GM ALDL Feilsøking
ricmik
Hei! Jeg har et spørsmål jeg har stilt på engelsk tidligere, så jeg håper ikke det gjør noe at jeg sender deg spørsmålet på engelsk.
Håper noen kan hjelpe meg!
I have a question regarding my Chevrolet G20 ’88.
Here’s the cars data:
Chevrolet G20 Van ’88
6.2L Diesel
Automatic transmission
Mileage: somewhere around 65000
A/C and Cruise Control
Questions:
The ”Service engine soon” light is constantly lit. When I try to short the ALDL to get an error code, I only get the “Diagnostics mode” code (1 pause 2).
Anyway, when I short the ALDL, I can hear the glow plugs relay click (I suppose it should do so) – in addition to a weird fast clicking noise (like a relay is being turned on and off repeatedly). Is this normal?
I have a light bulb hanging behind the instrument panel with wire colors: gray/pink-black (pink with black stripe). There’s also a plug with 4 contacts; wires: dark blue/yellow – brown/light blue.
What are these for?
Is it an easy way to check that the A/C compressor is working? I can't get any cold air out of the vent.
