Ajaco Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Det morsomme er at nesten alle som er imot Ensidia ikke hadde hatt noe imot dem om de hadde vært i guilden.. Kanskje en grunn til at de ikke er i guilden, da (De som er hardcore nok til å joine i utgangspunktet, da). Lenke til kommentar
Altobelli Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Om man ser litt på historien bak Ensidia, tror jeg enhver oppegående person vil forstå hvorfor Lenke til kommentar
Slimda Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Noen tidligere eksempler:- Twins - Vashj - C'thun - Mimiron..JoL stack Har du noen faktiske bevis, eller bare følger du saueflokk-mentaliteten? Mimiron? Ok so I wanted to check numbers for real of overall healing done by JoL but I got bored after the 7th parse Anyway these are the numbers from the top 7 parses on WMO for overall healing done by JoL: First numbers are from ret pally, 2nd is from holy. first what was our numbers - Ret 748k, holy 316k, overall 1064k 1st parse: 941k (ret) + 0 (holy) = 941k 2nd parse: 570k (ret) + 480k (holy) = 1050k 3rd parse: 946k (ret) + 0 (holy) = 946k 4th parse: 1294k (ret) + 12k (holy) = 1306k 5th parse: 1000k (ret) + 0 (holy) = 1000k 6th parse: 842k (ret) + 104k (holy) = 946k 7th parse: 957k (ret) + 0k (holy) = 957k and for a special parse.... Exo 1st kill: 1000k (ret) + 344k (ret) = 1344k As these numbers show nearly all guilds have the same amount of total healing done by JoL, some holy pallys don't use JoL at all which imo is crazy on such a fight, otherwise their numbers would be as high if not higher than ours. Why do two procs show up at the same time? Im not sure tbh, maybe its a UI bug? As it definately doesnt seem to stack, the Exo parse shows that clearly since they were judging at the same time, if it stacked the 2nd ret would be much higher. No idea but its clearly not something that gives any guild an advantage. Hope that clears up this shizzle atleast but im sure more conspiracy theorys will come Kom gjerne med litt håndfaste bevis, og ikke myter. Lenke til kommentar
Christoffer99 Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Forskjellene her er mange.Ensidia sa aldri at de tok Hodir lovlig, imotsetning til hva eXo-gutta gjorde med Yogg-saron. De sa rett frem at de hentet en buff fra trash, før de tok bossen. De mailet også Blizzard med info om hva de hadde gjort, hvorfor, etc. We discovered this mechanic on a wipe, and decided to see if we could actually get it to work. The first attempt after that wipe, we realized it worked, and went with it and killed it on that attempt. We also filed a formal bug report on Blizzard's website. Fra Exodus hjemmeside De fylte også ut en bug report som ensida gjorde, men de blei fortsatt banna i 72timer, det blei ikke ensidia. Lenke til kommentar
Altobelli Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Noen tidligere eksempler:- Twins - Vashj - C'thun - Mimiron..JoL stack Har du noen faktiske bevis, eller bare følger du saueflokk-mentaliteten? Litt morsomt at disse kommenterene kommer fra deg ^ Lenke til kommentar
Ajaco Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 (endret) Noen tidligere eksempler:- Twins - Vashj - C'thun - Mimiron..JoL stack Har du noen faktiske bevis, eller bare følger du saueflokk-mentaliteten? Litt morsomt at disse kommenterene kommer fra deg ^ Hvorfor var det morsomt at det kom fra han? Stopp å gå på person, les heller det han skrev. Endret 30. juni 2009 av Ajaco Lenke til kommentar
