Følger det med VGA blokk på Reserator 1 Plus?
jeg spurte de Zalman typene og som svar fikk jeg:
Thank you for your enquiry.
Our reserator 1 plus comes with brand new CPU waterblock (ZM-WB3 Gold), VGA waterblock (ZM-GWB2) and water coolant for our Reserator 1 Plus. (ZM-G100)
We have changed the color of the reservior to black color.
It is totally up to you if you want to go for our Reserator 1 plus or not. We are sure that the new Reserator 1 Plus gives much better convenience to using our Reserator 1 Plus, but the Reserator 1 still gives very good performance.
Thanks!
Support/Zalman
__
EDIT: Er du full Margarus ? Du har en del skrivefeil :p
Endret av Pels
Thanks!
Support/Zalman
__
ja stemmer det. var litt feil har redigert det :thumbup: er litt trøtt nå, er ikke full. :whistle:
Endret av Margarus
