and player enemies.
o V now shows enemies only (no longer shows friendly targets.)
o Shift-V now shows friendly targets only, not enemies (with a new bindable hotkey.)
o Control-V shows both friendly targets and enemy targets (with a new bindable hotkey.)
* New floating combat text has been added to the game with a number of options. You can see when you take damage, when you are healed and how much, when you acquire and lose auras and much more. You can turn on the new options in the newly revised options screen.
* The Need Before Greed and Group Loot countdown timers will now have a 3 minute countdown when there is a bind on acquire item on the corpse. This should allow a bit more time in making a decision to roll for an item.
* Automatic Quest Tracking has been added to the game and is turned on by default. Any time you advance a quest by advancing one of the requirements, the quest information will appear on your screen for 5 minutes before fading. You can turn this option off from the options screen.
* There is now a confirmation dialogue when you attempt to disband your guild.
Bug Fixes
* Fixed a bug that caused some non-combat pets to be referred to as Minions instead of Pets. Mini Diablo however has escaped this fate and will continue to be referred to as a Minion.
6722399[/snapback]
Hadde samme problemet før når eg brukte en cooldown timer, som for eksempel at eg brukte HS å så fikk en disconnect så sto det 14668 timer til CD var over. var litt irriterende :p
Bra informasjon!
Jeg lurer litt på, hva er best for priest?
Magister's settet, eller Devout settet?
Dreadmist, er det _kun_ for warlocks?
6722940[/snapback]
www.wow-loot.com
Skaff deg random blues fra DM, BRD, UBRS, Strat og Scholo. Settene -suger-.
