hvordan slette zone alarm når pass. er glemt
veit at detta spørsmålet nok ikke hører hjemme her men , veit ikke hvor jeg ellers skulle ha lagt den eller hvor jeg henvendt meg :blush: jeg har lagt inn zone alarm på pc`n til eksen for leeeenge siden, og nå vil hun ha den bort, men mener den er passord beskyttet.. har prøvd de jeg tror det er, men til ingen nytte.. hva kan gjøres?? takker for alle svar!!
format&reinstall
neida, kanskje du burde vende deg til Zone Labs kundestøtte, eller de-aktivere zonealarm, eller
ta en linux live cd, og slett mappen som inneholder zonealarm
  • 3 uker senere...
HE HE .. kremt. :blush: glemte visst det viktigste..
[Please note that this will remove your program permissions and Local Zo
ne ]
[settings, so you may want to make note of them. However, re-establishin
g ]
[them is a simple process - you will be prompted again for program acces
s for]
[all the applications that you use to access the local network or Intern
et. ]
- Step 1. Open the ZoneAlarm program, go into the Overview Preferences tab a
nd
turn off "Load ZoneAlarm at startup".
- Step 2. If you are running Windows 95, 98, ME, or 2000, reboot your system
into either Safe Mode or to a Command Prompt. The method is determined by yo
ur
OS, but most systems will boot into safe mode by either pressing F8 at the b
eep
or holding the CTRL key during bootup. You should now have no ZoneAlarm
processes running on your system.
- Step 3. Open the Internet Logs directory (in 95/98/ME this will be
"C:\Windows\Internet Logs", in NT and 2000 it will be "C:\Winnt\Internet Log
s",
in Windows XP it could be either of these folders), where you will find a fi
le
named "iamdb.rdb" and a file named after your computer with the ".ldb"
extension. Delete both of these files. If "backup.rdb" exists, delete it als
o.
- Step 4. Make sure that you EMPTY your Recycle Bin BEFORE rebooting back in
to
normal mode.
- Step 5. You will need to start ZoneAlarm manually. (Click "Start," "Progra
ms,"
"Zone Labs" and either "ZoneAlarm" or "Zone Labs Security"). ZoneAlarm will
start up again with a fresh database. Each program should ask for access aga
in
if the files were properly deleted.
- Step 6. Be sure to RECHECK the "Load ZoneAlarm at startup".
