Ny og irriterende "buddy" fil...
Jeg har fått en veldig irriterende fil på maskina mi. Den hopper opp hele tiden inne på loggen på brannmur-programmet mitt Sygate Personal Firewall. Har en copy-paste av meldingen jeg får opp lenger nede på denne posten. Programmet eller viruset heter "Buddy" men fila som ligger i Windows mappa heter "qbaxbxtxvj.exe". Har prøvd å søke på den men jeg finner ikke noe om den.
Ad-Aware tar den heller ikke.
The executable has changed since the last time you used: D:\WINDOWS\qbaxbxtxvj.exe
File Version : 1.0.2.4
File Description : Buddy
File Path : D:\WINDOWS\qbaxbxtxvj.exe
Process ID : 0xB38 (Heximal) 2872 (Decimal)
Connection origin : local initiated
Protocol : TCP
Local Address : 192.168.0.101
Local Port : 1276
Remote Name : xadsj.offeroptimizer.com
Remote Address : 64.95.228.143
Remote Port : 80 (HTTP - World Wide Web)
Ethernet packet details:
Ethernet II (Packet Length: 76)
Destination: 00-11-95-09-f8-a0
Source: 00-30-bd-9e-67-05
Type: IP (0x0800)
Internet Protocol
Version: 4
Header Length: 20 bytes
Flags:
.1.. = Don't fragment: Set
..0. = More fragments: Not set
Fragment offset:0
Time to live: 128
Protocol: 0x6 (TCP - Transmission Control Protocol)
Header checksum: 0xbc03 (Correct)
Source: 192.168.0.101
Destination: 64.95.228.143
Transmission Control Protocol (TCP)
Source port: 1276
Destination port: 80
Sequence number: 4099064903
Acknowledgment number: 0
Header length: 28
Flags:
0... .... = Congestion Window Reduce (CWR): Not set
.0.. .... = ECN-Echo: Not set
..0. .... = Urgent: Not set
...0 .... = Acknowledgment: Not set
.... 0... = Push: Not set
.... .0.. = Reset: Not set
.... ..1. = Syn: Set
.... ...0 = Fin: Not set
Checksum: 0x3c9f (Correct)
Data (0 Bytes)
Binary dump of the packet:
0000: 00 11 95 09 F8 A0 00 30 : BD 9E 67 05 08 00 45 00 | .......0..g...E.
0010: 00 30 11 10 40 00 80 06 : 03 BC C0 A8 00 65 40 5F | [email protected]@_
0020: E4 8F 04 FC 00 50 F4 52 : C4 47 00 00 00 00 70 02 | .....P.R.G....p.
0030: 40 00 9F 3C 00 00 02 04 : 05 B4 01 01 04 02 66 66 | @..<..........ff
0040: 65 72 6F 70 74 69 6D 69 : 7A 65 72 03 | eroptimizer.
Noen kjenskap til den jæv*** fila?
