Forumets fly- og bildetråd!
Avro (RJ85 eller RJ100)? SAS selskap dette.
Har ikke noe legge opp, så isteden lurer jeg på hva var den første militære maskinen som fløy over Alpene?
Har leita etter denne maskinen på nettet, husker selvfølgelig ikke navnet.
Maskinen er en 4 Turbopropp? proppeller, Russisk maskin fra 50/60 tallet.
Faktisk en meget flott sak.
Kan det være forgjengeren til "kjehaako" bidrag?
Endret av Vetlite
Sakser kjapt fra wikipedia:
The BAe 146 (also known as the Avro RJ) is a medium-sized commercial aircraft manufactured by BAE Systems.
Hawker Siddeley Aviation carried out the original design in 1973 using the designation HS146, but soon abandoned the project as a result of the world economic downturn resulting from the oil crisis. Low-key development proceeded, however, and in 1978 British Aerospace, Hawker Siddeley's corporate successor, re-launched the project.
Production began in 1983 with the series 100, carrying 70 - 84 passengers, and ended during the 2001 world slump in the aviation market.
The type name "Avro RJ" superseded "BAe 146" in 1993 in a new joint venture. The Avro RJ comes in three sizes: for 70, 85 and 100 passengers. All three sizes have the same cockpit, engines and operations. Turbofan engines from Honeywell Inc., housed in newly designed nacelles, replaced the original Lycoming engines. Production of this aircraft has ended with the final four aircraft being delivered in October/November 2003. Many airlines will replace the Avro/BAe with the Boeing 717, Airbus A318, Bombardier CRJ 700, or EMBRAER models such as the EMBRAER 170 and EMBRAER 190.
The Avro RJ family of aircraft was built at the BAE Systems Regional Aircraft Centre at the historic Avro Airfield at Woodford in England. 166 Avro RJ aircraft were delivered between 1993 and 2002.
