Traffic Shaping
vel, dersom du søker på shaper i sid nå så er det..
shapecfg:
The traffic shaper for Linux configures a virtual interface, for which all
outgoing packets are shaped. This means that you may set parameters and
limits on outgoing network traffic. Incoming traffic may not be limited or
shaped using this utility. See /usr/share/doc/shapecfg/README.shapecfg.gz for
instructions.
shapecfg for Debian was ported from Red Hat's utility of the same name
shaper:
This init script sets up traffic shaping using Linux's class-based queueing.
This can be used to build smart bandwidth shapers which understand TCP/IP.
See /usr/share/doc/shaper/README.shaper.gz for more details.
The kernel support needed to use either of these facilities is described in
README.Debian.
cbq.init comes from http://sourceforge.net/projects/cbqinit/
trickle:
Trickle is a voluntary, cooperative bandwidth shaper. it works
entirely in userland and is very easy to use.
The most simple application is to limit the bandwidth usage of programs.
og wondershaper:
An easy to use traffic shaping script that provides these improvements:
* Low latency for interactive traffic (and pings) at all times
* Allow websurfing at reasonable speeds while uploading / downloading
* Make sure uploads don't hurt downloads
* Make sure downloads don't hurt uploads
It does this by:
* Limiting upload speed slightly, to eliminate queues
* Limiting download speed, while allowing bursts, to eliminate queues
* Interactive traffic skips the queue
* ACKs and tiny packets skip the queue
Configuring the wondershaper requires you to accurately and precisely
determine your consistent upload and download speeds.
The wondershaper is the simplest, easiest to use, entry level, traffic
shaping script provided by Debian.
After installing this package, read highly the detailed instructions:
/usr/share/doc/wondershaper/README.Debian
kan vel se ut som om at det er wondershaper som kan være noe for alle oss da? eller?
  • 1 måned senere...
