the_fire Skrevet 19. mars 2006 Rapporter Del Skrevet 19. mars 2006 "Version 2.5.2.951 adds about 70 improvements and fixes including much improved synchronization for iPods (including copying iPod content back to a PC), 'Plays for Sure' devices, and the Sony Ericsson W800i Walkman phone, improved CD/DVD Burning, and updated codecs." Ikke noe jeg trenger, med mindre de har fikset den "linjen" over sangene jeg nevnte tidligere. Lenke til kommentar
MindTooth Skrevet 20. mars 2006 Rapporter Del Skrevet 20. mars 2006 MediaMonkey 2.5.2.951 - Updated translation pack with Croatian (thanks to Emil) - Updated online help - Fixed ratings & play history not imported from iTunes if int'l characters in filename - Fixed restoration of Now Playing window - Fixed playback can start twice in some cases ------------------------------------------------------------------ MediaMonkey 2.5.2.950 RC-3 - Fixed configuration settings don't persist in some cases - Fixed file associations set by the installer can be overwritten in some cases - Fixed Synchronization: Empty playlists aren't deleted from MTP devices - Fixed corrupt MediaMonkey.m3u file can cause strange behaviour - Fixed new format of eMusic .m3u sample playlists fails to play - Fixed Rip CD dialog not friendly for the visually impaired ------------------------------------------------------------------ MediaMonkey 2.5.2.948 RC-2 - Improved Auto-Tag from Amazon search results further - Fixed Auto-Tag from Amazon.co.uk adds incorrect tags to Artists - Fixed failed write of mediamonkey.ini and mediamonkey.m3u in some cases - Fixed Synchronization needlessly synchs tracks with custom masks - Fixed Playlist order doesn't persist in some cases - Files are incorrectly considered duplicates after conversion - Fixed wheel mouse doesn't work in drop down dialogs (e.g. Auto Tag from Amazon) - Fixed Album Art window is too insensitive to wheel mouse movement ------------------------------------------------------------------ MediaMonkey 2.5.2.947 RC-1 - Added command line option to start in Party Mode ( /party) - Added command line option to start up and play ( /play) - Added track length calculation for VBR files missing header info - Added Type-Browsing to Scan Folders dialog - Improved auto-tag from Amazon search results when only Artist is known - Updated help file - Updated default masks - Fixed occasional freezes related to file locking - Fixed MP3 encoding is slow even at -q 9 (updated to LAME 3.97b2) - Fixed FreeDB results should display properly even for incorrectly encoded data - Fixed CD Burning: write method is sometimes blank - Fixed Audio CD Burning: tracks fail to burn after a faulty file - Fixed Audio CD Burning: volume leveling doesn't work correctly - Fixed regression: some flac files fail to play correctly - Fixed regression: keyboard shortcuts conflict ------------------------------------------------------------------ MediaMonkey 2.5.2.943 Beta 2 - Added ability to scroll through multiple Album Art entries with wheel mouse - Added ability to import metadata from Windows Media Player when scanning - Added transparent synchronization support for Sony Ericsson walkman phones - Added lyrics support for iPod synchronization - Updated flac encoder/decoder to version 1.1.2 - Improved synchronization speed of MTP devices significantly - Improved iPod synchronization when genre = Audiobook (resume playback & not incl. in shuffle) - Fixed iPod synchronization - non-music entries (podcasts/movies) are not written correctly - Fixed synchronization fails to manually delete tracks on UMS devices using the WMDM plugin - Fixed synchronization of tracks via Location node don't use synch mask - Fixed synchronization of Album/Artist creates unwanted .m3us for MTP devices with DBs - Fixed synchronization of Album Art for some MTP devices - Fixed synchronization should never delete filetypes that MM doesn't understand - Fixed setting genre to null causes multiple track update - Fixed data CD Burning burns tracks in incorrect order - Fixed $ character in masks doesn't work as expected - Fixed mouse gestures can't be completely disabled - Fixed keyboard shortcuts missing for some actions ------------------------------------------------------------------ MediaMonkey 2.5.2.942 (Beta 1) - Added lots of scripting fixes and functionality (see script documentation) - Added ability to rename iPod - Added manual synching of tracks via drag & drop for iPods & other DB-based devices - Fixed synchronization with auto-conversion may not fill the device to capacity - Fixed synchronization settings don't persist for disabling a device - Fixed synchronization of metadata from the device back to the PC doesn't work - Fixed synchronization status bar sometimes incorrectly shows 'converting' - Fixed iPod doesn't trigger AutoPlay dialog - Fixed streaming audio is choppy for some stations - Fixed Auto-tag from Amazon displays some unicode incorrectly - Fixed Auto-tag from Amazon parsing and problems displaying some comments - Fixed tracks may not be found on drive with Volume ID = 0 - Fixed tracks queued via Explorer are sometimes added to Now Playing twice - Fixed focus is lost when tracks are deleted - Fixed copy/cut/paste are disabled on Location & My Computer nodes - Fixed <Auto number> and <Playlist> masks can't be used for Convert or Auto-organize - Fixed $ character in masks is ignored and can cause errors when using Auto-organize - Fixed Album Artist tagging in ogg/flac for better compatibility - Fixed CMYK Album Art triggers an access violation - Fixed Export All Playlists script fails when illegal characters are in Playlist name - Fixed FLAC playback doesn't work for non 16-bit per sample streams - Fixed volume meter is slow/refreshes slowly for some mp3 files - Fixed open threads can cause deadlocks Lenke til kommentar
iMono Skrevet 20. mars 2006 Forfatter Rapporter Del Skrevet 20. mars 2006 Takk gutter! (Eller jenter)... Lenke til kommentar
iMono Skrevet 22. mars 2006 Forfatter Rapporter Del Skrevet 22. mars 2006 Oppdatert førstepost Her er et skin som jeg har lagd (iTunes): Last ned Lenke til kommentar
Spragleknas Skrevet 22. mars 2006 Rapporter Del Skrevet 22. mars 2006 Det mest irriterende med MM er at A-ha blir tolket som gruppa Ha, med sangen A (elns) - feiltagging mao. Lenke til kommentar
blured Skrevet 23. mars 2006 Rapporter Del Skrevet 23. mars 2006 Har et lite problem nå med MediaMonkey. Det kommer opp denne feilmeldingen når jeg starter det: og denne.. Noen som vet hva jeg skal gjøre.. har prøvd å reinstalere, og å instalere forskjellige versjoner og lignende, men det hjelper ikke. Mulig jeg må få fikset denne databasen på en eller annen måte, men er ikke sikker på hvordan jeg gjør det. Så det hadde vert fint med litt hjelp Lenke til kommentar
blured Skrevet 24. mars 2006 Rapporter Del Skrevet 24. mars 2006 Problemet er løst... burde kanskje ha prøvd litt til før jeg spurte her men. Men jeg lurer på en annen ting. Kanskje ikke det rette stedet å spørre men. Støtter ipod formatet "flac" ? Lenke til kommentar
Uknuselig Skrevet 24. mars 2006 Rapporter Del Skrevet 24. mars 2006 (endret) I begynelsen skal man samle all musikk i bibloteket? For og si det sånn er jeg helt nybegynner. Hvordan lager en katigori for de musikk albumene jeg har? Endret 24. mars 2006 av zigg_ Lenke til kommentar
iMono Skrevet 24. mars 2006 Forfatter Rapporter Del Skrevet 24. mars 2006 Problemet er løst... burde kanskje ha prøvd litt til før jeg spurte her men. Men jeg lurer på en annen ting. Kanskje ikke det rette stedet å spørre men. Støtter ipod formatet "flac" ? 5805050[/snapback] iPod støtter kun .aac og .mp3. Hvis du har Gold kan du bruke konvertering ved synkronisering til MP3. Lenke til kommentar
blured Skrevet 24. mars 2006 Rapporter Del Skrevet 24. mars 2006 OK. Tenke på å kanskje gjøre det om til Flac.. for det holder seg bedre eller noe. Husker ikke helt. Men da er ikke det aktuelt. Forresten. Når man kjøper gold versjon, får man den med en gang ?. Eller må man vente til man har betalt ordentlig ? Lenke til kommentar
iMono Skrevet 24. mars 2006 Forfatter Rapporter Del Skrevet 24. mars 2006 Hvis du vil ha musikk på PC'en og på iPod'en og er opptatt av kvalitet, bør du gjøre det. Det er null tap av kvalitet når du brenner det ut igjen, noe som lønner seg hvis du skal lage egenmiks av sanger. Angående kjøp av MediaMonkey, så kan du enten betale med kort eller via PayPal (f.eks med Mobiltelefon). Da får man lisensen med en gang. Lenke til kommentar
