fifiyu Skrevet 9. juni 2005 Skrevet 9. juni 2005 Hi everybody, :!: I am going to buy a notebook from internet. I have following choices, which do you think is the best to purchase? Thank you! Multicom G556E Dothan 2.0 1G ATI 9700 128M 15 TFT 13495 Netshop 154WS-TV Sonoma 2.0 2G 333 Go 6600GT 128M 15.4 W 16796 Netshop 1557GLS Dothan 2.0 1G 333 ATI 9700 128M 15 TFT 13626 Netshop 1559AS Sonoma 2.0 2G 533 Nvidia 6600 128MB 15 17155 Netshop 259IA3 Dothan 2.0 1G 333 ATI 9700 256M 15.4 W 13627 Netshop CL56 Dothan 2.0 1G 333 ATI 9700 128M 15" SXGA 14230 PS DATA 1559R Sonoma 2.0 2G 533 Nvidia 6600 128MB 15 15695 PS DATA 1557R Dothan 2.0 1G 333 ATI 9700 256M 15" SXGA 13195 MPX KN1 1.73G 915 1G 533 Nvidia 6600 128MB 15.4 W 13390
osse-mon waits for alice Skrevet 9. juni 2005 Skrevet 9. juni 2005 What are you going to use the machine for? It would be useful to have something to go by...
fifiyu Skrevet 9. juni 2005 Forfatter Skrevet 9. juni 2005 I need it for some programming, image processing, and of course 3D game so I need a good graphic card . And I want it be fast, so better cpu and large memory are preferred . I really like the one from netshop 154W, but I do not why only 333 memory avaliable. What do you think?
fxwz Skrevet 9. juni 2005 Skrevet 9. juni 2005 I need it for some programming, image processing, and of course 3D game so I need a good graphic card . And I want it be fast, so better cpu and large memory are preferred . I really like the one from netshop 154W, but I do not why only 333 memory avaliable. What do you think? How much money do you have?
fifiyu Skrevet 9. juni 2005 Forfatter Skrevet 9. juni 2005 I would like to afford one better not exceed 16,000kr and Quality is the first thing I will consider
TeCh2pe Skrevet 9. juni 2005 Skrevet 9. juni 2005 The "Netshop 154WS-TV" that you are refearing to is a good selection.
scarface15 Skrevet 9. juni 2005 Skrevet 9. juni 2005 (endret) www.dell.no herer you can get an 17" laptop with a 6800go (the second best notebook graphics card on the market) GFX (the computer is called Inspiron 9300), 512 mb ram, 1,8ghz cpu for under 16000Kr. ps. don't buy extra ram over dell, they overcharge like crazy! Endret 9. juni 2005 av scarface15
fifiyu Skrevet 9. juni 2005 Forfatter Skrevet 9. juni 2005 But I think 17" is a little bit big for me and what do you think about Tundra PCs, They are always cheaper than the similar ones from other retailers.
fifiyu Skrevet 9. juni 2005 Forfatter Skrevet 9. juni 2005 The "Netshop 154WS-TV" that you are refearing to is a good selection. what is about it compared with Tundra 1559R?
