Din ATi Catalyst 5.6 Score! :)
Litt off-topic, men legger til dette;
Catalyst 5.6 introduces full hardware acceleration of Microsoft Windows Media Video (WMV) files when using DirectX 9 shaders. Enable this feature.
How to enable DirectX Video Acceleration (DXVA) in Windows Media Player 10
    The following steps will help you enable
    DirectX Video Acceleration (DXVA) within Windows Media Player 10
    1.    Install Catalyst 5.6 or higher.  Drivers before Catalyst 5.5 to not support  DXVA acceleration
    a.      Reboot
    2.    Install Windows DRM update
    a.      http://www.microsoft.com/downloads/details...08-1FD6E7827CD8
    b.    Reboot
    Note: Please refer to this article for more information:  Update for Windows Media Digital Rights Management-enabled players
    http://support.microsoft.com/kb/891122/
    3.    Install the following Windows Media Player Hotfix
    a.      http://download.microsoft.com/download/f/9...-global-enu.exe
    Note: Please refer to this article for more information on the Hotfix:  Update to enable DirectX Video Acceleration (DXVA) of Windows Media Video content in Windows Media Player 10
    http://support.microsoft.com/default.aspx?...kb;en-us;888656
    4. Go into Catalyst Control Center.  Switch to Advanced view
    5. Go to the Video, All Settings
    6. Scroll to the bottom of the Catalyst Control Page to find the Windows Media Setting option and ensure Windows Media Video Acceleration is checked on.
    7. Start Windows Media Player 10, go into Tools, Options (if the menu bar is not available, double the click title bar to dispaly)
    8. Open the Performance tab and click Advanced under Video Acceleration
    9. Ensure Use high quality mode is selected. Click OK, OK.
Mitt resultat :(
Catalyst 5.5 = 4445
Catalyst 5.6 = 4557 (uten Control Panel)
Catalyst 5.6 = 4567 (med Control Panel)
Mener jeg har en del drit på maskinen som
gjør at testene ble så dårlig :cry:
hvilken 3dmark ? 05? 03? 01SE? :love:
Bra?
Jeg har ingen anelse... For alt jeg vet kan det være en nedgang i ytelsen du har der.
Si heller hvor mange prosent bedre eller dårligere resultatet blir.
Og test nå også ekte spill så vi kan få et inntrykk av ytelseøkningen i de ekte spillene.
Bra?
Har ikke testet i 3dmark før.
Med å spør bra, mente jeg om poengsummen er bra i forhold til maskinvare.
Sorry, men er nok feil plass å poste. Forstår at sammenligning med tidligere drivere var poenget her.
Fikk en liten økning i 3dmark05 her også.
Gikk fra 5234 til 5384 poeng, det blir vel rundt 3%... virker som om folk har gått opp 100-200 poeng uavhengig av kort og tidligere score?
P4 640 LGA775 3,2GHz @3,4
PowerColor Radeon X800XL 256MB PCIe @430/525
Abit AG8-V
TwinMOS DDR PC3200 2048MB
Gjest Slettet-uHVgFQ
lamt at alle dere har 5000+ i 3dmark også ser jeg 3dmark som bildefremvisning med i underkant av 2000...
Jeg har ikke noen "all settings" under video i Catalyst Control Center. Hvor finner jeg det?
Samme problem her, skjønte ikke hvordan jeg skulle få enablet "full hardware acceleration of Microsoft Windows Media Video (WMV) files", siden det ikke finnes noen "all settings" under video i CCC. Flere som har dette problemet?
Har radeon 9800pro, kan det være at det bare er støtte for hardware-wmv-akselerasjon i nyere ati-kort?
