ATi Crossfire hacket
http://www.hexus.net/content/reviews/revie...mlld19JRD0xMzUx
In slave-slave AFR mode, you don't get the display output at any time from the second board, since there's no compositing chip to display it and the finished frame isn't sent over the PCI Express bus either. So while each board is rendering separate frames, half the frames are never displayed since the second board doesn't push them to the first. So you get inflated benchmark results without seeing all the frames on your screen.
The nVidia SLi technique □g is □ the friendly □□l□d core □□□ 碛 good fortune □□□mio connection, is □ the deep wc□L□d core ég □ò□ the cow □ passes □^ this MIO connection □ is friendly □□@
:!: Lett å få med seg hva de mener når det er 50% teknoligiprat og 50% fortune-cookie-utsagn.
  • 5 uker senere...
