Crayven Skrevet 12. juni 2005 Del Skrevet 12. juni 2005 (endret) Ser disse delen greie ut??? eller e eg helt ute å kjører??? Asus A8N-SLI, nForce4 SLI,Socket-939 ATX,S-ATA, GbLAN,Firewire,DDR, PCI-Ex16 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chenbro Gaming Box Black/Orange 350W Strømforsyning -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- NEC DVD recorder ND-3540A IDE Black OEM DVD+R/+RW/DVD-R/-RW (Dual layer) -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Corsair Value S PC3200 DDR-DIMM 1024MB Kit w/two matched Value Select 512MB -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- AMD Athlon 64 3500+ 2.2GHz Socket 939, 512KB, BOXED m/vifte -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Sapphire Radeon X800 256MB GDDR3 PCI-Express, Tv-Out, DVI-I, Full-Retail -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Seagate Barracuda 7200.8 250GB SATA 8MB 7200RPM NCQ -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- e ikkje helt sikker på vifter o.l så råd tas gjerne imot.... Takk på forhånd!! Endret 12. juni 2005 av Crayven Lenke til kommentar
BazeLaze Skrevet 12. juni 2005 Del Skrevet 12. juni 2005 Asus A8N-SLI, nForce4 SLI,Socket-939 ATX,S-ATA, GbLAN,Firewire,DDR, PCI-Ex16 <----- 100% unødvendig å bruke ekstra penger på SLI når du kjøper et skjermkort som ikke støtter denne funksjonen. Kom med et busjett så kan vi nok hjelpe deg mer! Lenke til kommentar
Crayven Skrevet 12. juni 2005 Forfatter Del Skrevet 12. juni 2005 (endret) Takker....tenkte å bruke rundt 10 tusen.... Siden det e unødvendig å kjøpe det hket...kan du anbefalle noen andre då?? Endret 12. juni 2005 av Crayven Lenke til kommentar
BazeLaze Skrevet 12. juni 2005 Del Skrevet 12. juni 2005 (endret) Gigabyte K8NXP-9 nForce4 Ultra 1 550,00 Hitachi Deskstar T7K250 250GB SATA2 1 150,00 Arctic Cooling Silentium T1 795,00 OCZ 512MB EL Platinum Edition R2 1 790,00 AMD Athlon 64 3500+ 2.2 GHz BOXED 2 190,00 PowerColor Radeon X850PRO 256MB PCIe 2 995,00 Totalt: 10 470 dette ble satt sammen i all hast, men skulle tro dette opsettet vil fungere fint Edit: hentet fra netshop.no Endret 12. juni 2005 av BazeLaze Lenke til kommentar
BazeLaze Skrevet 12. juni 2005 Del Skrevet 12. juni 2005 http://www.vendur.no/catalog/product_info....&products_id=68 <---- flotte vifter til kabinettet, bråker lite og kjøler bra! Lenke til kommentar
Crayven Skrevet 12. juni 2005 Forfatter Del Skrevet 12. juni 2005 sweet....takker... Lenke til kommentar
BazeLaze Skrevet 12. juni 2005 Del Skrevet 12. juni 2005 Må nevnes at rammen er det dobbelt opp med, altså 2x OCZ 512MB EL Platinum Edition R2 som koster 895,- per stk. Lenke til kommentar
Spirre Skrevet 12. juni 2005 Del Skrevet 12. juni 2005 forslaget til bazelaze er veldig bra det, jeg hadde valgt et annet harddisk merke, mene det er smak og behag Lenke til kommentar
BazeLaze Skrevet 12. juni 2005 Del Skrevet 12. juni 2005 På merket av disk så leste jeg en test med Sata1 vs Sata2 hvor denne disken kom ekstremt bra ut med tanke på ytelse og bråk, spesielt i raid 0. Men som du sier: "smak og behag". Jeg har ikke prøvd en slik disk og skal dermed ikke si imot diverse negative opplevelser en kunna ha fått med bruk av disken. Lenke til kommentar
Kenneth Dammyr Skrevet 12. juni 2005 Del Skrevet 12. juni 2005 Hei og velkommen til forumet! Jeg foreslår at du leser retningslinjene og sticky i denne kategorien. Der kan du lese om emnetitteler. Den tittelen du har her er ikke god nok. Hvis ikke den endres blir jeg nødt til å stenge tråden. Husk dette til neste gang og lykke til videre Vennligst ikke kommenter dette innlegget Lenke til kommentar
BazeLaze Skrevet 12. juni 2005 Del Skrevet 12. juni 2005 http://netshop.no/aspx/prdinfo.aspx?plid=6959 <----- tenker denne brenneren skal fungere greit Lenke til kommentar
Simon Aldra Skrevet 14. juni 2005 Del Skrevet 14. juni 2005 NEC-brennere er good shit Eneste jeg kan se på stående fot er at jeg personlig ville gått for en Maxtor DiamondMax 10 250GB 7200RPM 16MB Cache. Cache er bra for OS-disk, og har gode erfaringer med DiamondMax 10-disker. Lenke til kommentar
MacManus Skrevet 14. juni 2005 Del Skrevet 14. juni 2005 Gigabyte K8NXP-9 nForce4 Ultra1 550,00 Hitachi Deskstar T7K250 250GB SATA2 1 150,00 Arctic Cooling Silentium T1 795,00 OCZ 512MB EL Platinum Edition R2 1 790,00 AMD Athlon 64 3500+ 2.2 GHz BOXED 2 190,00 PowerColor Radeon X850PRO 256MB PCIe 2 995,00 Totalt: 10 470 dette ble satt sammen i all hast, men skulle tro dette opsettet vil fungere fint Edit: hentet fra netshop.no Dette høres ganske bra ut men gå heller for X800XL, det er billigere og bedre. Lenke til kommentar
