Jeg har tenkt å legge inn en registeroppføring om at quick launch skal bli aktivert automatisk, men etter hva jeg har fått med meg kan ikke dette gjøres via en vanlig reg fil, men må gjøres via cmd.
Så det jeg lurer på er hva komandoen for å få lagt inn en endring i registeret via en cmd fil.
Er følgende jeg vil ha lagt inn i en cmd fil:
; Enable Quick Launch (CALL FROM CMDLINES to work)
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Streams\Desktop]
"TaskbarWinXP"=hex& #58;0c,00,00,00,08,00,00,00,02,00,00,00,00,00,00,0
0,b0,e2,2b,\
d8,64,57,d0,11,a9,6e,00,c0,4f,d7,05,a2,22,00,1c,00
,0a,01,00,00,1a,00,00,00,\
01,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,4c
,00,00,00,01,14,02,00,00,\
00,00,00,c0,00,00,00,00,00,00,46,83,00,00,00,10,00
,00,00,a0,b0,48,5e,89,8d,\
bd,01,00,d8,9e,e4,2a,8d,bd,01,00,45,fe,5e,89,8d,bd
,01,00,00,00,00,00,00,00,\
00,01,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
,13,01,14,00,1f,0f,e0,4f,\
d0,20,ea,3a,69,10,a2,d8,08,00,2b,30,30,9d,19,00,23
,44,3a,5c,00,00,00,00,00,\
00,00,00,00,00,00,00,00,00,00,00,00,cd,97,15,00,31
,00,00,00,00,00,af,24,5c,\
b9,10,80,57,69,6e,6e,74,00,00,20,00,31,00,00,00,00
,00,af,24,a3,b9,10,00,50,\
72,6f,66,69,6c,65,73,00,50,52,4f,46,49,4c,45,53,00
,19,00,31,00,00,00,00,00,\
c1,24,08,92,10,00,69,65,35,30,30,2e,30,30,30,00,00
,28,00,31,00,00,00,00,00,\
c1,24,08,92,10,00,41,70,70,6c,69,63,61,74,69,6f,6e
,20,44,61,74,61,00,41,50,\
50,4c,49,43,7e,31,00,21,00,31,00,00,00,00,00,c5,22
,9d,91,10,00,4d,69,63,72,\
6f,73,6f,66,74,00,4d,49,43,52,4f,53,7e,31,00,29,00
,31,00,00,00,00,00,d3,22,\
32,a6,10,00,49,6e,74,65,72,6e,65,74,20,45,78,70,6c
,6f,72,65,72,00,49,4e,54,\
45,52,4e,7e,31,00,24,00,31,00,00,00,00,00,db,22,76
,ba,10,00,51,75,69,63,6b,\
20,4c,61,75,6e,63,68,00,51,55,49,43,4b,4c,7e,31,00
,00,00,8d,00,00,00,1c,00,\
00,00,01,00,00,00,1c,00,00,00,36,00,00,00,0d,f0,ad
,ba,8c,00,00,00,1a,00,00,\
00,03,00,00,00,e7,18,2d,23,10,00,00,00,49,45,35,30
,30,5f,58,31,43,00,43,3a,\
5c,57,49,4e,4e,54,5c,50,72,6f,66,69,6c,65,73,5c,49
,45,35,30,30,2e,30,30,30,\
5c,41,70,70,6c,69,63,61,74,69,6f,6e,20,44,61,74,61
,5c,4d,69,63,72,6f,73,6f,\
66,74,5c,49,6e,74,65,72,6e,65,74,20,45,78,70,6c,6f
,72,65,72,5c,51,75,69,63,\
6b,20,4c,61,75,6e,63,68,00,00,10,00,00,00,05,00,00
,a0,1a,00,00,00,a3,00,00,\
00,00,00,00,00,08,00,00,00,02,00,00,00,cc,00,00,00
,01,00,00,00,03,00,00,00,\
4a,00,00,00,01,00,00,00,40,00,32,00,e6,01,00,00,c4
,24,15,9f,20,00,4c,61,75,\
6e,63,68,20,49,6e,74,65,72,6e,65,74,20,45,78,70,6c
,6f,72,65,72,20,42,72,6f,\
77,73,65,72,2e,6c,6e,6b,00,4c,41,55,4e,43,48,7e,32
,2e,4c,4e,4b,00,00,00,40,\
00,00,00,02,00,00,00,36,00,32,00,48,02,00,00,c4,24
,15,9f,20,00,4c,61,75,6e,\
63,68,20,4f,75,74,6c,6f,6f,6b,20,45,78,70,72,65,73
,73,2e,6c,6e,6b,00,4c,41,\
55,4e,43,48,7e,31,2e,4c,4e,4b,00,00,00,36,00,00,00
,00,00,00,00,2c,00,32,00,\
51,00,00,00,ec,22,46,39,20,00,53,68,6f,77,20,44,65
,73,6b,74,6f,70,2e,73,63,\
66,00,53,48,4f,57,44,45,7e,31,2e,53,43,46,00,00,00
,52,00,00,00,e0,00,00,00,\
00,00,00,00,16,00,00,00,00,00,00,00,00,00,00,00,16
,00,00,00,00,00,00,00,01,\
00,00,00,01,00,00,00,aa,4f,28,68,48,6a,d0,11,8c,78
,00,c0,4f,d9,18,b4,37,02,\
00,00,e0,00,00,00,00,00,00,00,16,00,00,00,00,00,00
,00,00,00,00,00,16,00,00,\
00,00,00,00,00,01,00,00,00
CMDLINES slik det står der er ikke det samme som CMD prompt.
Les om CMDLINES her
Altså, lagre det som står i code i posten din til en .reg fil.
I cmdlines.txt filen du må lage skriver du:
[COMMANDS]
"REGEDIT32.EXE /S filonavn.reg"
Putt begge filene i $OEM$ mappa.
Det er mulig å legge til/slette/endre registernøkler via en .cmd fil også.
Skriv følgende i et cmd prompt:
REG /?
evt.
REG ADD /?
Så gir dette en pekepinn på hvordan du kan gå frem.
Har aldri prøvd å legge til binær verdier på denne måten selv.
Multistreng- og utvidbare strengverdier er nyttige å legge inn via .cmd filer.
Dette fordi en kan bruke path variabler i de.
