Tipper det var xslt du tenkte på.
XSL stands for EXtensible Stylesheet Language.
The World Wide Web Consortium (W3C) started to develop XSL because there was a need for an XML-based style sheet language.
XSLT stands for XSL Transformations. In this tutorial you will learn how to use XSLT to transform XML documents into other formats, like XHTML.
Endret av dabear
