Nobrains Skrevet 17. juli 2005 Del Skrevet 17. juli 2005 Topic sier alt... Skulle gjerne hatt det på en annen disk....hvordan flytter jeg det ? Lenke til kommentar
K.. Skrevet 17. juli 2005 Del Skrevet 17. juli 2005 En flott tråd Bruk søkefunksjonen. Lenke til kommentar
bobafett Skrevet 17. juli 2005 Del Skrevet 17. juli 2005 (endret) Sånn gjør du det: Moving the entire folderNOTE: This method does relocate key Windows components. Use this method only if you require the Documents and Settings folder to be moved or renamed and you cannot use the Unattend.txt file to change the name during installation. To specify a different folder for the entire Documents and Settings folder, including key system components, follow these steps: 1. Log on to the computer as an administrator, and then create a new folder. 2. In the current Documents and Settings folder, on the Tools menu, click Folder Options, and then click the View tab. 3. Under Advanced settings, click Show hidden files and folders, and then click to clear the Hide extensions for known file types and Hide protected operating system files (Recommended) check boxes. 4. Click OK. 5. Click and drag all the folders in the Documents and Settings folder to copy them to the new folder, except for the folder for the currently logged-on administrator. 6. Log off and then log back on, using a different administrator account from the one that you just logged off from. 7. Open the Documents and Settings folder again, and then copy the profile of the administrator that you just logged off from to the new folder. This extra step is needed because you cannot copy the profile of the account that is currently logged on. 8. Log off the computer, and then again log on to the computer as an administrator. 9. Start Registry Editor, and then click Find on the Edit menu. 10. Type documents and settings, and then click Find Next. 11. For every registry key or value that contains the original path, replace the value data or rename the value or registry key to the new path.IMPORTANT: You must complete this change in the registry for every instance of the original path, or your computer may not start. It is imperative that you update all registry keys and values with the new path. 12. Restart the computer. You can now safely remove the original Documents and Settings folder. Foreslår "Registry Workshop" for punkt 11. EDIT: Link: http://support.microsoft.com/kb/314843/ Endret 17. juli 2005 av bobafett Lenke til kommentar