blured Skrevet 24. mars 2006 Rapporter Del Skrevet 24. mars 2006 Men om man gjør alle sangene om til Flac. Må man ikke da ha to av alle sangene, eller gjør MM om det før man legger det inn på ipoden ? <---- I så fall er det genialt. Da tror jeg at jeg betaler med Mobil telefon over PayPal. Så jeg får det med engang: *teste ut* Er bra at man kan velge hele sju forskjellige betalings metoder forresten. Lenke til kommentar
iMono Skrevet 24. mars 2006 Forfatter Rapporter Del Skrevet 24. mars 2006 Det er det jeg mener. MediaMonkey konverterer VED synkronisering. Dermed har du Flac på PC'en, og MP3 på iPoden. Lenke til kommentar
blured Skrevet 24. mars 2006 Rapporter Del Skrevet 24. mars 2006 Har enda et spørsmål. Hvordan betaler man med telefon med PayPal ? Lenke til kommentar
Kjekssjokolade Skrevet 24. mars 2006 Rapporter Del Skrevet 24. mars 2006 fungerer dette overens med ipod? at jeg kan overføre sanger til ipod med dette programmet? Lenke til kommentar
blured Skrevet 24. mars 2006 Rapporter Del Skrevet 24. mars 2006 Les litt lenger opp. Svaret er ja. Fungerer utmerket Lenke til kommentar
Spragleknas Skrevet 24. mars 2006 Rapporter Del Skrevet 24. mars 2006 Det mest irriterende med MM er at A-ha blir tolket som gruppa Ha, med sangen A (elns) - feiltagging mao. 5796490[/snapback] Ingen andre? Tagger vha. MusicBrainz (genial - men tydligvis ikke 100% samkjørt med MM)) Lenke til kommentar
Kjekssjokolade Skrevet 24. mars 2006 Rapporter Del Skrevet 24. mars 2006 jeg har latt itunes organisere alt av musikk jeg har....ca 200gb, organisert i mapper slik artist->album, kommer MediaMonkey til å gjøre noe annet igjen? Er bare ikke så vedig lysten på "rot" eller tull i data samlingen Lenke til kommentar
Kjekssjokolade Skrevet 25. mars 2006 Rapporter Del Skrevet 25. mars 2006 ah, MediaMonkey er det beste jeg har vært borti av slike programmer Men hvordan lager jeg helt egene skins, hvilket prog må jeg bruke? Leste i hjelp, men lurer på hvordan dere iallefall trådtsrater gjorde det, å hvordan lagrer jeg alle filene jeg evt tegner tilbake til .WSZ formatet? I hjelp står det at jeg må tegne på bit map filene, å da blir det jo ikke akkurat så bra Lenke til kommentar
iMono Skrevet 25. mars 2006 Forfatter Rapporter Del Skrevet 25. mars 2006 (endret) Du bør forandre på skinnet "Brushed Monkey" slik jeg gjorde. Da forandrer du på en eksisterende mal. Husk at det er lurt at du kopierer skinnet til en helt ny destinasjon før du redigerer, f.eks på skrivebordet. Når du har gjort det, laster du ned et zip-program f.eks WinRAR. Så angir du filen til å være en .zip fil istedetfor en .wsz fil. Hvis du ikke klarer å forandre filtype på filen, så må du slå på filendelser under Verktøy>Mappealternativer>Vis>Skjul filetternavn for kjente filtyper. Når du har åpnet zip-filen i Winzip eller WinRAR, så ekstrakterer du innholdet til en ny mappe med navnet på skinnet ditt. Det du har i den mappen da, er bildefiler som definerer spilleren i skinnet ditt, en .ini-fil som definerer hvilke skrifttyper du vil ha, og hvilken farge du vil ha på stripemønsteret i listene dine. Du har også en .mskn fil der. Den er for resten av utseendet til MediaMonkey og utgjør den største jobben. Du trenger to program til den jobben: Gå til denne siden og last ned et gratis skinneprogram. Da kan du åpne .mskn-filene som ligger inni zip-filen. Deretter lagrer du ressursene i den filen til en ny mappe, slik at du lett kan du redigere filene med et bilderedigeringsprogram som f.eks Photoshop eller til og med Paint. Husk at filformatet bør være det samme! Du kan forandre på bildefilene så mye du vil, men størrelsen på ikonene bør være noenlunde det samme. Da slipper du for mye redigering i skinneprogrammet. Det enest tipset jeg kan gi deg nå er at du må bruke begge musetastene når du definerer hvor ikoner og bakgrunner skal defineres fra bildefilene dine. En vanskelig formulering, men den inneholder alt det grunnleggende du trenger for å gjøre ferdig ditt skin Da får du ha lykke til, og gjerne spørre meg om mer hjelp Endret 25. mars 2006 av Dell_9200 Lenke til kommentar
