Edmund Blackadder Skrevet 12. juni 2005 Del Skrevet 12. juni 2005 Hei! Jeg skal nå oppgradere ATI Catalyst Driveren min. Men er det veldig viktif å slette den gamle driveren først`? Tusen takk for et forhåpentligvis raskt svar. Lenke til kommentar
borgz Skrevet 12. juni 2005 Del Skrevet 12. juni 2005 (endret) Uninstalling the ATI Control Panel and Display Driver This section provides information on uninstalling the previous versions of your ATI Control Panel and ATI Display Driver for your Radeon® product. Note: If you are using Windows 2000 or Windows XP, ensure that you have logged in with system administrative rights. Before you can install the latest Catalyst™ software driver for your Radeon™ product, you must uninstall the previous ATI Control Panel. To do this, follow these steps: 1. Navigate to the Add/Remove programs tool provided by Microsoft. This tool is found in the Control Panel. Note: Ensure all other applications are closed before continuing with the uninstall of the ATI Display Driver. 2. Click the Change/Remove button. The ATI Control Panel Setup window is displayed. 3. Select Remove, and click Next. A Confirm File Deletion dialog box is displayed. 4. Click OK. The ATI Control Panel Setup window is displayed. 5. Select No, and click Finish. You are returned to the Add/Remove Program tool. You have successfully uninstalled the ATI Control Panel. You are now ready to uninstall the ATI Display Driver. To do this, follow these steps: 1. Select ATI Display Driver in the Add/Remove Program tool. 2. Click the Change/Remove button. Note: If you have multiple display adapters installed, a dialog box will appear instructing you to choose which ATI Display driver to uninstall. Click the Select All button. 3. Click Yes when prompted to confirm the uninstall of the ATI Display Driver. 4. Reboot your system as prompted to compete the uninstall of the ATI Display Driver. Note: If you are prompted to start the installation of a display driver upon boot up, click CANCEL You have successfully uninstalled the previous version of the ATI Display Driver and ATI Control Panel. Installing the latest Catalyst™ Software Suite This section provides information on installing the latest Catalyst™ Software Suite for your Radeon® product. To install the driver, follow these steps: 1. Navigate to the Catalyst™ Download folder on your desktop. Double-click on the folder to view its content. 2. Double click the Catalyst™ software suite you have downloaded. Accept all the default prompts. 3. Restart your system as required. You have successfully installed the latest Catalyst™ software suite. edit glemte å svare på spørsmålet ditt (jeg misforsto, leste litt fort) JA, det er viktig Endret 12. juni 2005 av borgz Lenke til kommentar
