dkvam Skrevet 7. juli 2005 Del Skrevet 7. juli 2005 (endret) Tråden for oss som venter på Uli M1695 - Native AGP + PCIexpressx16 - Konkurransedyktig med nforce4 når det kommer til ytelse! - Stor fleksibilitet- - TGI - Støtte for bruk av 3 grafikk-kort samtidig for å gi mulighet for 6 skjermer samtidig! For demonstrasjon se: Ocworkbench - TGI Demonstration Trenger man si mer...... Artikkelindex : www.Uli.com - ULi Unveils World's 1st TGi Chipset 15.04.05 Hardware.no - Bred grafikkstøtte fra ULi 27.05.05 Ocworkbench - ULi M1695/1567 Reference Mainboard 27.06.05 Ocworkbench - ULi M1695 FX-57 oc to 400 x 7 aircooled 01.07.05 Tbreak - ULi M1695 Chipset : Intro 13.07.05 Anandtech - First look Uli M1695 22.07.05 Sysopt - AGP, PCI Express, and Scalability: ULi M1695 Chipset Overview 05.08.05 Anandtech - ULi M1695 PCIe/AGP for Athlon 64 – Part 2 with SLI 11.08.05 Tomshardware - NVIDIA Under Attack: Here Comes The M1695 From ULi 07.09.05 NY! Anandtech - Asrock DUAL-SATA2 Review The new ULi M1695/M1567 chipset is both unique in its full-blown AGP support on a PCIe board and fully competitive in performance with the best Athlon 64 solutions currently available. PCIe performance could use a bit more tuning, but it is already competitive. If ULi can bring PCIe performance to the levels that they currently enjoy with AGP on this same board, this could well be the fastest Athlon 64 chipset that you can buy. We could wish for SATA 2 support and integrated Gigabit LAN, but even those are coming with the M1575 South Bridge slated for September/October production. ULi did a great job with their new PCIe/AGP chipset. If you are in the market for a new Socket 939 board, then boards based on the ULi M1695/M1567 should definitely be on your shopping list. If you by chance plan to use AGP on your new PCIe board, then ULi M1695/M1567 is the only board that you should have on your shopping list. This AGP on PCIe really works, there are no compromises, and you will not be disappointed. Først ute med Uli M1695 er Asrock. OCWorkbench Asrock 939DUAL-SATAII review Asrock er ikke kjent for overklokking , men heller for gode utvidelsesmuligheter. På dette kortet er det iform av en slot som muliggjør oppgradering til socket M2 når den kommer. Kortet heter Asrock 939Dual-SATA2 Tross navnet så har kortet bare 1xSATA2 mens det har 2 vanlig SATA kontakter. Asrock DUAL-SATAII Tråden Prisguide: Asrock 939Dual-SATAII Endret 11. september 2005 av dkvam Lenke til kommentar
Zink Skrevet 8. juli 2005 Del Skrevet 8. juli 2005 DRM, hva er det ? - kanskje Digital rights management Det produseres kort med både PCI-e og AGP-støtte idag, men de er neppe særlig gode på overklokking. Lenke til kommentar
dkvam Skrevet 8. juli 2005 Forfatter Del Skrevet 8. juli 2005 (endret) Det produseres kort med både PCI-e og AGP-støtte idag, men de er neppe særlig gode på overklokking. Nettopp! Derfor venter jeg på Uli M1695! n 300HTT skulle ikke være noe problem med referanse kort , 400HTT ble oppnådd etterhvert. Pr. dags dato er jeg ikke sikker på om jeg har hørt om noe annet chipset som har oppnådd så høy Hypertransport Bus. Endret 8. juli 2005 av dkvam Lenke til kommentar
dkvam Skrevet 13. juli 2005 Forfatter Del Skrevet 13. juli 2005 Oppdatert med link til Anandtech sin forhåndstitt på Uli M1695 Lenke til kommentar
KongeOdin Skrevet 14. juli 2005 Del Skrevet 14. juli 2005 Kortet ser kjempebra ut. Lurer på hvordan det takler AMD Athlon 64 X2. Ser ut som om ting kan bli spennende fremover. Lenke til kommentar
Pels Skrevet 14. juli 2005 Del Skrevet 14. juli 2005 Når vil kortet være tilgjengelig i butikkene? Lenke til kommentar
dkvam Skrevet 19. juli 2005 Forfatter Del Skrevet 19. juli 2005 Oppdatert med Asrock nyheter. Lenke til kommentar
Malvado Skrevet 19. juli 2005 Del Skrevet 19. juli 2005 (endret) Så dette kortet kommer til å støtte både Agp + Pci-e med god ytelse? Da kan det godt bli at jeg oppdaterer til et sånt kort når jeg går over til A64, forhåpentligvis så kan jeg få tak i M2 Socketen med en slik støtte. Edit : Leste et par tester om dette hovedkortet, er veldig imponert. Kommer definitivt til å ha dette på handlelista mi ja når det kommer med støtte for M2. Endret 20. juli 2005 av Malvado Lenke til kommentar
