Skrev en liten klasse for en stund siden, som gjør akkurat dette. Du skriver f.eks:
java LineCounter javaprosjekt/
hvor javaprosjekt er en mappe som inneholder .java filer i hierarkiet. programmet går rekursivt igjennom hele shiten og teller alle linjer med javakode.
enjoy.
import java.io.File;
import java.io.RandomAccessFile;
* Created on Oct 10, 2004
* @author krigun
* This program counts the number of lines of code in a Project. It only counts
* lines of code in files with .java extension, and its recursive.
public class LineCounter
   private long counter;
   private long fileCounter;
   private long directoryCounter;
   private RandomAccessFile raf;
   public LineCounter(File folder)
       counter = 0;
       fileCounter = 0;
       directoryCounter = 0;
       traverse( folder );
       System.out.println("Number of lines: " + counter );
       System.out.println("Number of files: " + fileCounter );
       System.out.println("Number of directories: " + directoryCounter );
   public void traverse( File file )
       if( file.isDirectory() )
           System.out.println(file.getAbsolutePath());
           directoryCounter++;
           File[] files = file.listFiles();
           for( int i = 0; i < files.length; i++ )
               traverse( files[i] );
       else
 //if( file.getName().endsWith(".java") || file.getName().endsWith(".jsp") || file.getName().endsWith(".xml"))
 	if( file.getName().endsWith(".java") )
   countLines( file );
   public void countLines( File file )
       try
           raf = new RandomAccessFile( file, "r");
           fileCounter++;
           while( raf.readLine() != null )
               counter++;
           raf.close();
       catch(Exception ex)
           ex.printStackTrace();
   public static void main(String[] args)
       if( args.length == 0 )
           System.out.println("Usage: \njava LineCounter <path_to_folder>");
           System.exit(0);
       else
       	new LineCounter( new File(args[0]) );
 //new LineCounter( new File("./") );
Endret av krigun