Altobelli Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 (endret) edit Noen tidligere eksempler:- Twins - Vashj - C'thun - Mimiron..JoL stack Har du noen faktiske bevis, eller bare følger du saueflokk-mentaliteten? Mimiron? Ok so I wanted to check numbers for real of overall healing done by JoL but I got bored after the 7th parse Anyway these are the numbers from the top 7 parses on WMO for overall healing done by JoL: First numbers are from ret pally, 2nd is from holy. first what was our numbers - Ret 748k, holy 316k, overall 1064k 1st parse: 941k (ret) + 0 (holy) = 941k 2nd parse: 570k (ret) + 480k (holy) = 1050k 3rd parse: 946k (ret) + 0 (holy) = 946k 4th parse: 1294k (ret) + 12k (holy) = 1306k 5th parse: 1000k (ret) + 0 (holy) = 1000k 6th parse: 842k (ret) + 104k (holy) = 946k 7th parse: 957k (ret) + 0k (holy) = 957k and for a special parse.... Exo 1st kill: 1000k (ret) + 344k (ret) = 1344k As these numbers show nearly all guilds have the same amount of total healing done by JoL, some holy pallys don't use JoL at all which imo is crazy on such a fight, otherwise their numbers would be as high if not higher than ours. Why do two procs show up at the same time? Im not sure tbh, maybe its a UI bug? As it definately doesnt seem to stack, the Exo parse shows that clearly since they were judging at the same time, if it stacked the 2nd ret would be much higher. No idea but its clearly not something that gives any guild an advantage. Hope that clears up this shizzle atleast but im sure more conspiracy theorys will come Kom gjerne med litt håndfaste bevis, og ikke myter. Vet du egentlig hva du snakker om? C/P fra Enisidia er vanskelig Endret 30. juni 2009 av Rukk Lenke til kommentar
Slimda Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 (endret) Ikke så vanskelig å kopiere og lime inn, men jeg kommer tross alt med noe mer enn et par navn og saueflokk-uttalelser. Kom gjerne med noe større bevis. *edit* eXo-folkene var også litt kvalme... Vifte rundt med det Amerikanske flagg, samt gå rundt å si at "se på ensidia, de roper exploit, tapere!". Meh. Endret 30. juni 2009 av Slimda Lenke til kommentar
Altobelli Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Ikke så vanskelig å kopiere og lime inn, men jeg kommer tross alt med noe mer enn et par navn og saueflokk-uttalelser. Kom gjerne med noe større bevis. *edit* eXo-folkene var også litt kvalme... Vifte rundt med det Amerikanske flagg, samt gå rundt å si at "se på ensidia, de roper exploit, tapere!". Meh. Nerdragen til Ensidia siden killet til eXo har jo vært fenomenal da! Lenke til kommentar
Slimda Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Ikke så vanskelig å få kill når man har exploits, gitt. Lenke til kommentar
Altobelli Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Ikke så vanskelig å få kill når man har exploits, gitt. Vel, først skal du jo også finne exploiten da. Et argument Nihilum/Ensidia kom seg bort med flere ganger, da under navnet: 'Bra bruk av game mechanics' Lenke til kommentar
Slimda Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Du har ennå ikke kommet med eksempel på exploits de har brukt. Lenke til kommentar
Frederick_ Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Hvis jeg transfer en char til mindre andre account, får jeg alle penga mine, baggene mine, bank osv da ? Lenke til kommentar
Slimda Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Alt innenfor pengerestriksjonene Blizzard har satt. De er ganske høye for max-level karakterer, så det er ikke noe å bekymre seg ove.r Lenke til kommentar
Ajaco Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Ikke så vanskelig å få kill når man har exploits, gitt. Vel, først skal du jo også finne exploiten da. Et argument Nihilum/Ensidia kom seg bort med flere ganger, da under navnet: 'Bra bruk av game mechanics' Vel, helt ærlig så skjønner ikke jeg hvorfor folk skal rakke ned på Ensidia, siden de "stacket" Judgement of Light på Mimiron. Først av alt, om man har 3-4 paladins i et raid, er det vel naturlig at omlag halvparten judger light, uavhengi om den stacker eller ikke. Og om man da skal begynne å bruke DET som er argument for at de exploitet Mimiron, så blir det bare for dumt. Hva med alle andre encounters, da? Hva med folka som har stacket JoL uten å vite om det? Har de også exploitet da? Dessuten så stacker det mest sansynlig ikke, ifølge teksten Slimda linket til. Folkens, kan dere ikke bare la de få gleden av å ha en worldfirst, istedet for å finne på idiotiske grunner til at de ikke var et cleant kill? Lenke til kommentar
