Kernel panic med DWL-122 og linux-wlan-ng
Hei. En stund siden sist, spørs om noen av de som var her for lenge siden husker meg, men isåfall, hei :)
Jeg har et lite problem. Jeg har dårlig tid akkurat nå, så jeg bare copy/paster det jeg skrev om problemet på engelsk. Jeg antar at det ikke er noe stort problem? Det meste av manpages er jo på engelsk, dere har vel forhåpentligvis trening. :p
I've been working with a old Pentium 3 for a server project, and I added a DWL-122 to avoid cables as tripwires throughout the building. The problems began when I tried to configure the adapter:
1) I started by adding linux-wlan-ng. The D-link DWL-122 uses a Prism 2 chipset, and as far as I know, this is the only alternative.
2) I added alias wlan0 prism2_usb to /etc/modules.d/alias (might have been modprobe.d, anyhow it was by the book as for 2.6.x kernels)
3) I configured the wlan according to the README for linux-wlan-ng: Added a configuration file for my own network, and so on.
The problem comes when I try to initiate the /etc/init.d/wlan script - kernel panic with "Kernel panic - not syncing: Fatal exception in interrupt". As in any proper catastrophic malfunction, I'm forced to reboot. Any suggestions? I'm running the latest kernel in portage (2.6.12) as well as the masked linux-wlan-ng (the stable one supposedly isn't willing to play along with anything but the 2.4.x-kernels). The computer has a P3 coppermine clocked at 800 mhz, 256mb ram and so on - nothing that should be relevant to said problems there
The D-link DWL-122 is not faulty, as I've used it with my iBook before. Any suggestions would be most appreciated - although I've been an *nix-user for the last few years, setup of wlan is pretty new to me
Takk for hjelp.
Jeg vil ha noe av det du har røyka, iv3rs.
Orinoco driver : One driver, 3 hardwares...
The Orinoco driver support 3 hardware which are very closely related but slightly different :
    * Lucent/Agere Orinoco Pcmcia cards and Apple Airport (howto)
    * Intersil PrismII Pcmcia/PLX/PCI cards (howto)
    * Symbol Spectrum24 HR Pcmcia cards (howto)
If you look in the Wireless Howto, you will find that each of these hardware have other drivers available. For the Orinoco, we list those drivers in the previous section. For PrismII, there are the famous linux-wlan-ng and HostAP drivers, which have advantages over this driver.
Because Orinoco support all those hardware, people think they are the same hardware. However, all those other drivers support only one of these hardware, and only the Orinoco driver support all three of them. At boot, the Orinoco driver will print in the message logs which of the three hardware it has detected, with the firmware version number.
Moyner:
modprobe prism2_usb
wlanctl-ng lnxreq_ifstate ifstate=enable
wlanctl-ng lnxreq_autojoin ssid="<nettverk uten wep>" authtype=opensystem
Se om det der krasjer.
Endret av Nichotin
