Casio G'zOne [villmannstelefonen]
Gjest orden
Internett kan oversette vet dere :w00t:
Actualizing water resistance shock resistant efficiency with folding form Mega pixel camera loading 2005 May 26th
The toughness k tie "G ' zOne TYPE-R which evolved"
Real clock function and the electronic compass which utilize the sub liquid crystal
Green flag Red zone Black mark
Green flag
The Casio Computer Co., Ltd., outdoor, to sport, without choosing the scene from daily life, the toughness k tie ' G' zOne TYPE-R which is wide and can use 'it develops. Payment is started to the KDDI corporation which is the enterprise.
You can use "the G ' zOne" series, even in the rain, it is the portable telephone which has the shock resistant efficiency which it can withstand also the hard use of JIS protective class 7 suitable waterproof efficiency and daily life. Developing 4 types from 2000 to 2001. Focusing on the young person who requests the unique portable telephone toughness efficiency and the other portable telephone with the design which works out one line, confidence was won.
Black mark
This time we guide' G ' zOne TYPE-R ', to fold, principal trend of the portable telephone such as 128 ten thousand pixel cameras and 2.2 inch Kousei small QVGA liquid crystal of form and the macrofacility attachment while everything thoroughly containing, is the toughness k tie which actualizes water resistance shock resistant efficiency. Including the meaning, racing of design motif (Racing) with, the revolutionist existence which creates the new genre of the portable telephone (Revolution) of becoming, you named the respective initial "R" empty "TYPE-R".
* The JIS protective class 7 suitable water resistance the chip resistance which is superior
The sub liquid crystal is protected round urethane make ベゼル and the protector etc. which eases the impact of the vertical falling time, to fold, equipping the material and the mechanism which actualize water resistance shock resistant with form. Those, have become also accent in regard to the design which produces tough image.
* Even at the time of back light not yet illumination clock function of easy to see sub liquid crystal
As for the sub liquid crystal, when back light has not lit up, adopting the clock of easy to see regular indication type. Digital display of 4 types and analog indication of 1 type were pre-set. Furthermore while the substance is closed being one-touch, 1/100 second stopwatch and the countdown timer, it is change possible in the alarm.
* The electronic compass which is linked with EZ Nabi walk
You close the substance and it is one-touch even to the cartridge and it starts, loading the electronic compass which indicates direction in the sub liquid crystal. If it indicates with the main liquid crystal, linking with the map information of EZ Nabi walk, you can use.
* Being practical, fully loading the function which it is easy to use
The large volume buzzer of 80dB (the hot buzzer), being one-touch, the photographing LED light/write which shines, to the family and the friend with simple operation the telephone and the pair function etc. which can do the mail, being practical, it fully loaded the function which it is easy to use.
* Lining up 3 colors of "green flag" "red zone" "black mark"
' G ' zOne TYPE-R ', the Casio Computer Co., Ltd. develops & produces, is sold with the au brand of the KDDI corporation which is the enterprise. Please verify at the KDDI corporation in regard to price sale time.
<< The design of G ' zOne TYPE-R >>
As for substance design, adopting, the design which such as spirit 悍 body makes racing everywhere feel and the center cursor which makes the disk brake associate and is finished in carbon pitch the substance liquid crystal surface case which designate the tank of the motorcycle as motif. Freely using, Flash animation such as the menu screen which imitates the cylinder head, it actualized the picture design which has the substance and the standardized impression. Furthermore, the starting sound which was recorded from the actual racing car the starting picture, the charge stand of the forum which makes volt/bolt associate, also the color variation "green flag" of 3 colors "red zone" "black mark" being associated with motor sport, naming it does, passing the date of 4 years, it revives key back light, e.g., it changes every body color, it was suitable in the toughness k tie, adhering thoroughly, it finished.
Red zone
<< The main merit of G ' zOne TYPE-R >>
* The numerous equipment which actualizes water resistance shock resistant efficiency JIS protective class 7 suitable*actualizing waterproof efficiency
* At normal temperature the fresh water, when at the same time the telephone itself is sunk gently in the tank of the depth of water 1m of still water leaving in the bed approximately 30 minutes, it is not flooded inside the substance and it maintains efficiency as a telephone.
