VegardStr Skrevet 29. juli 2005 Del Skrevet 29. juli 2005 bruker denne koden som eg trodde gikk an på bruke til å laste opp bilder, har også prøvd å CHmodde filen, slik at den har alle rettigheter på serveren, men det går ikke, slik ser koden ut: <?php echo('Last opp bildet:<br /> <FORM ENCTYPE="multipart/form-data" ACTION="' . $PHP_SELF . '" METHOD="POST"> <INPUT TYPE="file" NAME="userfile" style="BORDER: #655C45 1px solid; BACKGROUND-COLOR: #CCC5B3"><br> <INPUT TYPE="submit" VALUE="Last opp" style="BORDER: #655C45 1px solid; BACKGROUND-COLOR: #CCC5B3"> </FORM>'); $path = "/var/www/html/img/"; $max_size = 20000; if (!isset($HTTP_POST_FILES['userfile'])) exit; if (is_uploaded_file($HTTP_POST_FILES['userfile']['tmp_name'])) { if ($HTTP_POST_FILES['userfile']['size']>$max_size) { echo "The file is too big<br>n"; exit; } if (($HTTP_POST_FILES['userfile']['type']=="image/gif") || ($HTTP_POST_FILES['userfile']['type']=="image/pjpeg") || ($HTTP_POST_FILES['userfile']['type']=="image/jpeg") || ($HTTP_POST_FILES['userfile']['type']=="image/png")) { if (file_exists($path . $HTTP_POST_FILES['userfile']['name'])) { echo "The file already exists<br>n"; exit; } $res = copy($HTTP_POST_FILES['userfile']['tmp_name'], $path . $HTTP_POST_FILES['userfile']['name']); if (!$res) { echo "upload failed!<br>n"; exit; } else { echo "upload sucessful<br>n"; } echo "File Name: ".$HTTP_POST_FILES['userfile']['name']."<br>n"; echo "File Size: ".$HTTP_POST_FILES['userfile']['size']." bytes<br>n"; echo "File Type: ".$HTTP_POST_FILES['userfile']['type']."<br>n"; } else { echo "Wrong file type<br>n"; exit; } } $my_file = $HTTP_POST_FILES['userfile']['name']; ?> med denne koden kommed denne feil meldingen når eg prøver ål last eopp et bilde. Warning: copy(): SAFE MODE Restriction in effect. The script whose uid is 16112 is not allowed to access / owned by uid 0 in /web/www/frac/users/gamer/image1.php on line 40 Warning: copy(/www/tabell.JPG): failed to open stream: No such file or directory in /web/www/frac/users/gamer/image1.php on line 40 upload failed! n har også prøvd å finne ut hvilke mappe filene skal ligges i, men eg får det liksom ikke til, tror det er denne koden som forteller meg hvilke mappe filene blir lagt i, kanskje det er mapen som ikke eksisterer: $path = "/var/www/html/img/"; isåfall hvorddan endre mappen og fjerne feilmeldingene? takker for svar. Lenke til kommentar
El Nino Skrevet 30. juli 2005 Del Skrevet 30. juli 2005 I forbifarten så ser det ut som du har feil path. Hvis du ser av feilmeldingen du får så ligger fila på stien "/web/www/frac/users/gamer/image1.php", mens du i scriptet har satt stien til "/var/www/html/img/". Hvis du setter $path = "/web/www/frac/users/gamer/img/"; så kan det hende det løsner litt.. (Så fremst du har satt "img" katalogen til riktig rettigheter og at den eksisterer). Lenke til kommentar
VegardStr Skrevet 31. juli 2005 Forfatter Del Skrevet 31. juli 2005 hvilke rettigheter skal img. mappen ha då? 666 eller 777? Lenke til kommentar
objorkum Skrevet 31. juli 2005 Del Skrevet 31. juli 2005 hvilke rettigheter skal img. mappen ha då? 666 eller 777? 777 666 på ein mappe gjer at du ikkje eingong kan gå inn i den. Lenke til kommentar
El Nino Skrevet 31. juli 2005 Del Skrevet 31. juli 2005 Feil. 666 tilsvarer read/write på public, group og owner, mens 777 tilsvarer read/write/execute på public, group og owner. ALDRI bruk 777 på en mappe!!!! Å sette en mappe som Execute og public er FY FY FY FY!!!! Lenke til kommentar
Torbjørn Skrevet 1. august 2005 Del Skrevet 1. august 2005 (endret) du mener vel at execute og writable er fy fy? executable må en mappe være for at filene skal være tilgjengelige. men disse rettighetene har ikke noe med eier av fila å gjøre, som feilmeldingen sier. feilmeldingen skyldes php safe mode. Endret 1. august 2005 av Torbjørn Lenke til kommentar
El Nino Skrevet 1. august 2005 Del Skrevet 1. august 2005 du mener vel at execute og writable er fy fy? executable må en mappe være for at filene skal være tilgjengelige. Jepp, derfor det står "ALDRI bruk 777 på en mappe!!!!". Det var dette jeg henviste til, men det er selvfølgelig noen som missforstår.. Lenke til kommentar
Torbjørn Skrevet 1. august 2005 Del Skrevet 1. august 2005 vel de som misforstår deg har strengt tatt rett. En mappe må være public executable hvis du vil at filene dine skal være tilgjengelige. public writable skal den kun være hvis det er behov for å skrive til nye filer. 755 er fint for mapper. 711 hvis man er paranoid. Lenke til kommentar
