Hvordan overføre musikk fra laptop til MD?
Pepsi
Hvis du har SPIF utgang på pcen så kan du jo prøve det. Regner med at du ikke har MD med usb tilkobling siden dette ikke blir nevnt.
Nope har ikke USB tilkobling på MD.
Men, hva er SPIF utgang ? Er ikke helt inni dette her :)
S/PDIF (Sony/Philips Digital Interface) is a standard audio transfer file format. It is usually found on digital audio equipment such as a DAT (Digital Audio Tape) machine or audio processing device. It allows the transfer of audio from one file to another without the conversion to and from an analog format, which could degrade the signal quality.
The most common connector used with an S/PDIF interface is the RCA connector, the same one used for consumer audio products. An optical connector is also sometimes used.