The speaker/the ear piece/the metal mesh and the high-molecular filter in order to prevent the flooding of the dust and the water from the microphone section
Protection of the hinge/antenna section the bumper of the urethane material was equipped in purpose the "urethane protection"
ベゼル "circle display protection" of the urethane material in order to protect the sub liquid crystal
"The screw battery lock" of the round pad system which prevents falling off of the battery with impact
The exchanging possible customization protector "round top eases the impact of the vertical falling time protector" which "square top protector" 3 types of "hammer head protector" bundled
In order to prevent the distortion of the vertical falling time itself, adopting the magnesium alloy for the case of the main liquid crystal surface
* Even at the time of back light not yet illumination clock function of regular indication type of easy to see sub liquid crystal Clock picture indication of digital 4 types and analog 1 type
Countdown timer of longest 60 parts
1/100 second meter stopwatch which 5 main story records is produced split
To 5 cases the alarm function which can be set
* The electronic compass which is linked with EZ Nabi walk The substance is closed and it is one-touch even to the cartridge and the electronic compass which it starts and indicates direction in the sub liquid crystal
With the main liquid crystal linking with the map information of EZ Nabi walk, enabled
* Loading 128 ten thousand pixel cameras of the macro photographing attachment The macrofacility whose photographing the small subject is possible
Being maximum, SXGA size (the 1280×960 dot) photographing is possible
The best shot function which is set to optimum state automatically ("person" "scenery" "night scene" "twilight" "party") loading the setting of the camera
As for illumination when photographing being one-touch as a general light/write of course, the photographing LED light/write which it can light up
Attaching also the photograph of SXGA size that way, it corresponds to the 500KB attachment of the E-mail which it can transmit
* QVGA size (the 320×240 dot) movie video recording is possible
* Freely using FLASH animation, the menu screen which it built up and 待 it receives, the picture and various operational pictures
* When you can verify the address of the partner "relief Nabi position search" and it enters into the area which sets with simplicity operation, it is notified it corresponds to "relief Navier rear notification" automatically
* When 0 keys length are pushed, approximately 80dB*buzzer sound sounds, with the "hot buzzer" and the telephone is applied to the partner who is registered, the "hot dial" it can select, "hot key" function
*The speaker of the terminal - empty 1m it is the sound pressure at the distance which leaves
* There is no electric battery remaining amount, telephone call failure becomes, the address register and mail contents can verify "extension mode"*
*Operational possible time differs depending upon the environment of use,
* Also during of mail drawing up and functional operation can receive the mail automatically "background reception"
* The mail and the partner who would like to speak by telephone can be called with simplicity operation, "pair function" (maximum of 5 human register possibilities)
* The screen can be changed to English, "bilingual indication"
* Modification of letter size finishes in 5 stages, "it is huge letter"
* Just the function which is used well it indicates in the menu "smart mode"
* Telephone call time of the telephone and frequency of transmission of the mail can be restricted "ティーンズモード"
* The bar-code reading function which can do the address register register and the jump to URL simply
* Judging context, it converts to appropriate word "ATOK for au (Kansai valve correspondence) +AI presumption conversion APOT" loading
* The arrival FLASH correspondence which can set the FLASH data as animation when arriving
<< The main specification of G ' zOne TYPE-R >>
< Basic specification >
Size weight Approximately 52 (width) the ×104 (height) ×28mm (depth)... you fold, time approximately 143 g... electric battery containing *As for size and weight at the time of customization protector installing
Electric battery duration Continuation 待 receiving; Approximately 270 hours, continual telephone call; Approximately 190 minutes
Charge time Approximately 120 minutes (commonness AC), approximately 140 minutes (commonness DC)
Liquid crystal indication Main; 2.2 inch Kousei small QVGA liquid crystal (240×320 dot)
Sub; 1.0 inch monochrome STN liquid crystal (100×100 dot)
Water resistance JIS protective class 7 suitable
< Photo movie common function >
Image pickup element 1/3.2 inches effective pixel several 128 ten thousand pixels CMOS
Zoom function Photo; Maximum of 20 gradual digital 8 time movie; Maximum of 16 gradual digital 4 times
Photographing function Macro photographing and self-timer function, photographing light/write, shutter sound selection
In addition GPS information addition and automatic play
< Photo function >
Record size SXGA (1280×960), VGA (640×480), wallpaper (240×320), k tie (120×160)
Photographing function Best shot function, serial radiography (9) coupling shot and up-down shot
Playback zoom function Detection zoom (maximum of 18 stages*), playback zoom (maximum of 18 stages*) *In case of SXGA
Edit function Frame (10 kinds), stamp (10 kinds), special effect (17 kinds), letter stamp,
Picture letter stamp, picture detection and size conversion other things
< Movie function >
Record size QVGA size (320×240), L size (176×144), M size (128×96), S size (96×80)
Video recording time Maximum approximately 30 seconds *In case of QVGA size
Movie compilation Postrecording function, telop indication (largest full size 20 letter) other things
< Arrival function >
Arrival sound Maximum of 64 chords, built-in 16 type
Arrival movie The movie which it photographed (sound to be attached), playback when arriving
In addition Vibrator arrival; 3 kinds, manner mode; 4 kinds
< Memory >
Data folder 12.8MB
Photographing picture Largest approximately 800 (k tie size), approximately 409 (wallpaper size), approximately 163 (VGA size), approximately 131 (SXGA size), approximately 218 (the S movie; 15 seconds), approximately 172 (M movie; 15 seconds), approximately 91 (the L movie; 15 seconds), approximately 8 (the QVGA movie; 30 seconds)
Mail E-mail; Reception mail maximum of 600 cases (or 2.4MB), transmission mail maximum of 300 cases
C mail; Reception mail maximum of 300 cases and transmission mail maximum of 100 cases
Mail attachment capacity; 500KB
Address Photo address register; 700 cases (respectively 3 telephone numbers, 3 mail addresses)
Past record Dispatching past record; 50 cases, arrival past record; 50 cases
< In addition specification >
Correspondence service EZ "arrival う it is® ", the EZ waiting う it is, EZ Nabi walk, EZ application (the BREW™)
EZweb (WAP2.0), EZ movie, FLASH®and arrival Flash
Picture letter 497 letters (the picture letter 96 letter which moves is included)
In addition Japanese input system 「 ATOK for au + AI presumption conversion APOT 」 (Kansai valve correspondence),
待 It receives and shortcut, the calendar, the portable calculator and the can it is メールレシピ,
Friendly design, hot buzzer and bilingual mode etc.
"ATOK" "APOT (Advanced Prediction Optimization Technology)", it is registered trade mark of the corporation just system. The arrival う it is®it is registered trade mark of corporation SONY music entertainment.®The trade mark which it is related®to BREW and BREW is trade mark or registered trade mark of the Qualcomm corporation. Macromedia®, Flash®and FlashLite™ Macromedia® Flash®and Macromedia® FlashLite™ Macromedia and Inc. It is trade mark or the registered trade mark in the United States and other countries.
Ahead the inquiring regarding this commodity
Customer aspectual talks room TEL:03-5334-4482
Endret av thomas ll
  • 2 uker senere...
