Småprat om/rundt WoW
Det er quest for å få zerger stance ikke sant?
Må du til byen "din" for å få dette? (recruit a friend granting leveling lager noen hull :p)
Stikk til Stormwind/Orgrimmar og snakk med Warrior Trainer der. Da får du The Islander som vil lede deg til en øy litt utenfor Ratchet i The Barrens. Øyen befinner seg et lite stykke ifra land, i nærheten av der piratene befinner seg. Tror du vil komme borti en liten fatigue for å kunne nå øyen, men er ikke noe å bekymre seg for.
Tror jeg skal skyve fra meg sengen og legge meg på tastaturet nå. Godnatt til de(n) som ikke har lagt seg enda. :)
EditzzzZz..
Endret av Dewd
Har ikke sett noen skikkelige patchnotes selv, kan se litt rundt på nettet med en gang.
Edit: Mmo sier at patchnotes ikke er oppdatert på ukesvis ;)
Edit2: det lille mmo visste med sikkerhet.
Klikk for å se/fjerne innholdet nedenfor
Existing content changes
Before any question, please read the Patch 3.0.2 FAQ on official forums
Once this patch is deployed, the following content will be disabled or removed :
The Atiesh quest-chain will not be completable anymore.
The Bear Mount from Zul'aman will no longer drop.
The Onyxia quest-chain has been removed from the game.
Naxxramas is "removed" from the game and moved to Dragonblight. (Unreachable until WotLK, obviously)
The ability to get titles related to Tier 4 or Tier 5 content is being removed. Of course, players who got them before the patch keep them. (Hand of A'dal, Champion of the Naaru)
Also, a few things are being changed or added :
Barbershops are now available in capital cities !
The amount of experience needed to level from 60 to 70 has been lowered.
New graphical effects are being added to the game, including the new shadow engine
The Stormwind Harbor will be available, but you won't be able to travel to Northrend until the release of WotLK. However it does have a working boat travelling between Auberdine and Stormwind.
The Caverns of Time have been slightly modified to add an entrance for CoT: Stratholme. The instance itself won't be available before WotLK, only the entrance is being added.
Mounts and Vanity Pets are now trainable spells and the old items will be used to teach you these spells. Once a mount or pet is learned you can access it through the Character Panel.
Various tokens like Badges of Justice or Honor Points are all merged in the new Token Interface. It will also remove the Badges of Justice and PvP Tokens from your bags to free up even more space !
The in-game Calendar used to schedule raids or events between your friends and guildmate will be available by typing /calendar
Still need to be confirmed :
Achievements might be added to the game, but I don't think there is any confirmation for the moment.
Item changes
+Healing and +Spell damage stats are being merged into a single +Spell power stat. Healers' talents and spells have been updated accordingly to compensate this change.
Items with magic school-specific damage like +shadow or +nature have been converted to +spell power as well. This include most of the TBC items except for some enchantments like Sunfire or Soulfrost.
Protection Paladin and Tanking Warrior sets to reflect changes on the new mechanics. A lot of non set items are also being changed. See this post.
Raid changes
Raids buffs, debuffs, and auras stacking have been revamped, please check this post for more information and our raid composition simulation tool to see how it works now.
All TBC raid monsters will have their health reduced by about 30%. (see this post)
The standard melee damage output will be reduced as well.
Boss abilities remain unchanged, except for Illidan who won't use Shear anymore.
Endret av Kuldesjokk
Er det bare jeg som aldri har hatt noen form for background downloader menst jeg spiller?
Skal den starte automatisk eller evt. hvor befinner den seg?
Åpne wowfolder der skal det ligge en fil, backgrounddownloder. Om ikke, kjør launcher.
Når du er ikke på background-downloader, skal du kunne velge om den skal laste ned imens du spiller, eller bare når du ikke spiller.
