VPU Recover - Nullstilt din grafikkakselerator
CurSe
Fikk denne opp for første gang i går da jeg spilte WCIII online. Etter at den kom opp så kan jeg ikke spille spill lenger, jeg får da opp den meldingen som dere ser på bildet. Hvordan fikser jeg dette problemet?
Endret av CurSe
Lykke til, sett over kaffen :thumbup:
"Troubleshooting ATI VPU Recover
This issue affects the following system configurations:
Windows XP
Any ATI display card
Based on our experience, the error "The drivers for the display adapter got stuck in an INFINITE LOOP" is a result of a system communication mishap. On some systems, the error "Unable to complete a drawing operation", or an ATI VPU recover error may also occur.
This error does not occur on all system configurations.
This issue can occur using any motherboard or graphics chipset along with the Windows XP Operating system. It appears that in most cases this problem is due to a BIOS setting, specifically options affecting the way the RAM, CPU and graphics card communicate with XP and DirectX. Improper timing settings can result in system lock ups or random system reboots.
This issue also affects different makes and models of video cards from various manufacturers.
In attempt to gather more information on why this error occurs, ATI developed a component to catch when the INFINITE LOOP occurs. This component is called VPU Recover. If the display driver detects that the graphics processor has hung, VPU Recover will attempt to reset the graphics processor, eliminating the need for a system reboot.
VPU errors can occur mostly while using 3D applications and games. This error has also been known to occur in 2D applications as well.
This error message may occur in the virtual video adapter driver that is used by Symantec PCAnywhere. If PCAnywhere is installed on a computer where this error message occurs, visit the Symantec Web site to determine if there are any available fixes for your version of PCAnywhere.
At the present time ATI is still gathering information on the Infinite Loop condition.
The following suggestions may help to correct this issue:
Verify that the system has updated software
Adjust basic settings within the system BIOS
Adjust advanced settings with the system BIOS
Test with different hardware configurations
1. Verifying that the system has updated software
a) Update the display drivers.
Ensure that you have installed the latest ATI CATALYST software for your ATI product. Drivers for your video card can be found on the ATI website.
Ensure that all three DirectX Features are enabled.
Run the available tests to ensure that each of the three components pass. More information on Direct X features and tests can be found on the ATI website at the following address: http://www.ati.com/support/infobase/dxdiag...uresupport.html
c) Update your motherboard chipset driver software.
Updating your AGP chipset drivers can add stability to the PC and may help to prevent the Infinite Loop error from occurring. More information on AGP Motherboard/Chipset Drivers can found on the ATI website at the following address: http://ati.com/support/faq/agpchipsetdrivers.html
d) Use the ATI SMARTGART utility to adjust AGP Reads/Writes.
In newer revisions of the Catalyst Drivers, a feature called SMARTGART was introduced. With the latest ATI CATALYST software installed, you can use the ATI SMARTGART settings to adjust the Fast Writes and AGP BUS speed.
Select the "Start" menu -> click on "RUN" -> type "SMARTGART" -> click OK.
Ensure that both the AGP Read and Write settings are On. If these are set to OFF, then enable them and restart Windows as prompted. As a test you should try disabling the AGP Write setting. NOTE- AGP Writes may not be enabled on all chipsets.
e) Update the motherboard BIOS. Any updates can be found on the motherboard manufacturer's website.
f) Make sure you have an adequate power supply.
2. Basic BIOS options.
NOTE: These options may vary depending on the type/version of your system. You may or may not have all these options present.
Video BIOS Shadow - DISABLED
Init Primary Display - AGP (Toggle this setting if your video card is PCI)
AGP MASTER 1W/S READ/WRITE - ENABLED/DISABLED (Toggle this option)
AGP Aperture size - 128 MB
AGP Driving Control - AUTO
Disable AGP 8x/4x mode in the BIOS.
Disable AGP Fast Writes in the BIOS.
AGP Performance Control - ENABLED/DISABLED (Toggle this option)
Assign IRQ for VGA - ENABLED
System Bios Cacheable - DISABLED
Video BIOS Cacheable - DISABLED
VIDEO RAM Cacheable - DISABLED
Read Around Write - ENABLED/DISABLED (toggle this setting)
PnP OS installed - YES
3. BIOS Settings for ADVANCED USERS:
NOTE: These options may vary depending on the type/version of your system. You may or may not have all these options.
Load optimized defaults in your BIOS
Set your memory settings to default values (I.e.. DRAM Timing = SPD)
Lower the memory frequency to 133/166mhz (effectively DDR266/333mhz)
If available increase AGP Voltage to 1.6 - 1.8 in the BIOS
SDRAM Cycle length - 2.5
Bank Interleave - ENABLE/DISABLE (toggle this setting - It will only make a difference if you have more than one memory module.)
