sliter med en svært simpel JSP:
<%@ page contentType="text/html" %>
<%@ taglib prefix="c" uri="http://java.sun.com/jstl/core" %>
<html>
<head>
<title>JSP is Easy</title>
</head>
<body bgcolor="white">
<h1>JSP is as easy as ...</h1>
<%-- Calculate the sum of 1 + 2 + 3 dynamically --%>
1 + 2 + 3 = <c:out value="${1 + 2 + 3}" />
</body>
</html>
Får kun ut følgende feilmelding:
HTTP Status 500 -
org.apache.jasper.JasperException: The absolute uri: http://java.sun.com/jstl/core cannot be resolved in either web.xml or the jar files deployed with this application
org.apache.jasper.compiler.DefaultErrorHandler.jspError(DefaultErrorHandler.java:50)
org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDispatcher.java:407)
org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDispatcher.java:114)
org.apache.jasper.compiler.TagLibraryInfoImpl.generateTLDLocation(TagLibraryInfoImpl.java:316)
org.apache.jasper.compiler.TagLibraryInfoImpl.<init>(TagLibraryInfoImpl.java:147)
org.apache.jasper.compiler.Parser.parseTaglibDirective(Parser.java:418)
org.apache.jasper.compiler.Parser.parseDirective(Parser.java:483)
org.apache.jasper.compiler.Parser.parseElements(Parser.java:1543)
org.apache.jasper.compiler.Parser.parse(Parser.java:126)
org.apache.jasper.compiler.ParserController.doParse(ParserController.java:211)
org.apache.jasper.compiler.ParserController.parse(ParserController.java:100)
org.apache.jasper.compiler.Compiler.generateJava(Compiler.java:146)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:286)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:267)
org.apache.jasper.compiler.Compiler.compile(Compiler.java:255)
org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:556)
org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:293)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264)
javax.servlet.http.HttpServlet.service(HttpServlet.java:810)
org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:81)
Hva er feil?
Hva skal jeg gjøre?
Koker snart over for meg.... håper det er noen som kan hjelpe.....
Har du f.eks. definert taglib i web.xml?
<taglib>
   <taglib-uri>http://jsptags.com/tags/navigation/pager</taglib-uri>
   <taglib-location>/WEB-INF/pager-taglib.tld</taglib-location>
 </taglib>
Eller kopiert f.eks jstl.jar til WEB-INF\lib mappen?
Endret av er@ser
finner jstl.jar i følgende mapper:
-jboss-4.0.3RC1/server/all/deploy/jbossweb-tomcat55.sar/jsf-libs
-jboss-4.0.3RC1/server/default/deploy/jbossweb-tomcat55.sar/jsf-libs
skal alle *.jar-filene i en av disse mappene kopieres til WEB-INF\lib mappen?
WEB-INF-mappen som ligger i roota til webserveren? har jo mange mapper med det navnet. Hvilken skal brukes?
Hvilken av web.xml-filene skal taglib defineres i? har 15 filer med det navnet..
Donerer muligens en nyre til den som klarer å hjelpe meg med dette,
finnes det en tutorial på dette på internett? sliter virkelig her.... sukk...
Du må definere tld filene i web.xml filen som ligger i kontekstets WEB-INF mappe (dvs. programmet du arbeider med sin WEB-INF).
Du må definere hvor filen http://java.sun.com/jstl/core eksisterer.
Det vanlige er å plassere c.tld i myApp/WEB-INF/tlds/c.tld, og dermed ha følgende kode myApp/WEB-INF/web.xml:
<taglib>
  <taglib-uri>http://java.sun.com/jstl/core</taglib-uri>
  <taglib-location>/WEB-INF/tlds/c.tld</taglib-location>
</taglib>
Deretter, i JSP fila som skal bruker c.tld skriver du, slik som du gjorde:
Håper det hjelper noe.