Fredrik Larsen Skrevet 9. juni 2005 Skrevet 9. juni 2005 The "Netshop 154WS-TV" that you are refearing to is a good selection. what is about it compared with Tundra 1559R? Tundra 1559's screen is rubbish and the case has alot of flex. I've never seen or tried the 154WS, but I know it's cheaper from Zepto
fifiyu Skrevet 9. juni 2005 Forfatter Skrevet 9. juni 2005 The "Netshop 154WS-TV" that you are refearing to is a good selection. what is about it compared with Tundra 1559R? Tundra 1559's screen is rubbish and the case has alot of flex. I've never seen or tried the 154WS, but I know it's cheaper from Zepto I don't think it cheaper with Zepto This is from netshop Sonoma 2.0 2G 333 Go 6600GT 128M 15.4 W 16796 And for the same configuration, the price in Zepto is kr 16 931,00Ekskl. mva
Fredrik Larsen Skrevet 9. juni 2005 Skrevet 9. juni 2005 Dont' buy ram from Zepto, it's very overpriced! Get a 2x1024MB DDR2 from Komplett! http://www.komplett.no/k/ki.asp?sku=305758&view=detailed
fifiyu Skrevet 9. juni 2005 Forfatter Skrevet 9. juni 2005 Dont' buy ram from Zepto, it's very overpriced!Get a 2x1024MB DDR2 from Komplett! http://www.komplett.no/k/ki.asp?sku=305758&view=detailed But I still have to buy one from Zepto, Can I buy a laptop without memory And I calculate the price, there still 800kr difference
Fredrik Larsen Skrevet 9. juni 2005 Skrevet 9. juni 2005 (endret) With PM 1.86, 1x512mb DDR400, 60GB 5400RPM and dvd-burner, Zepto is 30kr cheaper than Netshop. So buying from Netshop is cheapest (if you want more than 512mb memory) Endret 9. juni 2005 av Fredrik Larsen
fifiyu Skrevet 9. juni 2005 Forfatter Skrevet 9. juni 2005 With PM 1.86, 1x512mb DDR400, 60GB 5400RPM and dvd-burner, Zepto is 30kr cheaper than Netshop. So buying from Netshop is cheapest (if you want more than 512mb memory) Thank you for your suggestion But I noticed that PM 1.86 is out storage in Zepto and I want to buy with a 2.0 CPU Is there any different between the same model from netshop and zepto?
Fredrik Larsen Skrevet 9. juni 2005 Skrevet 9. juni 2005 (endret) With PM 1.86, 1x512mb DDR400, 60GB 5400RPM and dvd-burner, Zepto is 30kr cheaper than Netshop. So buying from Netshop is cheapest (if you want more than 512mb memory) Thank you for your suggestion But I noticed that PM 1.86 is out storage in Zepto and I want to buy with a 2.0 CPU Is there any different between the same model from netshop and zepto? Nope. 2.0 GHz is expensive and not worth the money, but it's your decision. Buy it from Netshop if you want 2GB memory. Edit: Buy it from Zepto with 256mb memory, order 2x1GB from Komplett! Netshop only has DDR333, not DDR400! Endret 9. juni 2005 av Fredrik Larsen
fifiyu Skrevet 9. juni 2005 Forfatter Skrevet 9. juni 2005 With PM 1.86, 1x512mb DDR400, 60GB 5400RPM and dvd-burner, Zepto is 30kr cheaper than Netshop. So buying from Netshop is cheapest (if you want more than 512mb memory) Thank you for your suggestion But I noticed that PM 1.86 is out storage in Zepto and I want to buy with a 2.0 CPU Is there any different between the same model from netshop and zepto? Nope. 2.0 GHz is expensive and not worth the money, but it's your decision. Buy it from Netshop if you want 2GB memory. Edit: Buy it from Zepto with 256mb memory, order 2x1GB from Komplett! Netshop only has DDR333, not DDR400! It is not because I do not like PM1.86G, but it is not in storage and I want to make sure it will reach me within one month, so... If I buy from Zepto, then what about the extra 256 memory. It is no use for me and I don't think there will be somebody buy it.
