mallis Skrevet 11. juni 2005 Del Skrevet 11. juni 2005 (endret) Hei! Kan noen forklare meg hva forskjellen er mellom et trådløst access point og en trådløs ruter? Jeg trenger å ta i mot et trådløst signal utenifra (fra ukjent kilde...), og spre det videre i huset. Trenger jeg da et trådløst access point eller en trådløs ruter? Mallis Endret 11. juni 2005 av mallis Lenke til kommentar
la7dfa Skrevet 11. juni 2005 Del Skrevet 11. juni 2005 GOOGLE virker ennå... A wireless AP bridges traffic from an 802.11 wireless LAN onto an 802.3 Ethernet LAN. The AP lets several 802.11 stations connect to your wired LAN, similar to the way that a hub or switch lets Ethernet stations connect. A router relays network traffic (IP packets) between two or more subnets. A subnet can be composed of one or more LAN segments. All hosts in a subnet are assigned IP addresses from the same range, which allows traffic to be routed to and from the right subnet. Once the traffic hits the destination subnet, LAN frame forwarding delivers the traffic to its final destination. Many vendors (D-Link, Linksys, Netgear, etc) sell both wireless APs and wireless routers. A wireless router is just a wireless AP with a BUILT-IN router. Instead of buying two separate devices, you can buy one device that does both. If you only need one AP and one router, this is usually cheaper and less difficult to set up. That's why wireless routers are popular with home users that have small networks. Broadband connections may be delivered with a modem or a broadband gateway. A modem is just a network interface; a broadband gateway is a router/firewall with an embedded modem. BT broadband can tell you what they'll be providing you along with your service, but from your description I will guess it's just a modem. If so, your options include: # Add a dual-Ethernet broadband gateway behind your modem like the LinkSys BEFSR11 EtherFast Cable/DSL Router. Gateways like these are inexpensive and provide basic broadband connection sharing. # Add a small business firewall behind your modem like the SonicWALL SOHO3. SMB firewalls provide higher throughput connection sharing plus more robust firewall and VPN features. Lenke til kommentar
NorKing1 Skrevet 11. juni 2005 Del Skrevet 11. juni 2005 Vanskelig å skjønne hva du mener her.... Men hvis du for eksempel får inn et trådløst signal i huset ditt, som egentlig kommer fra naboen, så trenger du en repeater. For eks: Dwl-2100ap. Denne vil da ta i mot signalene som kommer i fra naboen, og kaste signale videre i ditt hus... // NorKing1 Lenke til kommentar
Pengu Skrevet 11. juni 2005 Del Skrevet 11. juni 2005 (endret) Enkelt forklart er et trådløst aksesspunkt en enhet du kobler til nettverket ditt via en switch (eller hub om du er litt gammeldags). De aksesspunktene jeg har vært borti har kun en ethernettilkobling, den du kobler aksesspunktet til nettverket med. Aksesspunktet har ingen router eller brannmur. Trådløs router er router og aksesspunkt i en enhet. Trådløse routere har vanligvis innebygget en 4-ports switch og en brannmur. En trådløs router inneholder dermed egentlig 4 enheter, selve routeren, en brannmur et trådløst aksesspunkt og en switch. Når det gjelder hva du trenger kommer det litt an på hva du ønser å oppnå. Hvis du bare vil forsterke signalene er det nok en repeater som NorKing 1 skriver som er saken, men da skal du være klar over at du er på samme WLAN som andre maskiner i det ukjente nettet. Du bør i så fall beskytte deg med brannmur på maskinene dine. Alternativet er å bruke en router-løsning med brannmur. Siden den trådløse "kilden" er ukjent, har du tenkt på hva du gjør hvis signalet forsvinner i morgen, eller at eieren finner det for godt å sikre nettet sitt? Litt dumt å investere i utstyr for noe som kanskje slutter å funke i morgen? Endret 11. juni 2005 av Pengu Lenke til kommentar
