program for å lage bilder i notepad
n0ob
flere plasser, spesielt i følge med "ulovlige" bittorrent nedlastninger, så starter de info filen med ett slags bilde, se vedlegg for eksempel.
det jeg lurer på er: hvordan i alle dager lager de disse bildene?
Jeg har klarer ikke å forestille meg at det sitter en fyr og taster inn hvert enkelt tegn, eller?
bilde.txt
har tegna litt i Notepad selv jeg på egenhånd. det var ganske morsomt, men det tar sin tid. man kan bruke hvilke som helst tegn egentlig. husker ikke helt hvilke tegn jeg brukte da men. det som lønner seg når man holder på med slike ting som å tegne i Notepad er å høre på musikk, da går tiden fortere :)
Må bare poste en jeg fant en gang:
                         8888  8888888
                 888888888888888888888888
              8888:::8888888888888888888888888
            8888::::::8888888888888888888888888888
           88::::::::888:::8888888888888888888888888
         88888888::::8:::::::::::88888888888888888888
       888 8::888888::::::::::::::::::88888888888   888
          88::::88888888::::m::::::::::88888888888    8
        888888888888888888:M:::::::::::8888888888888
       88888888888888888888::::::::::::M88888888888888
       8888888888888888888888:::::::::M8888888888888888
        8888888888888888888888:::::::M888888888888888888
       8888888888888888::88888::::::M88888888888888888888
     88888888888888888:::88888:::::M888888888888888   8888
    88888888888888888:::88888::::M::;o*M*o;888888888    88
   88888888888888888:::8888:::::M:::::::::::88888888    8
  88888888888888888::::88::::::M:;:::::::::::888888888
 8888888888888888888:::8::::::M::aAa::::::::M8888888888       8
 88   8888888888::88::::8::::M:::::::::::::888888888888888 8888
88  88888888888:::8:::::::::M::::::::::;::88:88888888888888888
8  8888888888888:::::::::::M::"@@@@@@@"::::8w8888888888888888
 88888888888:888::::::::::M:::::"@a@":::::M8i888888888888888
8888888888::::88:::::::::M88:::::::::::::M88z88888888888888888
8888888888:::::8:::::::::M88888:::::::::MM888!888888888888888888
888888888:::::8:::::::::M8888888MAmmmAMVMM888*88888888   88888888
888888 M:::::::::::::::M888888888:::::::MM88888888888888   8888888
8888   M::::::::::::::M88888888888::::::MM888888888888888    88888
888   M:::::::::::::M8888888888888M:::::mM888888888888888    8888
 888  M::::::::::::M8888:888888888888::::m::Mm88888 888888   8888
  88  M::::::::::::8888:88888888888888888::::::Mm8   88888   888
  88  M::::::::::8888M::88888::888888888888:::::::Mm88888    88
  8   MM::::::::8888M:::8888:::::888888888888::::::::Mm8     4
      8M:::::::8888M:::::888:::::::88:::8888888::::::::Mm    2
     88MM:::::8888M:::::::88::::::::8:::::888888:::M:::::M
    8888M:::::888MM::::::::8:::::::::::M::::8888::::M::::M
   88888M:::::88:M::::::::::8:::::::::::M:::8888::::::M::M
  88 888MM:::888:M:::::::::::::::::::::::M:8888:::::::::M:
  8 88888M:::88::M:::::::::::::::::::::::MM:88::::::::::::M
    88888M:::88::M::::::::::*88*::::::::::M:88::::::::::::::M
   888888M:::88::M:::::::::88@@88:::::::::M::88::::::::::::::M
   888888MM::88::MM::::::::88@@88:::::::::M:::8::::::::::::::*8
   88888  M:::8::MM:::::::::*88*::::::::::M:::::::::::::::::88@@
   8888   MM::::::MM:::::::::::::::::::::MM:::::::::::::::::88@@
    888    M:::::::MM:::::::::::::::::::MM::M::::::::::::::::*8
    888    MM:::::::MMM::::::::::::::::MM:::MM:::::::::::::::M
     88     M::::::::MMMM:::::::::::MMMM:::::MM::::::::::::MM
      88    MM:::::::::MMMMMMMMMMMMMMM::::::::MMM::::::::MMM
       88    MM::::::::::::MMMMMMM::::::::::::::MMMMMMMMMM
        88   8MM::::::::::::::::::::::::::::::::::MMMMMM
         8   88MM::::::::::::::::::::::M:::M::::::::MM
             888MM::::::::::::::::::MM::::::MM::::::MM
            88888MM:::::::::::::::MMM:::::::mM:::::MM
            888888MM:::::::::::::MMM:::::::::MMM:::M
           88888888MM:::::::::::MMM:::::::::::MM:::M
          88 8888888M:::::::::MMM::::::::::::::M:::M
          8  888888 M:::::::MM:::::::::::::::::M:::M:
             888888 M::::::M:::::::::::::::::::M:::MM
            888888  M:::::M::::::::::::::::::::::::M:M
            888888  M:::::M:::::::::@::::::::::::::M::M
            88888   M::::::::::::::@@:::::::::::::::M::M
           88888   M::::::::::::::@@@::::::::::::::::M::M
          88888   M:::::::::::::::@@::::::::::::::::::M::M
         88888   M:::::m::::::::::@::::::::::Mm:::::::M:::M
         8888   M:::::M:::::::::::::::::::::::MM:::::::M:::M
        8888   M:::::M:::::::::::::::::::::::MMM::::::::M:::M
