Chasseur Skrevet 27. mai 2005 Del Skrevet 27. mai 2005 etter en vellykket innstalasjon, trykker jeg på lenken som skulle fullføre innstalasjonen. Men da kommer denne meldingen opp: message_die() was called multiple times. This isn't supposed to happen. Was message_die() used in page_tail.php? Noen som vet hva jeg skal gjøre? Posteer i samme slengen filen page_tail.php <?php /*************************************************************************** * page_tail.php * ------------------- * begin : Saturday, Feb 13, 2001 * copyright : (C) 2001 The phpBB Group * email : [email protected] * * $Id: page_tail.php,v 1.27.2.3 2004/12/22 02:04:00 psotfx Exp $ * * ***************************************************************************/ /*************************************************************************** * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation; either version 2 of the License, or * (at your option) any later version. * ***************************************************************************/ if ( !defined('IN_PHPBB') ) { die('Hacking attempt'); } // // Show the overall footer. // $admin_link = ( $userdata['user_level'] == ADMIN ) ? '<a href="admin/index.' . $phpEx . '?sid=' . $userdata['session_id'] . '">' . $lang['Admin_panel'] . '</a><br /><br />' : ''; $template->set_filenames(array( 'overall_footer' => ( empty($gen_simple_header) ) ? 'overall_footer.tpl' : 'simple_footer.tpl') ); $template->assign_vars(array( 'TRANSLATION_INFO' => ( isset($lang['TRANSLATION_INFO']) ) ? $lang['TRANSLATION_INFO'] : '', 'ADMIN_LINK' => $admin_link) ); $template->pparse('overall_footer'); // // Close our DB connection. // $db->sql_close(); // // Compress buffered output if required and send to browser // if ( $do_gzip_compress ) { // // Borrowed from php.net! // $gzip_contents = ob_get_contents(); ob_end_clean(); $gzip_size = strlen($gzip_contents); $gzip_crc = crc32($gzip_contents); $gzip_contents = gzcompress($gzip_contents, 9); $gzip_contents = substr($gzip_contents, 0, strlen($gzip_contents) - 4); echo "\x1f\x8b\x08\x00\x00\x00\x00\x00"; echo $gzip_contents; echo pack('V', $gzip_crc); echo pack('V', $gzip_size); } exit; ?> Jeg kan ikke PHP, men jeg kan HTML, hvis det er nødvendig.. Noen som hvet hva en stakkars mann skal gjøre? Lenke til kommentar
Prodigy_ Skrevet 27. mai 2005 Del Skrevet 27. mai 2005 Er det siste versjon (2.0.15) av phpBB du har installert? Lenke til kommentar