Hexagon Skrevet 9. juni 2005 Skrevet 9. juni 2005 As a rule of thumb: at least know a bit about the language before you try to be "smart" and post in "English"(i use goosemarks 4 a reason). Which should I choose (if you say so maybe, who knows what your trying to say.....) You don't buy a notebook from the internet. I need it for some programming, image processing, and of course 3D game (i love a round at the golf course to). I would like to afford one better not exceed 16,000kr(there is a meaning in this?) What is about it compared with Tundra 1559R?(sorry, dont get your meaning here?) I don't think it cheaper with Zepto(maybe its cheaper without a Zepto?) Is there any different between the same model from netshop and zepto?(umm....) It is no use for me and I don't think there will be somebody buy it.(no use, and don't think is key words here if im not mistaken?). Hex. (I have the power, i know CapsLoc)
Charli Skrevet 9. juni 2005 Skrevet 9. juni 2005 (endret) As a rule of thumb: at least know a bit about the language before you try to be "smart" and post in "English"(i use goosemarks 4 a reason). Which should I choose (if you say so maybe, who knows what your trying to say.....) You don't buy a notebook from the internet. I need it for some programming, image processing, and of course 3D game (i love a round at the golf course to). I would like to afford one better not exceed 16,000kr(there is a meaning in this?) What is about it compared with Tundra 1559R?(sorry, dont get your meaning here?) I don't think it cheaper with Zepto(maybe its cheaper without a Zepto?) Is there any different between the same model from netshop and zepto?(umm....) It is no use for me and I don't think there will be somebody buy it.(no use, and don't think is key words here if im not mistaken?). Hex. (I have the power, i know CapsLoc) Ok, og poenget med posten din er? Ser ut til at de aller fleste her inne har skjønt hva han har skrevet, de har tross alt svart. Meningen kommer da helt tydelig frem på tross av at det er en del skrive- og grammatiske feil. Og siden du er glad i å kritisere andres engelsk, kan jo jeg kritisere din litt. ....what your trying to say.... hmm...mangler vi kanskje et lite tegn her, du mente vel kanskje you're as in you are siden du poengterer at han har glemt en s i 3D game, kan jo jeg poengtere at du mangler en o i to. Du mente vel mest sannsynlig at you love a round at the golf course too. Dessuten tror jeg heller on er mer passende, on the golf course. "maybe its cheaper without a Zepto?" Ok, hva er det du egentlig mener her, oi, du mente kanskje; maybe it's cheaper without a Zepto. Tok litt tid det der, er jo ikke så smart at man skjønner meningen av en setning med en tegnsettingsfeil. Intensjonen din var vel å virke som en bedreviter som er utrolig god i engelsk og derfor kan rakke ned på en stakkar som har et par feil her og der. Vi andre får bare bruke litt sunn fornuft for å skjønne meningen i alt "virvaret" som er skrevet... Endret 9. juni 2005 av Charli
.Marcus Skrevet 9. juni 2005 Skrevet 9. juni 2005 As a rule of thumb: at least know a bit about the language before you try to be "smart" and post in "English"(i use goosemarks 4 a reason). Which should I choose (if you say so maybe, who knows what your trying to say.....) You don't buy a notebook from the internet. I need it for some programming, image processing, and of course 3D game (i love a round at the golf course to). I would like to afford one better not exceed 16,000kr(there is a meaning in this?) What is about it compared with Tundra 1559R?(sorry, dont get your meaning here?) I don't think it cheaper with Zepto(maybe its cheaper without a Zepto?) Is there any different between the same model from netshop and zepto?(umm....) It is no use for me and I don't think there will be somebody buy it.(no use, and don't think is key words here if im not mistaken?). Hex. (I have the power, i know CapsLoc) Ok, og poenget med posten din er? Ser ut til at de aller fleste her inne har skjønt hva han har skrevet, de har tross alt svart. Meningen kommer da helt tydelig frem på tross av at det er en del skrive- og grammatiske feil. Og siden du er glad i å kritisere andres engelsk, kan jo jeg kritisere din litt. ....what your trying to say.... hmm...mangler vi kanskje et lite tegn her, du mente vel kanskje you're as in you are siden du poengterer at han har glemt en s i 3D game, kan jo jeg poengtere at du mangler en o i to. Du mente vel mest sannsynlig at you love a round at the golf course too. Dessuten tror jeg heller on er mer passende, on the golf course. "maybe its cheaper without a Zepto?" Ok, hva er det du egentlig mener her, oi, du mente kanskje; maybe it's cheaper without a Zepto. Tok litt tid det der, er jo ikke så smart at man skjønner meningen av en setning med en tegnsettingsfeil. Intensjonen din var vel å virke som en bedreviter som er utrolig god i engelsk og derfor kan rakke ned på en stakkar som har et par feil her og der. Vi andre får bare bruke litt sunn fornuft for å skjønne meningen i alt "virvaret" som er skrevet... Er så til de grader enig med Charli her. Når du først retter en som har et par typos (ja det var et engelsk ord) så hjelper det ikke mye at du ikke kan det så mye bedre selv. Du hadde fått en stor smekk på pungen av engelsklæreren min når du glemmer appostrof i "it´s" Charli vettu.. han er smartere enn deg Hexagon, eller skulle jeg si sekskant siden du tydeligvis ikke kan engelsk så veldig godt?
