Error ved innstallering av Sp1
Edit: Når jeg leser gjennom posten din igjen så fortjener jeg vel en slag i hodet...
Uansett, prøv recoverykonsollet og prøv fixboot kommandoen. Du bør også muligens søke for virus og spyware mens du er i gang i tilfelle.
Leser du aldri gjennom ting du finner?
Fra: http://support.microsoft.com/default.aspx?...kb;en-us;327101
CAUSE
This behavior may occur if your computer has a modified version of the Ntoskrnl.exe file that uses the /KERNEL switch in the Boot.ini file. This condition may exist because your computer has a third-party program installed that customizes the graphics that are displayed when your computer starts up. Third-party programs that can cause this condition include the following:
• BootXP
• LogonUI Boot Randomizer
RESOLUTION
To resolve this problem, follow these steps:
1. Click OK to close the error message.
2. Click Start, click Run, and then type appwiz.cpl in the Open box.
3. Click the program that customizes the startup graphics, and then click Remove.
4. Restart your computer, and then try to install the Service Pack again. If the problem persists, go to step 5.
5. On the desktop, right-click My Computer, and then click Properties.
6. Click the Advanced tab, and then click Settings under Startup and Recovery.
7. Under System Startup, click Edit.
The Boot.ini file opens in Notepad.
8. Locate and then delete the /KERNEL= switch.
9. Save and then close the Boot.ini file.
10. Restart your computer.
11. Try to install the Windows XP Service Pack.
Står da ganske svart på hvit der da...
Endret av TCi
