Warrior lvl 40 talents. hvor skal jeg putte de?
Heisann.
Jeg er nå en lvl 33 human warrior. Jeg er atm fury DW specced, jeg synes jeg grinder fortere med det en med en 2h. Bruker 2 Jade serpentblades. Jeg har 1600ish hp. funker kjempe fint i pve, pvp bryr jeg meg ikke om enda(ikke før lvl 40).
Men jeg skal specce Arms på lvl 40 med MS. Så det jeg lurer på er; hvor skal jeg sette talent poengene for komme opp til MS? Mortal strike kommer til og bli rage dumpen, sammen med overpower og whirlwind.
Så hvilke talents støtter disse bra?
Jeg tenkte kanskje på og prøve denne her:
Axe Specialization
Rank 5/5
Increases your chance to get a critical strike with Axes by 5%.
Impale
Rank 2/2
Increases the critical strike damage bonus of your abilities in Battle, Defensive, and Berserker stance by 20%.
Tactical Mastery
Rank 5/5
You retain up to 25 of your rage points when you change stances.
Sweeping Strikes
Rank 1/1
30 Rage
Instant 30 sec cooldown
Requires Melee Weapon
Requires Battle Stance
Your next 5 melee weapon swings strike an additional nearby opponent.
Deflection
Rank 5/5
Increases your Parry chance by 5%.
Improved Charge
Rank 2/2
Increases the amount of rage generated by your Charge ability by 6.
Deep Wounds
Rank 3/3
Your critical strikes cause the opponent to bleed, dealing 60% of your melee weapon's average damage over 12 sec.
Mortal Strike
Rank 1/1
30 Rage 5 yd range
Instant 6 sec cooldown
A vicious strike that deals weapon damage plus 85 and wounds the target, reducing the effectiveness of any healing by 50% for 10 sec.
Improved Hamstring
Rank 2/2
Increases the movement slow effect of your Hamstring ability by 10%.
Improved Overpower
Rank 2/2
Increases the critical strike chance of your Overpower ability by 50%.
Improved Rend
Rank 3/3
Increases the bleed damage done by your Rend ability by 35%.
Arms Total: 31
Total Points Spent: 31
Level Required: 40
Kommentarer? Helst med begrunnelse.
Ja det kan jeg, men jeg ser ikke hvordan det kan hjelpe meg som er fury DW specced?
(er ikke frekk på noen måte ;))
Edit: nå som jeg ser på det så virket det ikke frekt allikevel hehe
Endret av Nstin
Hvis du skal være dualwield warrior, så har det vel liten hensikt å være Arms ? :|
Riktig.
Men jeg skal ikke være dualwield warrior når jeg respeccer til arms :)
Men, noen som faktisk vil kommentere builden min? hehe
Riktig.
Bra build, men jeg tror jeg ville tatt ett poeng fra improved hamstring, og satt det i anger management. Deretter går du fury til du får piercing howl, som koster det samme som hamstring men virker mye bedre (AoE og ranged)
Riktig.
Grei build det der, men jeg ville tatt 5% mer skade på 2hand våpen hvis du faktisk skal bruke 2hand da :p
De 5 talents pointsa i 2hand spec er ikke verdt det..
Stemmer. Sett de poenga i fury..
Blir litt vanskelig, siden han uansett må ha 5points et sted hvis han skal ha MS
Eh.. nei. 2h spesialisation er ikke med i 31/20 buildet. Vil du ha 2h spes. i tillegg, må du ofre 5 poeng i fury.
Edit: Om du ser på trådstarters første post, er der et omtrent korrekt arms build, uten 2h spec.
Endret av likferd
Det jeg mente var om du kunne forklare meg hvordan han skal få mortal strike med 26 points i arms ;)
Han får uansett ikke MS før level 40, men det eneste han oppnår med å sette poeng i 2h spes. er å måtte respecce igjen, når han finner ut at "enrage" i fury er verdt gull..
