Hvorfor kommer dette opp? (oppdatering av Ubuntu)
når jeg klikker på oppdaterings ikonet på toppen av skjermen kommer denne beskjeden opp:
It is not possible to upgrade all packages.
This means that besides the actual upgrade of the packages some further action (such as installing or removing packages) is required. Please use Synaptic "Smart Upgrade" or "apt-get dist-upgrade" to fix the situation.
The following files is not upgradable:
mozilla-firefox
mozilla-firefox-gnome-support
deretter:
Apply the following changes?
This is your last opportunity to look through the list of marked changes before they are applied.
Warning
You are about to install software that CAN`T BE AUTHENTICATED! Doing this could allow a malicious individual to damage or take control over your system.
details:
file-roller (version 2.10.1-0ubuntu1) will be upgraded to version 2.11.1-0ubuntu1~5.04ubp1
foomatic-db-hpijs (version 1.5-20041013-1) will be upgraded to version 1.5-20050420-1~5.04ubp1
foomatic-filters-ppds (version 20041013-1ubuntu1) will be upgraded to version 20050430-1ubuntu1~5.04ubp1
gaim (version 1:1.1.4-1ubuntu4.3) will be upgraded to version 1:1.3.1~5.04ubp1
gaim-data (version 1:1.1.4-1ubuntu4.3) will be upgraded to version 1:1.3.1~5.04ubp1
gimp (version 2.2.2-1ubuntu5) will be upgraded to version 2.2.7-1~5.04ubp1
gimp-data (version 2.2.2-1ubuntu5) will be upgraded to version 2.2.7-1~5.04ubp1
gimp-python (version 2.2.2-1ubuntu5) will be upgraded to version 2.2.7-1~5.04ubp1
gnome-btdownload (version 0.0.18-1ubuntu4) will be upgraded to version 0.0.20-1~5.04ubp1
gnome-menus (version 2.10.1-0ubuntu1) will be upgraded to version 2.10.2-0ubuntu1~5.04ubp1
hpijs (version 2.0.1+0.8.7-4) will be upgraded to version 2.1.2+0.9.2-2ubuntu3~5.04ubp1
konversation (version 0.16-1ubuntu1) will be upgraded to version 0.18-1ubuntu1~5.04ubp2
libgcc1 (version 1:4.0-0pre6ubuntu7) will be upgraded to version 1:4.0.0-7ubuntu6~5.04ubp1
libgimp2.0 (version 2.2.2-1ubuntu5) will be upgraded to version 2.2.7-1~5.04ubp1
libgnome-menu0 (version 2.10.1-0ubuntu1) will be upgraded to version 2.10.2-0ubuntu1~5.04ubp1
libnspr4 (version 2:1.7.6-1ubuntu2.1) will be upgraded to version 2:1.7.8-1ubuntu2~5.04ubp2
libnss3 (version 2:1.7.6-1ubuntu2.1) will be upgraded to version 2:1.7.8-1ubuntu2~5.04ubp2
libsmbclient (version 3.0.10-1ubuntu3) will be upgraded to version 3.0.14a-3ubuntu3~5.04ubp1
python-xdg (version 0.9-1) will be upgraded to version 0.14-0ubuntu1~5.04ubp1
python2.4-samba (version 3.0.10-1ubuntu3) will be upgraded to version 3.0.14a-3ubuntu3~5.04ubp1
samba-common (version 3.0.10-1ubuntu3) will be upgraded to version 3.0.14a-3ubuntu3~5.04ubp1
synaptic (version 0.55+cvs20050406-1) will be upgraded to version 0.56+revertedto+officialhoary+0.55+cvs20050406-1~5.04ubp1
totem (version 1.0.1-0ubuntu1) will be upgraded to version 1.1.1-0ubuntu3~5.04ubp1
totem-gstreamer (version 1.0.1-0ubuntu1) will be upgraded to version 1.1.1-0ubuntu3~5.04ubp1
xchat (version 2.4.1-0.1ubuntu5) will be upgraded to version 2.4.3-0.1ubuntu2~5.04ubp2
xchat-common (version 2.4.1-0.1ubuntu5) will be upgraded to version 2.4.3-0.1ubuntu2~5.04ubp2
La til disse repositoriene
## Backports
deb http://ubuntu-backports.mirrormax.net/ hoary-backports main universe multiverse restricted
deb http://ubuntu-backports.mirrormax.net/ hoary-extras main universe multiverse restricted
Er dette farlige greier eller er det bare en genrell advarsel?
Endret av blablabla21
Dette er en helt normal melding. :)
..betyr bare at du installerer/oppgraderer programmer fra Backports-repositoriet. Selvom dette repositoriet er halv-offiselt, er det ikke garantert bug-fritt og derfor vises denne meldingen.
mozilla-firefox
...betyr at enten holder programvedlikeholderne på med en ny fiks, eller så har du installert en pakke som gjør at oppdateringen til Firefox er unødvendig. Du kan jo alltids prøve å fjerne backports fra repositorie-listen og prøve å oppdatere igjen, men dette kan føre til noen problemer.
lipsum
Oppdateringsverktøyet til Ubuntu er jo strengt tatt en frontend til en av disse programmene, så å kjøre upgrade manuelt i en konsoll hjelper nok ikke.
Hva betyr lipsum? "Det som står"?
Iallefall.. det oppdateringsikonet som trådstarter her sikter til utfører kun en ..og der kom jeg på det ja.. apt-get upgrade.
dist-upgrade er man nødt til å gjøre via apt-get eller synaptic. Det virker iallefall på den måten her. Nå kan det godt hende det er deler av min forståelse som er ullen, eller om det er noen grep jeg har gjort som gjør at ting fungerer annerledes her.
Hvis min forståelse er ullen, enlighten me!
-Escariot
Hvis noen pakker ikke lar seg installere med "apt-get upgrade" er det ikke bryet verdt å prøve å installere dem med "apt-get dist-upgrade". Det kan i værste fall ødelegge installasjonen din.
(alt ifølge min hukommelse og #ubuntu på FreeNode ;) )
takk gimper, det visste jeg ikke..
veldig OT: men, hva betyr lipsum? jeg gjorde en wiki og fant dette:
Lorem ipsum (lipsum for short) is the standard placeholder text used since the 1500s in the publishing and graphic design industry. It is used to demonstrate the elements of graphic presentation, such as fonts, typography, and layout. It also serves as the placeholder text in the mock-ups of visual design projects before the actual words are inserted into the finished product. When used in this manner, it is also called greeking.
her.
Kan ikke si dette gjorde meg noe særlig klokere, men fant ordet veldig interessant. Care to explain gimper?
-Escariot
"lorem ipsum" (lipsum) er en gammel latinsk tekst som blir ofte brukt som plassholder i grafisk design, på nettsider, o.l. Men eneste grunnen til at jeg skrev "lipsum" i quote-feltet var at innlegget ditt var "for langt" til å quotes i sin helhet. ;)
