Problemer med Topcom 871BT
Den har klikka helt ser det ut som..
Hva kan være problemet her?
Portene jeg har åpnet er port 10000 og 10001 til 10.0.0.20
Denne er igjen koblet i en tråløs router som bare kommer opp med begrenset nettverk hele tia...
DHCP er ikke aktivert på den og har koblet meg inn på en lan port
Rebot og så kommer
06/26/2005 13:39:58> Received time from Time Server 129.6.15.29
06/26/2005 13:41:13> DDNS: Server Name [ members.dyndns.org ]
06/26/2005 13:41:13> DDNS: Domain Name [ mittdomene.mine.nu ]
06/26/2005 13:41:13> DDNS: IP Address [ xxx.xxx.xxx.xxx ]
06/26/2005 13:41:13> DDNS: Update information!
06/26/2005 13:41:13> DDNS: Update successful!
06/26/2005 13:48:07> DNS WAN auto connection attempt.
06/26/2005 13:48:09> DNS WAN auto connection attempt.
06/26/2005 13:48:10> DNS WAN auto connection attempt.
06/26/2005 13:48:12> DNS WAN auto connection attempt.
06/26/2005 13:48:13> DNS WAN auto connection attempt.
06/26/2005 13:48:18> DNS WAN auto connection attempt.
06/26/2005 13:48:20> DNS WAN auto connection attempt.
06/26/2005 13:48:21> DNS WAN auto connection attempt.
06/26/2005 13:48:22> DNS WAN auto connection attempt.
06/26/2005 13:48:24> DNS WAN auto connection attempt.
06/26/2005 13:48:54> DNS WAN auto connection attempt.
06/26/2005 13:50:40> DNS WAN auto connection attempt.
06/26/2005 13:52:36> DNS WAN auto connection attempt.
06/26/2005 13:52:37> DNS WAN auto connection attempt.
06/26/2005 13:53:07> DNS WAN auto connection attempt.
06/26/2005 13:54:57> DNS WAN auto connection attempt.
06/26/2005 13:55:40> DNS WAN auto connection attempt.
06/26/2005 13:55:47> DNS WAN auto connection attempt.
06/26/2005 13:55:48> DNS WAN auto connection attempt.
06/26/2005 13:55:50> DNS WAN auto connection attempt.
06/26/2005 13:55:58> DNS WAN auto connection attempt.
06/26/2005 13:55:59> DNS WAN auto connection attempt.
06/26/2005 13:56:02> DNS WAN auto connection attempt.
06/26/2005 13:56:05> DNS WAN auto connection attempt.
06/26/2005 13:56:06> DNS WAN auto connection attempt.
06/26/2005 13:56:33> DNS WAN auto connection attempt.
06/26/2005 13:58:07> DNS WAN auto connection attempt.
06/26/2005 13:59:38> DNS WAN auto connection attempt.
06/26/2005 14:00:27> DNS WAN auto connection attempt.
06/26/2005 14:00:28> DNS WAN auto connection attempt.
06/26/2005 14:03:17> DNS WAN auto connection attempt.
06/26/2005 14:14:13> DNS WAN auto connection attempt.
06/26/2005 14:14:14> DNS WAN auto connection attempt.
06/26/2005 14:14:15> DNS WAN auto connection attempt.
06/26/2005 14:14:16> DNS WAN auto connection attempt.
06/26/2005 14:14:17> UPnP Action:AddPortMapping State:Success. TCP-port:18712 Opened!
06/26/2005 14:14:17> UPnP Action:DeletePortMapping State:Success. TCP-port:18712 Closed!
06/26/2005 14:14:18> DNS WAN auto connection attempt.
06/26/2005 14:14:19> DNS WAN auto connection attempt.
06/26/2005 14:14:23> DNS WAN auto connection attempt.
06/26/2005 14:14:24> DNS WAN auto connection attempt.
06/26/2005 14:18:08> DNS WAN auto connection attempt.
06/26/2005 14:21:01> DNS WAN auto connection attempt.
06/26/2005 14:21:15> DNS WAN auto connection attempt.
06/26/2005 14:21:16> DNS WAN auto connection attempt.
06/26/2005 14:21:17> DNS WAN auto connection attempt.
06/26/2005 14:21:20> DNS WAN auto connection attempt.
06/26/2005 14:21:32> Send UPnP Connected
06/26/2005 14:23:17> DNS WAN auto connection attempt.
06/26/2005 14:23:18> DNS WAN auto connection attempt.
06/26/2005 14:23:19> DNS WAN auto connection attempt.
06/26/2005 14:24:52> sip: port limit exceeded
06/26/2005 14:25:03> Send UPnP Connected
06/26/2005 14:30:02> sip: port limit exceeded
06/26/2005 14:30:03> sip: port limit exceeded
06/26/2005 14:30:42> sip: port limit exceeded
06/26/2005 14:31:58> sip: port limit exceeded
06/26/2005 14:32:10> Send UPnP Connected
06/26/2005 14:32:37> sip: port limit exceeded
06/26/2005 14:39:34> sip: port limit exceeded
06/26/2005 14:39:35> sip: port limit exceeded
06/26/2005 14:39:37> sip: port limit exceeded
06/26/2005 14:39:41> sip: port limit exceeded
06/26/2005 14:40:14> sip: port limit exceeded
06/26/2005 14:40:16> DNS WAN auto connection attempt.
06/26/2005 14:40:17> DNS WAN auto connection attempt.
06/26/2005 14:40:19> DNS WAN auto connection attempt.
06/26/2005 14:40:20> DNS WAN auto connection attempt.
06/26/2005 14:40:21> DNS WAN auto connection attempt.
06/26/2005 14:40:22> DNS WAN auto connection attempt.
06/26/2005 14:40:23> DNS WAN auto connection attempt.
06/26/2005 14:40:24> DNS WAN auto connection attempt.
06/26/2005 14:46:20> DNS WAN auto connection attempt.
06/26/2005 14:46:22> sip: port limit exceeded
06/26/2005 14:46:24> sip: port limit exceeded
06/26/2005 14:46:28> sip: port limit exceeded
06/26/2005 14:46:36> Send UPnP Connected
06/26/2005 14:51:09> DNS WAN auto connection attempt.
06/26/2005 14:51:10> DNS WAN auto connection attempt.
06/26/2005 14:52:21> DNS WAN auto connection attempt.
Endret av taz