AMD-King Skrevet 20. juli 2005 Del Skrevet 20. juli 2005 *ser lysstråla mellom skyene skinne ned på meg, en stemme sier: det er en mulighet, se på M1695!* Hovedkortet dekker mine behov ganske bra. AGP ytelsen er jo også ekte! Men jeg kom på noe DRM greier og ULi. http://www.hardware.no/artikkel/16627 Det var nesten! Denne artikkelen gjelder M1697, men det betyr jo ikke at M1695 ikke har DRM. Kan noen bekrefte dette? Mine inntrykk fra referansehovedkortet sier at vi kan vente: + OK overklokking + PCIe og Ekte AGP, endelig + Lav pris og konkurrerende ytelse + Dual Core støtte (antar dette siden det står "Dual-Core" på selve printkortet til ASRock) Lenke til kommentar
dkvam Skrevet 20. juli 2005 Forfatter Del Skrevet 20. juli 2005 http://www.hardware.no/artikkel/16627Det var nesten! Denne artikkelen gjelder M1697, men det betyr jo ikke at M1695 ikke har DRM. Kan noen bekrefte dette? Har lest mye om ULi M1695 , men har ikke funnet noen slags referanser til at det skal er DRM. Hadde DRM vært en realitet hadde noen nevnt det. Lenke til kommentar
Malvado Skrevet 20. juli 2005 Del Skrevet 20. juli 2005 Det er vel ikke støtte i selve brikkesettet for DRM (fant i alle fall ingenting om det), men det kommer nok i selve cpu'en etter hvert. Ser at DRM kommer kanskje til M2 socketen og det er ikke bra. Lenke til kommentar
Zink Skrevet 21. juli 2005 Del Skrevet 21. juli 2005 DRM, nok en forkortelse å forholde seg til ...i praksis, hva vil det si, og hva er så ille med det, på norsk? Lenke til kommentar
Malvado Skrevet 21. juli 2005 Del Skrevet 21. juli 2005 Digital Rights Managements : Kort fortalt så kan det hindre oss for å ta i bruk egen kopierte mp3 spillere , minnebrikker som ikke kommer fra en spesiell fabrikant etc. Litt avhengig av hvordan det blir brukt, men kan begrense brukerfrihet kraftig eller lite. Lenke til kommentar
perpyro Skrevet 21. juli 2005 Del Skrevet 21. juli 2005 Dersom dette er negativt for sluttbrukeren hvorfor inplementeres dette i hardwaren? Vil jo gi dårlig reklame for de som gjør det. Regner med at både Intel og AMD og alle de andre HW produsentene ikke er interesert i dårlig reklame. AMD f.eks. er vel mest interresert i at man skal velge deres prosessor og driter vel i resten så lenge de lager et bra produkt. Lenke til kommentar
AMD-King Skrevet 21. juli 2005 Del Skrevet 21. juli 2005 Dersom dette er negativt for sluttbrukeren hvorfor inplementeres dette i hardwaren?Vil jo gi dårlig reklame for de som gjør det. Regner med at både Intel og AMD og alle de andre HW produsentene ikke er interesert i dårlig reklame. AMD f.eks. er vel mest interresert i at man skal velge deres prosessor og driter vel i resten så lenge de lager et bra produkt. Veldig lett for DRM folkene å selge dette. Folk generelt er uvitne om hva DRM innebærer, alt selgerne trenger å si er at kjøperne ikke kommer til å få virus igjen og at alt kommer til å bli sikkert. Lenke til kommentar
dkvam Skrevet 25. juli 2005 Forfatter Del Skrevet 25. juli 2005 Oppdatert med link til til forhåndstitt på Asrock 939 Dual-SATA-II hos ocworkbench. Lenke til kommentar
AMD-King Skrevet 25. juli 2005 Del Skrevet 25. juli 2005 Oppdatert med link til til forhåndstitt på Asrock 939 Dual-SATA-II hos ocworkbench. Åhh! Det ble mer og mer digg å lese, men side 7 dukket aldri opp. Prøvde å justere linken, men fikk aldri opp noe side 7 etter alle forsøkene mine. Ikke side 8 heller Lenke til kommentar
dkvam Skrevet 25. juli 2005 Forfatter Del Skrevet 25. juli 2005 (endret) Åhh! Det ble mer og mer digg å lese, men side 7 dukket aldri opp. Prøvde å justere linken, men fikk aldri opp noe side 7 etter alle forsøkene mine. Ikke side 8 heller Som jeg forstår er artikkelen under bygging! så prøv igjen senere! Endret 29. juli 2005 av dkvam Lenke til kommentar
dkvam Skrevet 29. juli 2005 Forfatter Del Skrevet 29. juli 2005 Oppdatert med link til demonstrasjon av Tgi. - Triple Graphics interface. Noe som muliggjør bruk av AGP , Pci-express16 og PCI skjermkort samtidig!!! Lenke til kommentar
Malvado Skrevet 29. juli 2005 Del Skrevet 29. juli 2005 Flott, dette ser bare bedre og bedre ut! Gleder meg til hovedkortene kommer ut. Dkvam : Vet du om det kommer noen med M2 støtte? Lenke til kommentar