DRAM Burst length - 4
4. Recommended Hardware changes:
Test system with a single memory module if multiples are being used
Test with different memory modules.
Test with a different Power supply
Disable/Remove ALL non-essential hardware i.e. sound card, network card, additional HDD etc.
Test the video card in a different PC"
Har oppdatert BIOS og installert de nyeste driverne til skjermkortet. Har også oppgradert til SP2 og andre diverse windowsoppdateringer, men alt er fremdeles feil. Det jeg ikke skjønner er at jeg har spilt problemfritt i nesten 1 år på pc'n, men for så å plutselig få opp den VPU Recover greia. Har ikke installert noe nytt som kan kludre dette til.
Edit: Når jeg installerer de nye skjermkortdriverne så finner pc'n ny maskinvare. Den er "ukjent" og den finner ikke noe egnet programvare på driver cd'n som fulgte med datamaskinen eller når jeg ber den koble seg til internett for å se om den finner noe som egner seg. Kan det rett og slett være at kortet synger på siste verset?
Edit2: Etter å ha trålet internett en god stund så sier mange at det er driverne som er problemet. Det som da er litt rart er at alt har funket fint i 1 år med de driverne jeg hadde. Har som tidligere nevnt at jeg har oppdater driverne etter at jeg fikk problemet, men det hjalp ikke. Var også noen som sa noe om at ATI kort ikke gikk sammen med VIA Chipset, kan det stemme?
Edit 3:
Hvordan finner jeg ut av det? Aner ikke hvor stor strømforsyningen er og hvis jeg husker rett så står det heller ikke i brosjyren som vi bestilte fra. Jeg kan heller ikke åpne kabinettet for da ryker garantien.
Edit 4: Fant heller ikke noe i BIOS som kunne ligne på det som sto i den guiden som zjulik postet.
Endret av CurSe
Legger ved et nytt vedlegg hvor det står litt av hvert om datamaskinen, en Scaleo800. Sånn som jeg tolket dette skjemaet så står det at jeg har en 300w strømforsyning. Er ikke det en anelse lite?
Edit: Vet ikke om dette er viktig, men jeg poster det uansett:
ActiveX-Version: 3.0.0.6
Motherboard: D1607
Other components
Other components
    Driver vendor: not available
    Driver version: not available
    Driver date: not available
Diskettkontrollere
  Standard diskettkontroller
    Driver vendor: Microsoft
    Driver version: 5.1.2600.0
    Driver date: 7/1/2001
Enheter for menneskelig grensesnitt
  USB-enhet for menneskelig grensesnitt
    Driver version: 5.1.2600.1106
IDE ATA/ATAPI-kontrollere
  VIA Bus Master IDE-kontroller
IEEE 1394-bussvertskontrollere
  OHCI-kompatibel IEEE 1394-vertskontroller
    Driver version: 5.1.2535.0
Lyd-, video- og spillkontrollere
  Creative Audigy Audio Processor (WDM)
    Driver vendor: Creative
    Driver version: 5.12.4.442
    Driver date: 2/19/2004
  Creative Game Port
    Driver version: 1.0.0.0
    Driver date: 1/29/2003
Modemer
  Smart Link 56K Modem
    Driver vendor: Smart Link (www.smlink.com)
    Driver version: 3.40.3.410
    Driver date: 8/20/2003
Nettverkskort
  ADMtek AN983 10/100Mbps PCI Adapter
    Driver vendor: ADMtek Incorporated
    Driver version: 2.21.418.2003
    Driver date: 4/18/2003
  Eicon Diva USB 2.01 S/T
    Driver vendor: Eicon Networks
    Driver version: 3.5.103.205
    Driver date: 1/22/2003
Porter (COM og LPT)
  ECP-skriverport
  Kommunikasjonsport
Prosessorer
  AMD Athlon64 Processor
    Driver vendor: Advanced Micro Devices
    Driver version: 1.1.0.0
    Driver date: 10/16/2003
SCSI- og RAID-kontrollere
  VIA SATA RAID Controller
    Driver vendor: VIA Technologies, Inc.
    Driver version: 5.1.2600.430
    Driver date: 4/8/2005
Skjermer
  Plug and Play-skjerm
    Driver version: 5.1.2001.0
    Driver date: 6/6/2001
Skjermkort
  RADEON 9800 SERIES
    Driver vendor: ATI Technologies Inc.
