RamGuy Skrevet 15. juli 2005 Del Skrevet 15. juli 2005 Hei, Jeg skal ha noen nye minnekort nå, men jeg lurer på hva som er forskjellen på ECC/Reg minnekort og vanlige minnekort. Hva er forskjellen? Og jeg lurer på hvor stor betydning hastigheten på minnekortet har, sålenge de fleste anbefaler PC-3200 kort/DDR-400 når man kan få opptil PC-4400/DDR-550. Hvorfor anbefales de trege kortene? Jeg snakker om DDR-DIMM kort ikke DDR2 kort Lenke til kommentar
la7dfa Skrevet 16. juli 2005 Del Skrevet 16. juli 2005 Gooooooooooooooooooooooooooooooooooooooooooooooooooooogle What is the difference between ECC and non-parity memory? If you already have a PC and are unsure which type you have, count the number of small, black, IC chips mounted on one of your existing DIMMs. If the number of chips is evenly divisible by three, then you need ECC. If the number of chips is NOT evenly divisible by three, you have non-parity memory. If you are building a PC and deciding which type to use, the following guidelines should help. If you plan to use your system as a server or a similar mission critical type machine, it is to your advantage to use ECC. If you plan to use your PC for regular home, office, or gaming applications, you are better off with non-parity. ECC (Error Checking and Correcting) performs "double bit detection and single bit correction." This means that if you have a single bit memory error, the chipset and memory will find and repair the error on the fly without you knowing that it happened. If you have a double bit memory error, it will detect and report it. Using ECC decreases your PC's performance by about 2%. Current technology DRAM is very stable and memory errors are rare, so unless you have a need for ECC, you are better served with non-parity SDRAM. Lenke til kommentar
Jankee Skrevet 16. juli 2005 Del Skrevet 16. juli 2005 No har eg sletta bumpinga men eg vil anbefale trådstarter å ta ein liten tur innom retningslinjene og nettiketten for dette forumet. http://forum.hardware.no/index.php?act=SR&f=60 http://forum.hardware.no/index.php?act=boardrules Lenke til kommentar
