Feilmld: The requested lookup key was not found
Utvikler Websider i VS.NET med ASP.NET og VB.NET
Skal sende mail fra prosjektet mitt, uten å bruke SMTP Server:
Koden ser slik ut:
Dim epost As System.Text.StringBuilder = New System.Text.StringBuilder
epost.Append("mailto:[email protected]")
epost.Append("&Subject=hei&body=hei igjen")
Dim minProsess As System.Diagnostics.Process = New System.Diagnostics.Process
minProsess.StartInfo.FileName = epost.ToString
minProsess.StartInfo.UseShellExecute = True
minProsess.StartInfo.RedirectStandardOutput = False
minProsess.Start()
minProsess.Dispose()
Når eg køyrer denne koden får eg feilmeldinga:
The requested lookup key was not found in any active activation context
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ComponentModel.Win32Exception: The requested lookup key was not found in any active activation context
Er det nokken som veit korleis eg kan løyse dette problemet?
På førehand takk.
hurlis