       888    M:::::Mm::::::::::::::::::::::MMM:::::::::M::::M
     8888    MM::::Mm:::::::::::::::::::::MMMM:::::::::m::m:::M
    888      M:::::M::::::::::::::::::::MMM::::::::::::M::mm:::M
 8888       MM:::::::::::::::::::::::::MM:::::::::::::mM::MM:::M:
            M:::::::::::::::::::::::::M:::::::::::::::mM::MM:::Mm
           MM::::::m:::::::::::::::::::::::::::::::::::M::MM:::MM
           M::::::::M:::::::::::::::::::::::::::::::::::M::M:::MM
          MM:::::::::M:::::::::::::M:::::::::::::::::::::M:M:::MM
          M:::::::::::M88:::::::::M:::::::::::::::::::::::MM::MMM
          M::::::::::::8888888888M::::::::::::::::::::::::MM::MM
          M:::::::::::::88888888M:::::::::::::::::::::::::M::MM
          M::::::::::::::888888M:::::::::::::::::::::::::M::MM
          M:::::::::::::::88888M:::::::::::::::::::::::::M:MM
          M:::::::::::::::::88M::::::::::::::::::::::::::MMM
          M:::::::::::::::::::M::::::::::::::::::::::::::MMM
          MM:::::::::::::::::M::::::::::::::::::::::::::MMM
           MM:::::::::::::::M::::::::::::::::::::::::::MMM
            M:::::::::::::::M:::::::::::::::::::::::::MMM
            MM:::::::::::::M:::::::::::::::::::::::::MMM
             M:::::::::::::M::::::::::::::::::::::::MMM
             MM:::::::::::M::::::::::::::::::::::::MMM
              M:::::::::::M:::::::::::::::::::::::MMM
              MM:::::::::M:::::::::::::::::::::::MMM
               M:::::::::M::::::::::::::::::::::MMM
               MM:::::::M::::::::::::::::::::::MMM
                MM::::::M:::::::::::::::::::::MMM
                MM:::::M:::::::::::::::::::::MMM
                 MM::::M::::::::::::::::::::MMM
                 MM:::M::::::::::::::::::::MMM
                  MM::M:::::::::::::::::::MMM
                  MM:M:::::::::::::::::::MMM
                   MMM::::::::::::::::::MMM
                    M:::::::::::::::::MMM
                   MM::::::::::::::::MMM
                   MM::::M:::::::::MMM:
                   mMM::::MM:::::::MMMM
                    MMM:::::::::::MMM:M
                    mMM:::M:::::::M:M:M
                     MM::MMMM:::::::M:M
                     MM::MMM::::::::M:M
                     mMM::MM::::::::M:M
                      MM::MM:::::::::M:M
                      MM::MM::::::::::M:m
                      MM:::M:::::::::::MM
                      MMM:::::::::::::::M:
                      MMM::::::::::::::::Mm
                       MMM:::::::::::::::MM
                        MM::::::::::::::MMM
                        MMM:::::::::::::MM
                        MMM:::::::::::::MM
                        MMM::::::::::::MM
                         MM::::::::::::MM
                         MM::::::::::::MM
                         MM:::::::::::MM
                         MMM::::::::::MM
                         MMM::::::::::MM
                          MM:::::::::MM
                          MMM::::::::MM
                          MMM::::::::MM
                           MM::::::::MM
                           MMM::::::MM
                           MMM::::::MM
                            MM::::::MM
                            MM::::::MM
                             MM:::::MM
                             MM:::::MM:
                             MM:::::M:M
                             MM:::::M:M
                             :M::::::M:
                            M:M:::::::M
                           M:::M::::::M
                          M::::M::::::M
                         M:::::M:::::::M
                        M::::::MM:::::::M
                        M:::::::M::::::::M
                        M;:;::::M:::::::::M
                        M:m:;:::M::::::::::M
                        MM:m:m::M::::::::;:M
                         MM:m::MM:::::::;:;M
                          MM::MMM::::::;:m:M
                           MMMM MM::::m:m:MM
                                 MM::::m:MM
                                  MM::::MM
                                   MM::MM
:love:
er masse sånne småprogrammer som kan gjøre om bilder til ascii...det blir veldig lett veldig!!! store teks filer da...for om et bilde er 1024/768 så blir det veldig veldig mange tegn :)
(Ascii Pic v2.0 (converts .bmp and .jpg into ascii art).zip)
google etter den filen ellerno...
Men de logoene deres lager vel de muligens manuelt ellerno...ikke vet jeg :)
Meg:
EDIT: Prøvde å legge ut "tekstbilde" av meg i tråden, men d gikk ikke så bra..
Jaggu.. Den burde du nesten poste i "Recent Pic Post" tråden.
