ATi kan ha problemer med fab. av R520? [Link]
The information on the R520 suggests that there are some extreme yield problems with the current design.  Not only are there few working dice per wafer, but a large number of those dice only have 16 pixel units working, and others are lucky to get 24 working.  The information I received suggested that the R520 was in fact designed with 32 pixel units (each with multiple ALU’s), but due to the issues that the chip is facing, very few of them so far are fully functioning
Stemmer dette så.... Au da...
Høres ut som om de kanskje kjører inn på samme problem som nVidia hadde, da de kjørte NV30 i en da helt ny prosess 130nm...
With this information in hand, it looks as if NVIDIA could have a big leg up on ATI for the next several quarters.  While the rumored specs of the G70 are not as impressive as that of the R520, NVIDIA looks to have no problems producing G70 chips.  This is actually quite reminiscent of the R300/NV30 situation
Edit: Ser ut som finansanalyse bladet Forbes også skriver litt om ATi sine problemer. ATi har også nedjustert salgs forventningene sine, noe som har fått aksjekursen til å synke....
http://www.forbes.com/markets/2005/06/07/0...ootix&referrer=
First, we remain concerned with the delay of ATI's next generation high-end graphics processor, code-named R520, which appears to be now due out in August, flatly missing the 'spring refresh' window. Given the tape-out took place as far back as October, and Taiwan Semiconductor's yields on 90nm have been generally good on other products including the Xbox 360 graphics chip, we believe the delay is due to a design issue."
http://yahoo.smartmoney.com/Techsmart/inde...50606&afl=yahoo
ATI TECHNOLOGIES (ATYT) is on a roll — and not in a good way. On Monday, for the second time in three months, the Markham, Ontario-based graphics chip maker has lowered the bar on its fiscal third quarter, which ended May.
Endret av [GDI]Raptor
Tror det ATI driver med er å bestemmer seg for om R520 skal komme med 32 eller 24 pipes. Men de venter til nVidia G70 er lansert og testet til de bestemmer seg. Kanskje det blir noe slikt : 32 pipes og 500 Mhz core eller 24 pipes og 600 Mhz core. Tiden får vise.
Artikkelen drar jo ganske kjappe konklusjoner uten særlig gode kilder eller bevis for det, men det er en interessant (og skremmende) teori.
For alt vi vet kan det jo heller være at Ati har lært av forrige release, og satser på å få produksjonen opp i topp før de lanserer. Alle husker jo ventetiden fra lansering til å faktisk ha kortet i hus når det gjelder x800xt :)