    Driver version: 6.14.10.6542
    Driver date: 5/12/2005
  RADEON 9800 SERIES - Secondary
Systemenheter
  Verts-CPU-bro av PCI-standard
  VIA Standard Host Bridge
    Driver version: 5.1.0.240
    Driver date: 10/2/2002
  VIA Standard PCI to ISA Bridge
  VIA CPU to AGP2.0/AGP3.0 Controller
    Driver version: 5.1.0.3442
    Driver date: 7/2/2003
  ACPI-knapp for fast funksjon
  Programmerbar avbruddskontroller
  Tidtaker
  Kontroller for direkte minnetilgang (DMA)
  Systemhøyttaler
  PCI-buss
  Standardbuss
  CMOS/sanntidsklokke
  Ressurser på hovedkortet
  Matematikkprosessor
  ACPI-strømforsyningsknapp
Tastatur
  Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Universal seriell busskontroller
  VIA versjon 5 eller senere USB universell vertskontroller
  VIA USB 2.0 Enhanced Host Controller
    Driver date: 9/9/2002
  USB rothub
  USB rothub
  USB rothub
  USB rothub
  USB-rothub
  Støtte for USB-utskrift
  USB-enhet (sammensatt)
  USB-masselagringsenhet
Endret av CurSe
Hadde det same problemet med midt Ati Radeon 9800 pro kort. Etter ca 1år spilling, fikk jeg same feil mld. Prøvde reinstallasjon, forskjellige cpuer, psuer også videre. Fikk et tips av en kompiss, han hadde opplevd liknende, kjøpte ny vifte til radeon korte mitt, og vips, alt var i orden igjen :)
har hatt samme problem! det du gjør er å deaktivere vpu!
stikk inn på: --> kontrollpanel-->skjerm-->instillinger-->avansert-->vpu recover også tar du og deaktiverer det! du bare tar vekk haken som står der!
vel å deaktivere vpu løser sjelden problemet. Det du sitter igjen med da er en pc som er "låst" og som krever en omstart for å fungere igjen. Heller løs det som EGENTLIG er problemet, nemlig drivere, bios, strømmangel, overoppheting etc. etc. etc. ikke selve VPU recovery funksjonen.
Har prøvd å deaktivere VPU Recover, men det endte bare med at alt låste seg. Hvordans sjekker man temperaturen på kortet? Lastet ned ATI Tray Tools, men jeg finner ikke ut hvordan man får fram temperatur. Kabinettet er beskyttet med et garantisegl så jeg kan ikke åpne kabinettet og kun sende inn skjermkortet. Pc'n er litt over 1 år gammel, har jeg fremdeles garanti? Brosjyrene for datamaskinen finner jeg ikke, så jeg vet ikke om jeg fremdeles har garanti på delene. Skal ringe support telefonen til Fujitsu Siemens i morgen.
Garanti er en frivillig sak som produsenter som regel gir. Hvor lenge garantien gjelder og hvilke vilkår den inneholder er også helt opp til produsenten. Garantivilkårene skal følge med da du kjøpe PCen og krever som som regel kvittering for å dokumentere kjøpsdatoen, så du bør nok lete litt ekstra. Jeg anser i hvertfall det å ta vare på papirene som ganske viktig.
En helt annen ting er reklamasjon. Dette er ikke noe frivillige saker fra produsenten, men er lovfestet for alle selgere innen norge. Reklamasjon på hele PCer er 5 år, så den gjelder absolutt fortsatt. Men om du har overklokket noe så vil den ikke gjelde de overklokkede delene. Siden dette er vanskelig/umulig å påvise og det er selgers ansvar å bevise at det er brukerfeil så er dette noe mange omgår. (Man bør selvfølgelig ikke svindle til seg uberettiget reklamasjon)
Ringte supporttelefonen nettopp og de ba meg bruke recovery cd'n som fulgte med datamaskinen. Hvis ikke det fikset problemet så kunne jeg sende inn hele greia, så garantien gjelder ennå:thumbup: .
Før jeg gjør det så hadde det vært fint hvis noen forklarte meg hvordan jeg finner ut temperaturen på skjermkortet. Har lastet ned ATI Tray Tools, men jeg får ikke til å få fram temperaturgrafen.
Har Radeon 9800PRO.
Endret av CurSe
Edit 3:
hehe...
det er lyse som har laggt opp fiberoptisk nettverk inne i spillet ditt :p
neida...
jeg har hatt de samme problemene som deg, du har samme chipset som meg og, og ATI skjermkort...
to løsninger:
1:bytt skjermkort til GeForce (slik som jeg gjorde, til et 6800 kort)
2: last ned ATITool, og sett agp speeden til 4x
Har du prøvd å rengjøre vifta på skjermkortet. Det kan være så enkelt at det er for mye støv i kjøleren, så den ikkje virker godt nok lenger.
Kan desverre ikke åpne kabinettet for da ryker garantien. Det er festet en strips lignende ting på kabinettet og den må man klippe av for å åpne kabinettet. Har prøvd å sette AGP til 4x, men det funket ikke det heller.
