Koder til Halo, alle kan vel ikke virke!?
Kom over denne siden idag da jeg surfet (nei, jeg leter ikke etter juksekoder, kom over det) på nett. Det var et bar ting jeg stusset over men det jeg stusset mest over var denne koden:
Stripper Mode Cheats
During the Campaign, Successfully Press, A,X,B,B,Y,Right Trigger, Left Trigger, Right Click, X, Y, W, B, W, B, W, B, W, B, W, B, Right, Right, W, B, Black, Y, A, X, B, Left Click, Left Trigger, Left Trigger, Left Trigger, Left Trigger, Right Trigger, Back, Start, Start, Y, B, X (Board a Ghost with this last button).
Make sure that you are over a pile of weapons because you want to be dual wielding throughout the entire code. The result will be once you get out of the ghost after u kill at least 5 enemies by boosting, that you will be transformed into a cortana looking HOTT Female, wearing the Master Chief Helmet. Some how master chief has taken the role of Cortana. If the code doesnt work try again!!!! it has to be timed correctly.
