Tror jeg fikk det til, trikset er å søke etter Path.DirectorySeparatorChar, og ikke "\\" eller @"\". Legger ved koden for andres fornøyelse. Sannsynligvis er det en del feilsjekk som burde være med...
 static public string GetRelativePath(string absDir, string filename)
 	// absDir should be a directory we need a relative path FROM. c:\foo\baz\
 	// filename should be a complete absolute path, e.g C:\foo\bar\file.txt
 	// Returns relative path from absDir til filname, ..\bar\
 	string relPath = "";
 	int i = 0, levels = 0;
 	absDir = absDir.ToLower();
 	filename = filename.ToLower();
 	// Check if file is on same disk
 	if (filename[0] != absDir[0])
   return filename;
 	// Find last common character
 	while ((i < filename.Length) && (i < absDir.Length)
          &&	(filename[i] == absDir[i]) )
   i++;
 	if (i == absDir.Length) i--;
 	// Must go back to last "\"
 	while (!absDir[i].Equals(Path.DirectorySeparatorChar))
   i--;
 	relPath = filename.Substring(i+1);
 	// Don't want relPath to start with \
 	// Must insert correct number of "..\"
 	// Count the number of \ after i, don't count the last \ in absDir
 	for (int j = i;j < absDir.Length-1; j++)
   if (absDir[j].Equals(Path.DirectorySeparatorChar))
   	relPath = "..\\" + relPath;
 	return relPath;
Endret av Mr Burns
  • 2 uker senere...
