Den store Huntertråden
Hva er grunnen til det?
Kan ikke se at en BM hunter kan gjøre mer dmg enn en MM, når de fleste BM skills gir pettet mer fordeler enn det gir deg, og pettet bruker du jo ikke i raid.
Noen andre som har noen meninger om speccen?
Om MM var en bedre PVE spec enn BM er det jo svært rart at huntere fra omtrent alle store guilder, som har BT på farm bruker en BM 41-20-00 spec?
Eksempler
http://eu.wowarmory.com/character-sheet.xm...azzak&n=Maa
http://eu.wowarmory.com/character-sheet.xm...azzak&n=Rez
http://eu.wowarmory.com/character-sheet.xm...Kazzak&n=Nm
Endret av Ashvan
påstand fra en hunter i guilden min.
Think about it, You take 3-4 hunters to raids. Each of you have a different rank of Imp HM, and you get a ridiculous 440*4 AP bonus
Det han påstår er altså at hunters mark kan stacke, og at man kan utnytte dette med å ha forskjellig antall points i improved i et raid.
Er det noe hold i dette?
Høres litt rart ut synes jeg
Endret av vetle
I følge wowwiki er det bare den beste HMen som teller: http://www.wowwiki.com/Improved_Hunter's_Mark
From what I see, it is true, you can see more marks on the bufflist of the target. Only I dunno if you can only see the buff, or the buff is also counted more than once. With the bm spec though, it is imo a bit difficult to take the improved mark as well and because it only benefit the melee dps with the current use of not too many rogues in the raid it is not that usefull. I also think it is a bug which will be solved soon
yeah ive seen happen too.. the way you can apply this is put low mark first then put imp. one... but as xxxx said it will be difficult for bm spec to do it.. although you can put 1-2 on it and not taking the rapid kill thingy.... and its only melee too.. but our pet is melee so i think its worth a try though.. what you think? are you going to respec just to try it? so we can haxx a bit more dps b4 they fixed it? ot its useless on your opinion?
Thats interesting,
If this is really a bug, You might actually receive the full bonus from the mark and the melee will get their % (depending on the rank). Worth a check,
And if it does what I suggested then its 10000% more viable then 2/2 rapid killing
Vi skal visst prøve dette i kveld. Har en følelse av at det ikke funker tho
Endret av vetle
Nihilums topphunter har faktisk Survival-build, og av de tre resterende hunterene bruker to 41/20/0. Men de tar vel hele BT så lett nå at min/max-ing ikke er så viktig.
I ett raid kan det være lurt å både ha BM og surv huntere da de drar nytte av hverandres buffs, men BM gir somregel høyest dps ;)
Men ang det med hunters mark, har selv sett at det har blitt 2 marks på en raid boss men om det ga noe mere atp aner jeg ikke (dette var jo ett par måneder siden også da)
Når gearet kommer på Mount Hyjal og Black Temple Tier blir gjerne Survival like bra/bedre. Dette er fordi survival skalerer utrolig bra med økningen i stats på gearet ditt.
Leser mye om shot rotation, men har egentlig aldri brukt det selv. Skal prøve å begynne med det..
Hvordan rotation bruker folk her?
Selv har jeg prøvd meg på en arcane, multi, steady, arcane, multi, steady rotation, med atuo innimellom fordi multi har så lang CD og synes den funker bra. Lite nedetid.
Hva synes dere?
andre som har noen kommentar til dette?
er du BM? som BM er det nesten like greit å drite i arcane og multi, kanskje en arcane en gang i blant, men når IAOTH proccer er det waste å bruke multi og auto, steady all the way.
Jeg har selv 4 set bonus av Tier 6 og da er det ikke vits å bruke multi og arcane på single target mobs, steady critter faktisk mer en multi til tider :p
Dagens tips: Ikke tenk "shot rotation", tenk på å ikke forsinke auto shot!
Auto > Random > Auto > Random
Er en veldig fin måte å spille på. Tenk selv. La auto gå av, bruk en skill du syns passer. Har du tid før neste auto; bruk en skill til. Vent på auto; skyt et skudd du syns passer.
Eksempel:
Auto > Steady > Kill Command > Steady > Multi > Arcane > Steady > Steady bla bla bla.
Poenget er at alle skills er gode til sitt bruk. Multi gjør mest skade (men er lite effektivt for manabruken), arcane gjør nest mest skade og steady minst (men er snillest på mana bruken. Om du har 20% mana igjen etter en boss fight er det mye skade du ikke har gjort. Bruk flere spesielle skudd som Multi Shot og Arcane. Har du mana, bruk alle skudd når cooldown er over! Når du ikke har nok mana til dette, bruk de litt inneimellom.
(Dette gjelder også for BM, Multi gjør masser av skade. Om du ikke har 4 set bonus fra T5 er det bare å peise på. Og selv med den set bonusen tror jeg Multi vil gjøre mer skade alikevel...)
Endret av hobbyflekken
Nå er det sånn at for best dpm så er det best å bruke auto-steady+KC rotation som bm hunter :)
Selvfølgelig, om du ikke har noe prob med mana er det bare å peise på med arcaneshots så lenge du ikke "clipper"(forsinker som nevnt ovenfor) autoshots.
Endret av M@R7!N
Og husk at KC ikke gir en globalcooldown. Så den kan du bruke så lenge du ikke caster noe annet, feks steady shot.
Ikke glem Cooldown på Auto Shot! Det korrekte er vel å si casting time. Dette er 0.5 sekunder og en Kill Command som blir brukt innenfor denne tiden, eller så nærme at latency plasserer den innenfor denne tiden, vil utsette auto shot! Du trenger altså (ideelt) 0.5 sekunder med fri tid FØR Auto Shot skal bli avfyrt.
