Filmer fra www.wmvhd.com hakker
Lastet ned et par filmer fra www.wmvhd.com, men de hakker.
Systemkravene for filmene er:
Minimal Configuration
(Play 720p video)
Microsoft Windows XP
Windows Media Player 9 Series
2.4 GHz processor or equivalent
384 MB of RAM
64 MB video card
1024 × 768 screen resolution
16-bit sound card
Speakers
Mine PC spesifikasjoner
Noen som vet hva som kan være grunnen til at de hakker?
Spyware kan være problemet, Scan datan din med disse to programmene!
Micrsoft Anti Spyware (BETA):
http://www.microsoft.com/downloads/details...&displaylang=en
Spybot Search And Destroy v1.4:
http://www.chip.de/downloads/c1_downloads_13001443.html¨
Har scannet data-en med Spybot, Ad-Aware og Microsoft AntiSpyware så det er nok ikke spyware som er problemet.
Hvis ikke dette hjelper kan du prøve og spille dem av i en annen player eller laste ned nye codec's!
Ingen som har noen andre forslag før jeg prøver tipset ovenfor?
Fant denne newsgruppetråden:
http://groups-beta.google.com/group/nz.com...6487e8f33b15a7b
Sitat:
"Here are some colourful clips, in (..ugh!) WMV format, showing off the new
high-definition WMP9 series with a "breakthrough" new set of codecs. To play
the 1920x1080 clips, you're going to need a processor of 3ghz or better and
a decent video card, otherwise it's going to stutter like hell. But they
look great if you can play them. I've looked at 2 of them so far - "Step
Into Liquid" (114mb) and "Robotica" (20mb). "Step Into Liquid" was choppy
and horrible until I ripped it to DrDivx...Robotica was also very stuttery
on WMP9 but played flawlessly (and beautifully) on Winamp 5. Weird, but ah
well. "