Slimda Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Så, et innlegg fra "Kungen". Guildleder i Ensidia ellerno. C'thun (Know anything about a disgusting Oozling Kungen?): We do not? But it seems you guys do, did you use that to exploit for what? Never even heard of it until now. We as most other top guilds had been working on C'thun for over 2 months. Then it got hotfixed and we and Millenium and several other top guilds killed it that day. The boss was just made easy. That's all. Edit: There is no damn oozeling on his bar lol, It's a normal macro for god knows what. Nessaj is known to be 100% macro and no skills. Lady Vashj.....Respawns? Yes that's a known bug, it wasn't intended as several screen shots proved and it was posted on our front page that a bug had happened and we mailed blizzard right away to get it fixed. Twins...No video from first kill Kungen? Sat on a torch? Fyi there is a video of our first kill and it's been released. It shows that we were the FIRST guild to figure out the ledge strategy and that's why we killed it first. Once other guilds figured it out they managed to kill it as well. Hodir....Flower power? Yes we used it and we also posted that we did on our web page. The reason for us doing it you can read on our news. Fyi using flower power actually made the encounter harder since you had to fight Hodir + 1 extra pack.. Mimiron...JoL stacking There is a video and there are also wws logs... Anything else you guys wanna make up? Er vel ikke så mye mer å nevne da? Lenke til kommentar
Altobelli Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Du har ennå ikke kommet med eksempel på exploits de har brukt. Lady V: "A priest named "Lewt" or something, who was raiding with Nihilum at the time and delivered the Shadow Word: Death that killed Vashj said a long time ago that they intentionally exploited a bug. Now I know they deny this, but when the guy who actually delivered the killing blow says they exploited and no one else could kill Vashj for such a long time after, it really makes you wonder" C'thun: "Summon Disgusting Oozeling X amount of times to clear out Debuffs stacked on you. When inside stomach, debuff gets stacked that will kill you rather quickly if it stacked high enough." Lenke til kommentar
Altobelli Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Så, et innlegg fra "Kungen". Guildleder i Ensidia ellerno. C'thun (Know anything about a disgusting Oozling Kungen?): We do not? But it seems you guys do, did you use that to exploit for what? Never even heard of it until now. We as most other top guilds had been working on C'thun for over 2 months. Then it got hotfixed and we and Millenium and several other top guilds killed it that day. The boss was just made easy. That's all. Edit: There is no damn oozeling on his bar lol, It's a normal macro for god knows what. Nessaj is known to be 100% macro and no skills. Lady Vashj.....Respawns? Yes that's a known bug, it wasn't intended as several screen shots proved and it was posted on our front page that a bug had happened and we mailed blizzard right away to get it fixed. Twins...No video from first kill Kungen? Sat on a torch? Fyi there is a video of our first kill and it's been released. It shows that we were the FIRST guild to figure out the ledge strategy and that's why we killed it first. Once other guilds figured it out they managed to kill it as well. Hodir....Flower power? Yes we used it and we also posted that we did on our web page. The reason for us doing it you can read on our news. Fyi using flower power actually made the encounter harder since you had to fight Hodir + 1 extra pack.. Mimiron...JoL stacking There is a video and there are also wws logs... Anything else you guys wanna make up? Er vel ikke så mye mer å nevne da? Selvom Kungen har nok av Efame betyr ikke det at alt han sier er rett Lenke til kommentar
Gakks Skrevet 30. juni 2009 Rapporter Del Skrevet 30. juni 2009 Selvom Kungen har nok av Efame betyr ikke det at alt han sier er rett Da er det jo bra at du uten e-fame kommer og sier ting uten å backe det opp da Lenke til kommentar
